BlackPoloBM
blackpolobm
Drives: Polo Bluemotion
Re: BlackPoloBM
Post by blackpolobm »
IZVVC wrote:Car looks absolutely amazing mate, where did you get the alloy wheels from?
Thanks, I bought them on Ebay. They came from the UK.
IZVVC
Re: BlackPoloBM
Post by IZVVC »
Thanks mate, do you have a link or something or seller name?
that would be great!
thanks :mrgreen:
blackpolobm
Re: BlackPoloBM
http://www.madmotors.co.uk/alloy-wheels.html
This is their website. I searched for my wheels but could not find them.
Maybe you can find it or contact them about it.
Re: BlackPoloBM
Watch your inbox. :wink:
boomshack
Drives: 1.2 Bluemotion with R-line mods
Re: BlackPoloBM
Post by boomshack »
Did you solve the LED's problem?
Re: BlackPoloBM
boomshack wrote:Did you solve the LED's problem?
Just mention that you may not have these problems because your BCM is Maxx. Not sure because no one commented about it.
In addition blackpolobm did not make the wiring as iichel (still flashing of the leds without capacitors, everything else works perfectly).
There are many factors to consider on each Polo.
Results after install OEM xenon on your Polo are very important due to type of BCM. :wink:
blackpolobm
Re: BlackPoloBM
No, I still have the flashing LED's.
I had a adapter that was made just like Ichell's, but it did not work on my car and the canbus shuts all the led off so now I just use the flasing one untill the problem is solved someday somehow.
boomshack
Re: BlackPoloBM
Post by boomshack »
when you turn on Xenon the Leds keeps flashing? or do they only flash a couple of seconds until they are dimmed down?
Because if they flash while "normal" light / Xenon is on its kinda pointless, that will only get my pulled over:P
blackpolobm
Re: BlackPoloBM
Its flashing when you turn the wheel. And sometimes it flashes just a little bit. 1 time per minute or something.
LeeT96
Drives: 6R R-Line 1.2 TSI 105
Re: BlackPoloBM
Post by LeeT96 »
This is beautiful!
Are the GTI/RLine bumpers straight-swap? And will my lights still work with them?!
Re: BlackPoloBM
yep they are a straight swap
