Twin Headlight and Single Headlight System
cypherone
Drives: polo 6R
Re: Twin Headlight and Single Headlight System
Post by cypherone »
kartikhere_2498 wrote: Tue Sep 22, 2020 2:23 pm
alexperkins wrote: Tue Sep 22, 2020 2:14 pm I see
You can order these from your local VW dealer. You'll need details from ETKA to get the plug part numbers and associated pins however
Ciclo on here may be able to assist you
I tried to approach the VW dealer here in India but no luck, will try to contact Ciclo.
Thanks for help :)
Hi Karthik,
Any luck with upgrading to twin barrel headlights? I am from India and even i am planning to do so on my Polo 6R.
Why would you? You need 2x H7 bulb per headlight instead of 1x h4 bulb
kartikhere_2498
Drives: 2011 VW vento (polo sedan) 1.6mpi MT
Post by kartikhere_2498 »
cypherone wrote: Fri Oct 23, 2020 8:05 am
Thanks for help :)
Hi Karthik,
sorry for the delayed reply, actually my friend got it done on his Vento he did it from someone in Hyderabad
cypherone
Drives: polo 6R
Post by cypherone »
kartikhere_2498 wrote: Thu Nov 12, 2020 8:57 am
Thanks for help :)
Hi Karthik,
Hi, do you have contact details?
fun2sshh
Drives: Vento
Post by fun2sshh »
I have vento (india) 2011 with single barrel H4 three pin headlight. Recently I upgraded to dual barrel H7 two pin headlight. The connectors are totally different with both headlights. The former has three connectors( one for parking light one for signal light and one for headlamps.) while the later has 10 pin connector.
fun2sshh
Drives: Vento
Post by fun2sshh »
Yes that's correct. You need to reconnect the wires to the new connector
