Problem with electric window
gpeixoto109
- Drives: 2013 Polo 6R 1.2TDI
Hello people, I don't know if anyone could help me, I have a problem with my polo 6R.
Two days ago I forgot my lights on during the night, and ran out of battery, and when I boosted the battery and turned the car on, the front electric windows won't start automatic, minutes later tried again and they were working automatically again, but the windows are running on the wrong way. When I pull the switch, it should close the window but now the window is coming down when I pull the switch. Have this problem only with front windows, both driver and passenger window. The rear windows are okay.
Does this happened to anyone here?
Thank you!
Thank you!
Re: Problem with electric window
I don't know what could be the problem. (apart from battery in poor condition)
Try the following:
- Disconnect the battery ground cable for 5 minutes ... before make this it is appropriate that the battery is in good condition (eg. Engine turning on for 20 minutes).
- Reconnect battery.
- Checking.
Note
- To restore the windows automatic mode read the owner's manual.
VCDS autoscan?
In reply to your private message:
Multiple causes can cause battery drain, not necessarily the LEDs that you installed.
Try the following:
- Checking.
Note
VCDS autoscan?
gpeixoto109
VCDS Version: Release 12.12.0
Data version: 20130910
Monday,07,September,2015,12:17:08:62939
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZEY034162
56-Radio -- Status: OK 0000
Address 01: Engine (J0000-CFWA) Labels: 03P-906-021-CFW.clb
Part No SW: 03P 906 021 AJ HW: 03P 907 425 A
Component: R3 1.2 DCM3.7 H10 3316
Revision: 11002002 Serial number:
Coding: 00114014000400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TDI03103P906021AJ 001005
ROD: EV_ECM12TDI03103P906021AJ_VW25.rod
VCID: 70EF364BAB56C89E643-8025
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP90.clb
Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Component: ESP9.0i front H02 0002
Serial number: --------------
Coding: 21DD2485412600C48415246F825300420905
Shop #: WSC 01383 785 00200
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
ROD: EV_Brake1ESP90iBOSCH_AU21.rod
VCID: 8F2DD5B756A837669D9-80DA
2 Faults Found:
0625 - Display for Tire Pressure Monitoring
C1146 02 [008] - Signal Failure
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 13
Reset counter: 166
Mileage: 54434 km
Date: 2024.14.14
Time: 00:00:09
0886 - Control Module for Immobilizer
B1026 29 [008] - Signal Implausible
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 0 km
Date: 2024.14.14
Time: 00:00:00
Address 08: Auto HVAC (J301) Labels: 6R0-820-045.clb
Part No SW: 6R0 820 045 N HW: 6R0 820 045 N
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 3979CB6FB0AC49D693D-806C
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 P HW: 6R0 937 087
Component: BCM PQ25 H+4 H34 0411
Revision: BF034001 Serial number: 0581 168130649
Coding: 7CB02FB808210200003808C07C689CD0F00000FF60860000000000000000
Shop #: WSC 12469 483 00190
VCID: 4A9B84A3E54AD24E0A7-801F
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Coding: 02BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Coding: 02BC30
Subsystem 3 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
Component: E221__MFL-TAS H31 0033
Coding: 020000
Subsystem 4 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Coding: 18BC32
Subsystem 5 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Coding: 18BC32
1 Fault Found:
01179 - Incorrect Key Programming
000 - -
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 126
Mileage: 54434 km
Time Indication: 0
Date: 2024.14.14
Time: 00:17:04
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX01S7TUI
Coding: 00314D
ROD: EV_AirbaVW10BPAVW250_VW24.rod
VCID: 4A9B84A3ED4AD24E0A7-801F
Crash sensor for side airbag; driver side:
Serial number: 3575HRB400I50HLEGGP$
Crash sensor for side airbag; passenger side:
Serial number: 3585HRB405522BUKA946
Crash sensor for side airbag; rear driver side:
Serial number: 3515RRB401A50J2EM8RJ
Crash sensor for side airbag; rear passenger side:
Serial number: 3525RRB401850J2EBQ75
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 861 M HW: 6R0 920 861 M
Component: KOMBI H02 0406
Serial number: 00000017018511
Coding: 140A01
ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01723
ROD: EV_DashBoardUDSJCIPQ25_VN81.rod
VCID: 3F8DA577A68867E6AD9-806A
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H34 0411
Revision: BF034001
Coding: 002200
VCID: F0EFB64B2356489EE43-80A5
Address 25: Immobilizer (J285) Labels: 5K0-920-xxx-25.clb
Component: IMMO H02 0025
Serial number:
ASAM Dataset: EV_ImmobUDSJCIPQ25 A01003
ROD: EV_ImmobUDSJCIPQ25_SK25.rod
VCID: EADBA4230D8AB24EAA7-80BF
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11260
Shop #: WSC 00788
VCID: 306FF64BF7D6889E243-8065
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5M0 035 156 D HW: 5M0 035 156 D
Component: Radio 553 0556
Revision: R0553008 Serial number: VWZ5Z1N0835953
Coding: 0100020102
VCID: 2A5BE423450AF24EEA7-807F
End ---------------------------------------------------------------------
Hello ciclo, here is my auto scan.
it says nothing about the windows.
I recently saw that Spolos has the same problem, did he have something in his vcds autoscan?
