Tim_GTi
Post Whore
Posts: 12289 Joined: Mon Jun 25, 2007 6:31 pm
Post
by Tim_GTi » Fri Nov 14, 2008 1:45 pm
camber shims are what your looking for mate. they're normally used on the scene to increase negative camber to get more tuck in, can be used the otherway tho. they're fully adjustable
1der
Posts: 604 Joined: Fri Aug 11, 2006 2:41 pm
Post
by 1der » Fri Nov 14, 2008 1:47 pm
good place to get them?
Tim_GTi
Post Whore
Post
by Tim_GTi » Fri Nov 14, 2008 1:52 pm
im on the net on my phone at the mo, so its a bit of an effort to find you a link sorry. if you search 'camber shims' on clubpolo or edition38 theres a usual link on there to a shop.
1der
Post
by 1der » Fri Nov 14, 2008 1:53 pm
ok no bother tim. il have a search
tegwin
Posts: 945 Joined: Mon Nov 13, 2006 5:14 pm
Post
by tegwin » Fri Nov 14, 2008 2:39 pm
Does anyone know... how much lowering the car effects rear toe?
I assume the camber shims people have used have a wedge on both camber and toe to return it to straight?
Tim_GTi
Post Whore
Post
by Tim_GTi » Fri Nov 14, 2008 2:50 pm
yeh my toe is out. I wouldn't have thought camber shims would fix that tho
tegwin
Post
by tegwin » Fri Nov 14, 2008 3:24 pm
Im not sure what the camber shims for the polo are like..
The ones I fitted to my sierra when I lowered it fitted between the upright/hub and the suspension arm..
They were tapered in both directions so corrected for camber and toe.... Are the polo ones not similar?
Tim_GTi
Post Whore
Post
by Tim_GTi » Fri Nov 14, 2008 3:29 pm
I've only seen pictures of camber shims, they're round, and look a bit like a timing meter on a house boiler?
so i'm assuming they go between the hub and wheel.
