Problem with electric window
reborno
Drives: polo 6r 1.6 tdi dsg
Re: Problem with electric window
Post by reborno »
hello i know its little bit late but i have the same problem:(
reborno
Post by reborno »
i hope you would help to me
Sunday,18,March,2018,18:53:26:27676
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170220 DS267.3
www.Ross-Tech.com
VIN: WVWZZZ6RZEY064027 License Plate:
Mileage: 46670km-28999mi Repair Order:
Chassis Type: 6R (6N0)
Scan: 01 02 03 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZEY064027 Mileage: 46670km-28999miles
56-Radio -- Status: Malfunction 1110
Address 01: Engine (J623-CAYB) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 MG HW: 03L 907 425 B
Component: R4 1.6l TDI H33 9979
Revision: --H33--- Serial number:
Coding: 00254016000400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM16TDI02103L906023MG 003013
ROD: EV_ECM16TDI02103L906023LC.rod
VCID: 77FC68DFCEA158F9D8-8022
Readiness: 0 0 0 0 1
Part No SW: 0AM 300 058 F HW: 0AM 927 769 D
Component: GSG DSG AG7 431 4530
Revision: 00043014 Serial number: CU501307115999
Coding: 0000020
VCID: 34669FD3545773E13D-5140
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ABS82.clb
Part No SW: 6R0 907 379 AE HW: 6R0 907 379 AC
Component: ABS8.2 front H04 0001
Revision: --------
Coding: 200228E3017300B6042514E480D800000200
VCID: 010806079C651649E6-8054
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 N HW: 6R0 820 045 N
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 3978AEE7B0358E89EE-806C
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 P HW: 6R0 937 087
Component: BCM PQ25 H+4 H34 0411
Revision: BF034001 Serial number: 0581 214130719
Coding: 7CB82FBF68A3000000380E007F2B9CD90008410F60040040300000000000
Shop #: WSC 124697 483 00190
VCID: 4A9AE12BE5D3151177-801E
Subsystem 1 - Part No SW: 6R0 959 801 AT HW: 6R0 959 801 AT Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8610
Serial number: KU0KU008081300013291
Coding: 0200A0
Subsystem 2 - Part No SW: 6R0 959 802 BE HW: 6R0 959 802 BE Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8610
Serial number: KU0KU007081300015312
Coding: 0200A0
Subsystem 3 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Serial number: 0108556
Coding: 020000
Subsystem 4 - Part No SW: 6R0 959 811 N HW: 6R0 959 811 N
Component: J388__TSG_HL 003 8610
Serial number: KU0KU009081300012542
Coding: 0000A0
Subsystem 5 - Part No SW: 6R0 959 812 N HW: 6R0 959 812 N
Component: J389__TSG_HR 003 8610
Serial number: KU0KU001081300014903
Coding: 1000A0
3 Faults Found:
00967 - Left Turn Signals
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 46679 km
Time Indication: 0
Date: 2018.03.18
Time: 18:45:43
00968 - Right Turn Signals
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 46679 km
Time Indication: 0
Date: 2018.03.18
Time: 18:45:43
00901 - Back-Up Lamps
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 46679 km
Time Indication: 0
Date: 2018.03.18
Time: 18:45:43
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Component: VW10Airbag00G H10 0020
Revision: -------- Serial number: 003GW00MC8W$
Coding: 003047
Shop #: WSC 01383 785 00200
VCID: 4998DE27E8D51E097E-801C
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 861 M HW: 6R0 920 861 M
Component: KOMBI H02 0406
Serial number: 00000017687764
Coding: 140A01
ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01723
ROD: EV_DashBoardUDSJCIPQ25_A01_VW25.rod
VCID: 3F8CC0FFA611A0B9D0-806A
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H34 0411
Revision: BF034001
Coding: 002200
VCID: 70EE53C3A3CF0FC119-8024
1 Fault Found:
01304 - Radio
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 46679 km
Time Indication: 0
Date: 2018.03.18
Time: 18:45:48
Address 25: Immobilizer (J285) Labels: 5K0-920-xxx-25.clb
Component: IMMO H02 0025
Serial number:
ASAM Dataset: EV_ImmobUDSJCIPQ25 A01003
ROD: EV_ImmobUDSJCIPQ25.rod
VCID: 6ADA41AB8D13F51157-803E
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 10150
Shop #: WSC 00788
VCID: 306E93C3F74F4FC159-8064
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:22)--------------------------
Hello reborno, welcome. (manchester)
RHD or LHD?
