UK-POLOS.NET - THE VW Polo Forum • Best VAGCOM codes to enable on Polo 6R? - Page 2
Page 2 of 5
Re: Best VAGCOM codes to enable on Polo 6R?
Posted: Tue Feb 18, 2014 9:23 am
by ciclo
Mart!n-GTI-DK wrote:
Wilxay wrote:Get tear wiping done too bud
Have you had that done? I have heard that it's not possible on the Polo.
Posted: Tue Feb 18, 2014 11:44 am
by Joe9n3
In VCDS Select Control Module, go to 03 ABS Brakes, then 10 Adaptation, go to Channel:
Channel 09 Brake Assist
There are 3 settings for this
0-center (stock setting)
1-small
2-hard
Channel 36 XDS
1-weak
2-strong
Big Digital Speedo
Guide
Go to 17-Instruments and look under Coding, then (IIRC) on the first page, there is a drop down list of countries (it will currently be set as UK) change it to Australia, this is all you need VCDS for.
Then on the car's maxidot go to:
MFD
SETTINGS
Units,
"Consu/distance" change this back to mpg (GB), mi (as it defaults to 1/100km, km),
then
SETTINGS
"MFD data" and make sure the box for Digit.speed is ticked
then
SETTINGS
and unticked the "ALT.speed dis." box (this will remove the KPH speed and replace it with the outside temp display)
Posted: Tue Feb 18, 2014 1:54 pm
by Mart!n-GTI-DK
I know. But Watcher activated this in his Polo and it still didn't work... Does it work in yours?
Posted: Tue Feb 18, 2014 1:55 pm
by JayW
I will show this to the vagcom guy tonight and see what if he can do it. Looks complicated cos of all the steps lol.
Posted: Tue Feb 18, 2014 5:13 pm
by ciclo
Mart!n-GTI-DK wrote: I know. But Watcher activated this in his Polo and it still didn't work... Does it work in yours?
I have not enabled bit4.
I'll have to try it, then I will tell if it works or not. :wink:
The bit 7 working properly.
Posted: Tue Feb 18, 2014 6:15 pm
by Mart!n-GTI-DK
ciclo wrote:The bit 7 working properly.
What does that do ?
Posted: Tue Feb 18, 2014 6:58 pm
by ciclo
It is very interesting. Change the speed of wiper depending on the intensity of the rain.
This past weekend I made a long trip and was constantly raining, I put the stalk in the first position and this automatically varied wiper speed. It's okay to be able to quietly take out boogers with the right hand ... :lol:
Posted: Tue Feb 18, 2014 7:56 pm
by Mart!n-GTI-DK
ciclo wrote:It is very interesting. Change the speed of wiper depending on the intensity of the rain.
Isn't that the same thing the rainsensor does?
Posted: Tue Feb 18, 2014 10:57 pm
by JayW
Right so tonight I went down to see a guy who could do the Vagcom stuff for me.
Managed to get:
celebration mode working
1 click unlocks all doors
anti-hijack
however XDS and welcome home lights wouldn't work.
He said he couldn't find the XDS modules at all so either I don't have them or it's just not there. Is there something that maybe we missed?
For the coming home lights, we enabled it for the FOGS however when we tried it nothing happened! It doesn't work... so again is there something we missed?
My car is a 13 plate Polo R-Line 1.2 TSI
Posted: Wed Feb 19, 2014 12:03 am
by Roundsquare
Do you not have to pull the light stalk back before getting out the car for the coming home lights to work?
Sent from my GT-I9305 using Tapatalk
Posted: Wed Feb 19, 2014 4:41 am
by Wilxay
The coming home lights only work if you pull the headlights once when you have taken the keys out of the ignition
Posted: Wed Feb 19, 2014 10:01 am
by benhowarth6
JayW wrote:Right so tonight I went down to see a guy who could do the Vagcom stuff for me.
Managed to get:
anti-hijack
I was under the impression that the XDS was only available on GTI's as the other models don't have the electronic diff lock?
Posted: Wed Feb 19, 2014 10:09 am
by Eddie-gt
Managed to get:
anti-hijack
XDS is a feature of the ABS unit, so if the pump supports it then it can be enabled
Posted: Wed Feb 19, 2014 10:31 am
by ciclo
Mart!n-GTI-DK wrote: Isn't that the same thing the rainsensor does?
No. When you put the stalk in the first position can regulate (small lever) activation sensitivity with which the wiper works, but always at the same sweep speed. However, to enable bit 7 sweep speed depends on the rain intensity.
It's fantastic, more water, faster ... automatically.Thus it is not necessary to go to the second or third position of the stalk. :wink:
:twisted:
Posted: Wed Feb 19, 2014 1:58 pm
by JayW
Right.. so if i go to my car now and start the car... then turn it off, take the ignition out and pull the headlight stalk once.. should it work? I dont need vagcom connected still do i? Cos the guy has enabled it but couldn't get it to work but of course i asked him to leave it enabled.
