6R - Multifunction Steering Wheel Retrofit
jammydodger
Drives: 6R GTI
Re: 6R - Multifunction Steering Wheel Retrofit
Post by jammydodger »
Sorry for dragging up such an,old thread but can anyone tell me if my airbag from a plastic non-multifunction steering wheel will fit into a leather non-multifunction steering wheel... Thanks :)
It will not sadly
The leather steering wheel is a different design regardless of being multifunction or not (same wheel, just has blanks)
jammydodger
Drives: 6R GTI
:( damn!
Antonio92
Post by Antonio92 »
As far as I know, the airbag DOES fit (50/50 chance) if going from a leather round non-multifunction steering wheel (Polo Advance) to a round multifunction steering wheel (Polo Sport) with ONLY left buttons. It won't fit if updating to a MFSW with left and right butons.
Retali
Post by Retali »
I am really confused here,
Does the airbag, from a leather highline steering wheel, fit to a NO-multifunctional T5 (Gt/etc) wheel ?!
What should we guys look for in order to be certain ?!
Has anyone tried the above combination that i mention ?
Airbag from leather steering wheel to a T5 nomulti steering wheel .
Timbo220181
Post by Timbo220181 »
Guys, sorry to drag up an onld thread - I'm about to take stock of an R line Polo and the MFSW isnt an option annoyingly.....
Having spoken to parts they are about as clear as mud. Please can someone confirm which bits I need to do this retro fit?
Is it just the buttons and the cruise stalk? Obviously I have the R line flat bottomed wheel so I wont need the air-bag correct?
I seem to be getting told it cant be done in the dealerhsip, but this DIY says otherwise
Many thanks
diskoboy
Drives: 1.6 TDI BMT
Post by diskoboy »
The LIN-BUS can also be found on T28a/16 (connector to the driver door LHD cars). Perhaps it's easier for some :-)
AntonDelin
Drives: Polo 1.2TSI DSG GT
Post by AntonDelin »
Thank you very much Der Finne for a great DIY!
How about us who already have a standard left spoke mfsw, do we only need the coding when retrofitting a GTI steering wheel?
Thanks in advance :D
hmt
Drives: Polo gt tsi 1.2 dsg
Post by hmt »
I have 2015 1.2 gt tsi with flat bottom steering, with buttons on both sides, from India. Which steering with paddle shifters can i fit to my car?? Can anybody provide part number?? Thanks
AntonDelin wrote:Thank you very much Der Finne for a great DIY!
not even coding (sorry for the late answer, but maybe someone else will profit)
AndreasSPunkt
Drives: Polo 6R GTI
Post by AndreasSPunkt »
Hello,
sorry for my bad english.
Can someone tell me the partnumber of this clip with gti logi in black?
vnanic
Drives: Polo 6C 1.4 TDI
Post by vnanic »
Will this work on Polo 6C?
Built date is 10.05.2015
It has no buttons on steering wheel at all and in car shop they said to me that I need to change AirBag Centrale, Steering wheel centrale and the price for all that is around 3000€ :?
neil.cowie
Post by neil.cowie »
Great how to. Going to try with my t5 caravelle. Can I to the programming myself or do I need to use a garage.
Neil
neil.cowie wrote:Great how to. Going to try with my t5 caravelle. Can I to the programming myself or do I need to use a garage.
Neil
Easy to do yourself with vcds
vnanic wrote:Will this work on Polo 6C?
no you need a different procedure for polo 6c. it depends whether your bcm will support it. the airbag ECU and steering angle sensor do not need to be replaced.
dsorinn
Drives: Polo 6r, 1.6 TDI 140 HP
Post by dsorinn »
Hey guys,
I just fitted a highline steering wheel with MFSW but I have a problem. After I wired everything and coded, my BC buttons don't work. They still work from the wiper lever, but not from the steering wheel. I tried every coding I could find but still nothing. I even changed the wiper lever with one without BC buttons, but still nothing.
I'm out of ideas..what should I change so I could make it work ? Could it be the slip ring (my polo is the first generation, 2009-2010) or the airbag wiring ? my airbag wiring has a "D" at the end instead of "A" and the slip ring has an "E" at the end. The steering wheel is made by TRW in 2016, the same with the wiring.
The music buttons work perfectly..