Do the following if it's RHD.
New GW coding.
Revision: BF034001
Coding: 002300
New WRMs codings. (4)
Coding: 1000A0
Coding: 0000A0
Coding: 1000A0
Coding: 0000A0
... and set the comfort function with window switches according the user manual.
Please report the results.
What happened or were you doing for this fault to happen? :)
I know it's an LHD but maybe I'm wrong. :lol:
reborno
Post by reborno »
I tried to change everything for to fix problem. And also I am flying to madrid today;) i heard most from spain. Car options was module not installed and lhd rhd was not installed before i changed them. Should i return to previous? Tomorrow i would inform the codes, thank u friend
reborno
Post by reborno »
It is lhd. Should i try the codea anyway?
LHD
GW coding.
Revision: BF034001
Coding: 002200
WRMs codings. (4)
Coding: 0000A0
Coding: 1000A0
Coding: 0000A0
Coding: 1000A0
Please report the results. :wink:
reborno
Post by reborno »
Great. Its working! Thank you bro
lokesh
Drives: Polo Highline 1.2 Petrol 6R
Post by lokesh »
Hello ,
I am also facing the same issue . The driver and the front passenger side windows are working in wrong way .
This is a RHD polo [indian specific].
Possible cause - I had tested a VCP cable on my car at my friends place for the intermittent headlights(H4 led bulbs) getting off [ I have replaced all bulbs with led bulbs in my car]. The issue was not resolved but I am getting a whole lot of errors now in the VCDS autoscan .
Please also let me know if its possible to stop led headlight flickering [ intermittent turning off and on ] using VCDS .
Can someone please help me !! :(
VCDS Scan :
Wednesday,10,October,2018,15:45:32:00006
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: WVWB10602AT000319 License Plate:
Mileage: 56200km-34921mi Repair Order:
Chassis Type: 60-VW25 (6N0)
Scan: 01 03 09 15 17 19 25 44
VIN: WVWB10602AT000319 Mileage: 56200km-34921miles
Address 01: Engine (CJL) Labels: None
Part No SW: 03E 906 023 P HW: 03E 906 023 P
Component: SIMOS91 1.2l 4V 5811
Revision: --H05--- Serial number: 00000000000000
Coding: 0000031
Shop #: WSC 01234 785 00200
VCID: 2C57B2B28C0B312494-5178
2 Faults Found:
18045 - Powertrain Data Bus
P1637 - 009 - Missing Message from Electric Load Controller - Intermittent
16556 - Fuel Trim; Bank 1
P0172 - 007 - System Too Rich - Intermittent
Readiness: 0010 0001
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ABS82.clb
Part No SW: 6RF 907 379 HW: 6R0 907 379 AB
Component: ABS8.2 front H03 0002
Revision: --------
Coding: 500200C1006D00B20A2800E300DA00004000
Shop #: WSC 02069 000 00000
VCID: 11290346CC697CCC87-8044
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 88
Mileage: 55703 km
Time Indication: 0
Date: 2013.02.05
Time: 16:22:30
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x32D4
Hex Value: 0x16A9
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7E00
Hex Value: 0x0000
Part No SW: 6RU 937 086 HW: 6RU 937 086
Component: BCM25 IM M+4 H46 0207
Revision: BY046001 Serial number: 0118 289090026
Coding: 32B02BBF08B30000003000003C2B04900040410F60040000200000000000
VCID: 1E33687A09B7D3B40A-804A
Subsystem 1 - Part No SW: 6R0 959 802 D HW: 6R0 959 802 D Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 002 3411
Coding: 030000
Subsystem 2 - Part No SW: 6R0 959 801 F HW: 6R0 959 801 F Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 002 3411
Coding: 030000
Subsystem 3 - Part No SW: 6R0 959 811 E HW: 6R0 959 811 E
Component: J388__TSG_HL 002 3411
Coding: 020000
Subsystem 4 - Part No SW: 6R0 959 812 E HW: 6R0 959 812 E
Component: J389__TSG_HR 002 3411
Coding: 020000
2 Faults Found:
01332 - Door Control Module; Passenger Side (J387)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Time Indication: 0
01331 - Door Control Module; Driver Side (J386)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 55703 km
Time Indication: 0
Date: 2013.02.05
Time: 16:39:24
