9n3 Gti bhp output
Re: 9n3 Gti bhp output
well im running the stock airbox, so mine is sound less
but on an open cone they sound more like a sqeal from a pig because of how fast they operate
as for horror stories, iv never heard of any, and my valve runs better than my 007p ever did, never get any boot escaping now due to weak springs as there is no spring
as for my torques, i dont know, maybe i have just got a good one, but you have been in it, you gotta admit it pulls dam well
Alex_White_Gti
Lol !
Yeah, ill give you that i did pull well.
Not horror stories as such, just bringing up fault codes and warning lights with some people running them. But if yours is ok i might get one of those when i get back from hols. Anyways, i thought you were running a jetex? That why i asked about how it sounded you see.
And also....if you are after some proper nice wheels have you looked at the SCHMIDT TH LINES with a carbon centre? Could look great on black.
If you did want some schmidt rims, im good friends with a guy who imports them at rimstyle. Hes a customer of mine. Let me no i could probs get you a few quid knocked off....better than a kick in the teeth.
cheers alex, ill bare that in mind, but am just getting some narrower front tyres for now to keep my BBS's
i wanted 16 inch schmidt th lines the same in modern lines, but neither will clear the 312 brakes
cheers tho
as for the jetex, the company i ordered it off failed to supply and gave me a refund which is p*** poor, something else i need to get re ordered
iv defo had no issues from the APR R1 mate, for me, it also looks better than the 007p's aged large design
cheers tho
Alex_White_Gti
ok mate, well most of your top brands like bbs, schmidt, keskin etc etc i can get so....you know where i am.
So does the APR R1 run smaller than the 007 then? As my 007 knocks and rubs on my strut brace which gets annoying...dont really wanna be running around with a bit of rubber wedged underneath. That sucks about the jetex....i wanna cone filter but just dont know what route to go down at all tbh.
alex its much smaller in length but slightly larger in diameter, it fits under the engine cover and can just be seen, does not hit or rattle on anything at all
as for filters, iv heard jetex are the best for our engines, but awesome has told me what BHP ill gain by adding a filter, ill lose in torque and as you have said my torque is well up there at the min and it is torque that pulls you along, bhp being more pub talk
so im considering leaving mine as it is up until stage 3 when its paid off october 2010
- KennyPOLO_Gti
Roll on October 2010 for me too!
270lb/ft or torque on standard clutch is very good! Never get any slippage with that? I want more torque!
na mate nothing
just more likely to light the road up than slip, its pretty good, want a spec or sachs clutch in time tho when it starts to give, bear in mind, my cars only done baby milage as its not really a daily as i have another car for doing the daily stuff on
- KennyPOLO_Gti
Yeah thats true, mines has done a good few miles now! But i pay a lot of money for it so am going to enjoy it
Think a high flow mani will improve thing by much?
Really want to spend money on it just now, but go a stag do in newcastle next week so need to keep a bit of cash for that!
Alex_White_Gti
Jeff - ok mate i might get the apr one then. Also k&n do that filter where the cone is actually inside a replica of your own air box....have you seen those? Maybe these would be ok. The airbox is actually embossed with there k&n sign so would look good aswell.
kenny - There has to be someone around who could make a custom manifold for our cars as this is somthing i would love just to finish off the engine bay after i had it painted.
alex i dont think those k and n air boxes are out for our cars
What's the difference between the APR DV and the Forge DV???
apr one is a diaphram based valve - quicker acting - new lfe long reliability - no servicing - no boost leaks from weak springs as therer are no springs - as a whole is a smaller unit
forge one is older technology - works on a vacuum method of moving a piston against a spring to hold / release boost - requires yearly maintenance and servicing - as a whole is a bigger unit
Yeah that's true, although my Corrado would laugh in the face of a 250hp PoloAlex_White_Gti wrote:I sort of aggree with that marco...but there wont be much keeping up with a properly tuned 250 + bhp polo when your out and about on your daily drives lol
It's a bit more than just shoving a 2.0 TFSI in though. It's a smoother engine, has a broader spread of torque, can rev higher (less valve train weight) and attaches to the strongest gearbox VW make, so will set you up for many years of tuning
If our Polo GTI was mine and not the missus's, that's exactly what I would be doing!
Ah i see, cheers!Jeff GTi wrote:apr one is a diaphram based valve - quicker acting - new lfe long reliability - no servicing - no boost leaks from weak springs as therer are no springs - as a whole is a smaller unit
whats in the rado
as for laugh in the face of a 250 hp polo, come on, its gotta be somethiong pretty special to disgrace it like your saying, beat it maybe, but to laugh in the face of it, what you doing, a 911turbo conversion
if its a 2.0tfsi, fair play its a more modern engine, capable of bigger output power, but iv had one and hated it, felt smooth and dull (in standard form - im sure they are better mapped and played with)
iv played with a 2.0tfsi golf mk4 and had no issues with it
