Page 2 of 2
Re: Twin Headlight and Single Headlight System
Posted: Fri Oct 23, 2020 8:05 am
by cypherone
kartikhere_2498 wrote: Tue Sep 22, 2020 2:23 pm
alexperkins wrote: Tue Sep 22, 2020 2:14 pm I see
You can order these from your local VW dealer. You'll need details from ETKA to get the plug part numbers and associated pins however
Ciclo on here may be able to assist you
I tried to approach the VW dealer here in India but no luck, will try to contact Ciclo.
Thanks for help :)
Hi Karthik,
Any luck with upgrading to twin barrel headlights? I am from India and even i am planning to do so on my Polo 6R.
Posted: Fri Oct 23, 2020 10:50 am
by amer6R
Why would you? You need 2x H7 bulb per headlight instead of 1x h4 bulb
Posted: Thu Nov 12, 2020 8:57 am
by kartikhere_2498
cypherone wrote: Fri Oct 23, 2020 8:05 am
Thanks for help :)
Hi Karthik,
sorry for the delayed reply, actually my friend got it done on his Vento he did it from someone in Hyderabad
Posted: Fri Nov 13, 2020 6:34 pm
by cypherone
kartikhere_2498 wrote: Thu Nov 12, 2020 8:57 am
Thanks for help :)
Hi Karthik,
Hi, do you have contact details?
Posted: Tue Dec 15, 2020 6:41 pm
by fun2sshh
I have vento (india) 2011 with single barrel H4 three pin headlight. Recently I upgraded to dual barrel H7 two pin headlight. The connectors are totally different with both headlights. The former has three connectors( one for parking light one for signal light and one for headlamps.) while the later has 10 pin connector.
Posted: Tue Dec 15, 2020 6:43 pm
by fun2sshh
Posted: Tue Dec 15, 2020 8:17 pm
by iichel
Yes that's correct. You need to reconnect the wires to the new connector