Part No SW: 6R0 959 655 E HW: 6R0 959 655 E
Component: VW10Airbag600 H09 0018
Revision: -------- Serial number: 003DY000EBLA
Coding: 003030
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4487FA12CF9BD9647C-8010
1 Fault Found:
12666368 - Databus
U1122 00 [008] - Implausible Message
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Part No SW: 6RF 920 860 HW: 6RF 920 860
Component: KOMBI X05 0006
Coding: 540800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
VCID: 071D2D1EBE2D327C59-8052
1 Fault Found:
12664832 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Priority: 6
Fault Frequency: 2
Reset counter: 88
Mileage: 55703 km
Date: 2018.09.15
Time: 16:22:29
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6RU 937 086
Component: GW-K-CAN TP20 0207
Coding: 002340
VCID: 70EF66C2A3A315C4E8-8024
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO X05 0006
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03003
ROD: EV_Immo_UDS_VDD_RM09.rod
Part No: 6R0 423 156 A
Component: LenkhilfeTRW V275
Coding: 10150
Shop #: WSC 01234
VCID: 2E53B8BAED174334BA-807A
End-------------------------(Elapsed Time: 02:02)--------------------------
No communication to either door control module. These modules also house the window motors.
You could start with having a look at the fuses, otherwise there could be something wrong with either the LIN connection (databus).
lokesh
Post by lokesh »
thank you iichel .
I have checked all the fuses , all are fine . I had also removed the battery negative terminal for 10 min and reconnected but still same issue .
All the power windows are working fine , only the front power windows are working in opposite .
Can you please tell how to check the LIN connection/databus !
Can anything be done using VCDS long coding to resolve the error.
I doubt something has gone wrong with canbus coding while using clone VCP cable few weeks back for led issue as my vehicle displayed 'TRV/trn' in dashboard and the central locking was disabled but the vehicle was running fine with the key and manual locking/unlocking.
Now 'trv/trn' mode and remote locking/unlocking is resolved but the front windows are working in opposite .
Well, the error is intermittent and the only thing they share is the data line.
I would check the wire from the bcm to either door module. Measure continuity end to end with a multimeter. Inspect the rubbers in the door hinges for damage, undo the connectors in the a pillar to check for corrosion and breaks in the wiring.
I'm not familiar enough with the coding of these door modules. Maybe ciclo can have a look at them, he knows a lot about them. But if you haven't changed the coding, I'm hesitant it is the source of your problem
lokesh
Post by lokesh »
Issue is resolved now .. :D
For anyone facing this issue with the below central electronics module :
Coding: 030000
New Coding : 010000
Coding: 030000
New Coding : 010000
:idea: Search for the VCDS autoscan results for your car model .Try to find the exact match with the Part No SW , HW ,component. :roll:
If your codings are different , update the new codes found from the Autoscan and give it a try. :lol:
Thanks iichel ,ciclo .
@ciclo - your replies on the earlier posts made me think for this solution and I hope above method is correct .
zach138
Drives: 1.6 TDI 6R 90HP CAYB
Post by zach138 »
Hello to all.
I'm digging up this thread to ask for your help as I am facing a similar problem with my Polo 6R CAYB 2010 RHD.
I experience intermittent problems with driver's (mainly) and passenger's window: automation is not working quite often and in the same time the windows are running on the wrong way. When I pull the switch, it should close the window but now the window is coming down when I pull the switch.
Any help/advice will be much appreciated!
*I will upload the full VCDS scan asap as I cannot post the log file neither as text nor as code*
