Dont forget to mention that the fueling will be all wrong and will proberaly cause the engine to run like a bag of nails until it has had a serious re-map...bbspolo wrote:tps sensor i would guess is different!
Maybe wrong so let me know if it works as id be intrested 2 know!
U do know fitting a 2big throttle will kill your throttle responce as the manifold wont be able 2 cope with the difference in afs (air flow speed!)
But it depends from engine 2 engine so no1 who hasnt tried this will be able 2 tell u its just r&d that will tell if it works!
Good luck
You have to remeber that on the GTI with the throttle wide open, the variable valve timing kicks in to make allowances for the massive airflow occuring...
