Best VAGCOM codes to enable on Polo 6R?
Hi all,
I'm going to get my car plugged in tomorrow night and some codes enabled.
So far im getting,
Celebration mode/Needle sweep
XDS from normal to Hard
Welcome home lights on
Autolock after 10 seconds of driving
1 click unlocks all doors
Is there anything else i could enable or worth trying?
Jay
So far im getting,
Jay
Re: Best VAGCOM codes to enable on Polo 6R?
Have you got standard halogen bulbs? If so let me know if the coming home feature codes in
- Mart!n-GTI-DK
- Drives: '14 Polo BlueGT
What is XDL ? ? ?JayW wrote:Hi all,
XDL from normal to Hard
It does mate, so i will try and let you guys know for sure if it works.mattymdm wrote:Have you got standard halogen bulbs? If so let me know if the coming home feature codes in
Mart!n-GTI-DK wrote:What is XDL ? ? ?JayW wrote:Hi all,
Think it has other names too like EDL. It's to do with the differential lock? so it stops the power to the spinning/slipping wheel earlier and divert to the other wheel that needs it? Something along those lines
Correct me if im wrong btw!
XDS helps the car corner better by applying the brakes to the inner wheelsJayW wrote:Correct me if im wrong btw!
Get tear wiping done too bud
- Mart!n-GTI-DK
Have you had that done? I have heard that it's not possible on the Polo.Wilxay wrote:Get tear wiping done too bud
Thanks Eddie!!Eddie-gt wrote:XDS helps the car corner better by applying the brakes to the inner wheelsJayW wrote:Correct me if im wrong btw!
Never heard of this mod, what is it? what does it do?Wilxay wrote:Get tear wiping done too bud
- Mart!n-GTI-DK
It's when you use the window washer. Then afterthe wipers have stopped they wait a little while and then wipe the washerfluid drops running across the windshield.JayW wrote:Never heard of this mod, what is it? what does it do?Wilxay wrote:Get tear wiping done too bud
brakes from normal to hard.
makes loads of difference and works a treat with the xds set to hard aswell
great fun in the summer on back lanes with h&r, fresh rubber & stage 2
- greypolo9n3
- Drives: white 6r 1.6 tdi rline/gti
Can you post up how you can get all these done?...Vag com idiots guide?! lol
Yeah I got it done. Did it myself. I've got 13 plate R Line if that's different