2 Faults Found:
Fault Priority: 2
Fault Frequency: 13
Reset counter: 166
Mileage: 54434 km
Date: 2024.14.14
Time: 00:00:09
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 0 km
Date: 2024.14.14
Time: 00:00:00
Revision: 0003SH02
Coding: 02BC30
Coding: 02BC30
Coding: 020000
Coding: 18BC32
Coding: 18BC32
1 Fault Found:
000 - -
Fault Priority: 3
Fault Frequency: 1
Reset counter: 126
Mileage: 54434 km
Time Indication: 0
Date: 2024.14.14
Time: 00:17:04
Coding: 00314D
Coding: 140A01
Revision: BF034001
Coding: 002200
Serial number:
Coding: 11260
Shop #: WSC 00788
Coding: 0100020102
gpeixoto109
Which step do I need to do?
The one bellow channel 001?
First channel 000 then obligatorily the channel 001.
gpeixoto109
That solved my problem with the key remote, but the windows are still the wrong way.
Any solution?
Any solution?
Try these new codings:
Coding: 02BC30 New coding:18BC30
Checking all switches both doors, tell us the result.
gpeixoto109
It worked! You're the best!
thank you!
thank you!
Evo
- Drives: Polo GTI 6C DSG
Hi. I have same problem on my 6C Gti drivers window. I works in reverse.ciclo wrote: Wed Sep 09, 2015 10:25 am Try these new codings:
How do I code the above I cannot find where to do this in vids.
thank you! you rock!
Full and recent autoscan, please.
Evo
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 B HW: 6C0 937 089
Component: BCM PQ26 Hi4R H07 0065
Serial number: 001098082048
Coding: 03101A5042530AFB0BA44080B12F07C810005B0257010000000000000000
ASAM Dataset: EV_BCMA0 004008
ROD: EV_BCMA0_004_VW26.rod
VCID: 2F6C9E1876C9A83E23-807A
Rain Light Recognition Sensor:
Subsystem 1 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S4Y15M02D17H10M50S04
Coding: 0638DD
Drivers Door Control Module:
Subsystem 2 - Part No SW: 6R0 959 802 AT HW: 6R0 959 802 AT Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU006021550371598
Coding: 1800A0
Front Passengers Door Control Module:
Subsystem 3 - Part No SW: 6R0 959 801 BB HW: 6R0 959 801 BB Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 8612
Serial number: KU0KU003021550349051
Coding: 18BC30
Sensor For Anti Theft Alarm System:
Subsystem 4 - Part No SW: 6C0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY1500502AH
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000061712420
Sun Roof:
Subsystem 6 - Part No SW: 6R0 959 591 D HW: 6R0 959 591 D
Component: J245 PS72.403 H03 0004
Serial number: 0000FST00059YYA00000
Coding: 181001
Relative Air Humidity Interior Sender:
Drivers Door Rear Control Module:
Subsystem 8 - Part No SW: 6R0 959 812 N HW: 6R0 959 812 N
Component: J389__TSG_HR 003 8611
Serial number: KU0KU005021550363495
Coding: 1400A0
Passengers Rear Door Control Module:
Subsystem 9 - Part No SW: 6R0 959 811 N HW: 6R0 959 811 N
Component: J388__TSG_HL 003 8611
Serial number: KU0KU006021550373940
Coding: 0400A0
No fault code found.- ciclo
Try these new codings.Evo wrote: Sun Oct 29, 2017 12:06 pmThanks mate!Code: Select all
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-089-V1.clb Part No SW: 6C0 937 089 B HW: 6C0 937 089 Component: BCM PQ26 Hi4R H07 0065 Serial number: 001098082048 Coding: 03101A5042530AFB0BA44080B12F07C810005B0257010000000000000000 Shop #: WSC 00788 648 00255 ASAM Dataset: EV_BCMA0 004008 ROD: EV_BCMA0_004_VW26.rod VCID: 2F6C9E1876C9A83E23-807A Rain Light Recognition Sensor: Subsystem 1 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB Component: RLHS 037 0059 Serial number: S4Y15M02D17H10M50S04 Coding: 0638DD Drivers Door Control Module: Subsystem 2 - Part No SW: 6R0 959 802 AT HW: 6R0 959 802 AT Labels: 6R0-959-802.CLB Component: J386__TSG_FT 003 8612 Serial number: KU0KU006021550371598 Coding: 1800A0 Front Passengers Door Control Module: Subsystem 3 - Part No SW: 6R0 959 801 BB HW: 6R0 959 801 BB Labels: 6R0-959-801.CLB Component: J387__TSG_BT 003 8612 Serial number: KU0KU003021550349051 Coding: 18BC30 Sensor For Anti Theft Alarm System: Subsystem 4 - Part No SW: 6C0 951 171 HW: 5Q0 951 171 Component: Sensor, DWA 005 0315 Serial number: 000000000ZY1500502AH Alarm horn: Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605 Component: Sirene, DWA 004 0311 Serial number: 00000000000061712420 Sun Roof: Subsystem 6 - Part No SW: 6R0 959 591 D HW: 6R0 959 591 D Component: J245 PS72.403 H03 0004 Serial number: 0000FST00059YYA00000 Coding: 181001 Relative Air Humidity Interior Sender: Drivers Door Rear Control Module: Subsystem 8 - Part No SW: 6R0 959 812 N HW: 6R0 959 812 N Component: J389__TSG_HR 003 8611 Serial number: KU0KU005021550363495 Coding: 1400A0 Passengers Rear Door Control Module: Subsystem 9 - Part No SW: 6R0 959 811 N HW: 6R0 959 811 N Component: J388__TSG_HL 003 8611 Serial number: KU0KU006021550373940 Coding: 0400A0 No fault code found.
Coding: 1400A0
Coding: 0400A0
Evo
THANKYOU!!!! perfect!!! good work =)ciclo wrote: Sun Oct 29, 2017 6:25 pmTry these new codings.Evo wrote: Sun Oct 29, 2017 12:06 pmThanks mate!Code: Select all
Coding: 1400A0
Coding: 0400A0
