Ricky's Green 6n2 - SOLD....BMW POWER
Re: My Green 6n2 + UPDATES!!
I've not seen you around, where in Croydon are you?
thanks mate, wheels were not really what i wanted but i really hated the standard ones, all 4 of the steels were not even the same!, hopefully if i end up keeping my polo for a while i will invest in something a bit more dubstyle6N2 GTI 00 wrote:Car is looking good mate,
The wheels are not my cup of tea but they look much better than the standard wheels.
The grille makes the world of difference, I am not normally a fan of black VW badges but it really does suit your car, the green/black colour combo works well.
Keep up the good work
I live right next to Halfords and staples (or halfrauds as its called on here lol)lowfoon wrote:I've not seen you around, where in Croydon are you?
i drive through Shirley everyday on my way to work though, seen so many nice 6n2's around, its probably what pushed me to get the fogs done
Gave the calipers a lick of lime green today, thought id go for something different
rear drums have been sprayed satin black, but dont have a pic atm!
lol my discs look so tiny
- 6N2 GTI 00
Looks much better mate
Top Job
Managed to finish up the rear badge today and de-wiper it
however my brake lights have stopped working
, do any of the wires for the brake lights run through the boot panel? i only unplugged the one attached to the wiper motor
probably need a new brake light switch
Usually if it is the brake light switch the EPC light would come on your dash...
yep the EPC has been on since i bought it about 3 months ago, but the brake light has been working. il check the fuse tomorrow if its not that il pick up a brakelight switch from a local car parts
why not have a go with vag-com?
i bought a cable off ebay (£9 blue one) and using the shareware version of vag com, but i cant seem to get it to work, it scans but nothings coming up, but i have the engine check light and the epc light on. ( on the version on the pc it says select chassis code, i chose 6N because 6N2 isnt on there, do i need to add 6n2 to the .txt file?) - for those who know what im talking aboutdub6n2 wrote:why not have a go with vag-com?
Bring it round and I'll plug it into my one - I cleared my engine management last night
it works fine for me when choosing 6n. if it is scanning it should be working all right. try scanning using the engine controller option.RS_GT wrote:i bought a cable off ebay (£9 blue one) and using the shareware version of vag com, but i cant seem to get it to work, it scans but nothings coming up, but i have the engine check light and the epc light on. ( on the version on the pc it says select chassis code, i chose 6N because 6N2 isnt on there, do i need to add 6n2 to the .txt file?) - for those who know what im talking aboutdub6n2 wrote:why not have a go with vag-com?
will do mate if i cant sort minelowfoon wrote:Bring it round and I'll plug it into my one - I cleared my engine management last night
il try it again tomorrow, but im sure when i did it at the end it said 'no controller found', don't know if im doing it rightdub6n2 wrote:it works fine for me when choosing 6n. if it is scanning it should be working all right. try scanning using the engine controller option.RS_GT wrote:i bought a cable off ebay (£9 blue one) and using the shareware version of vag com, but i cant seem to get it to work, it scans but nothings coming up, but i have the engine check light and the epc light on. ( on the version on the pc it says select chassis code, i chose 6N because 6N2 isnt on there, do i need to add 6n2 to the .txt file?) - for those who know what im talking aboutdub6n2 wrote:why not have a go with vag-com?
did you just switch the ignition on then plug in and auto-scan?
plug the cable, switch the ignition and then from the options check that you have the working COM Port chosen by running the test. if it is giving you that error either the ignition is not switched on or the wrong port is chosen. and preferably always choose the same USB port or else you will have to continually change the COM port setting
