Heres a pic of my setup on my old gti
Worked a treat along with the froge 007p valve I miss the noise
Gti Air Filter Options?
- lukey GTI
Re: Gti Air Filter Options?
what cone is that ? NMAVS
Got my Jetex filter from badger 5 just give him a tinkle and he will send it out for you. They do sound awesome and he knows the correct one you need. Make sure you remove the sound deadening.
Its a Jetex pal. From Badger 5. Ive still got it in the garage with the blue pipercross oil breather filter. If anyones interested, £30 delievered for both
Meeee ill take them now! pm me
I recently went from the PD160 to a good pod in the airbox. I'm in Australia BTW, so different ambient temps, etc. Its about 20-25 deg here now.
Positive changes, but the added heat does not take long to do its damage. the argument around letting the intercooler do its job just makes me think of the difference between driving around when its 10deg or 30deg.
The pod in the stock bottom of the airbox does little to suck air down the original channel. Its more likely to suck air from the engine area. I tried a heat shiled sitting around the pod and into the airbox, better, but still too much heat.
The plan is to change the battery as the stock one is due to die, replace it with a smaller one near the back of the stock airbox location and pull air from near the passenger foglight area.
IMO if its sucking ANY engine bay air, its probably less efficient than the stock box with the PD160.
If I get there, I'll put up some info, or come visit the active Polo community at the VWW Polo section...
