Polo 6R ABS CODING
habib_123
Drives: Polo 6R 2012 1.2TDI RHD
Re: Polo 6R ABS CODING
Post by habib_123 »
lol. Thank you for all your help. I will try my best. I will try and post pics tomorrow, if it all works.
A separate issue:
Click :arrow: Do you have the ABS coding that some time ago gave you 'belouadi' ? It is a mere curiosity, to make comparisons. It can be important... for me. :twisted:
habib_123
Drives: Polo 6R 2011 1.2TDI RHD :arrow: --- but VIN number --> WVWZZZ6RZCU015153 --> Model Year C --- therefore '12.
Contact: Contact habib_123
habib_123
Post by habib_123 »
I didn't do the settings for the ABS when he gave me the code. i just installed it with the CAN gateway (ticked it) and then went to ABS, Long coding helper and put the code in.
It gave me error 22: Conditions not correct or request sequence error.
(so in my mind, I thought this coding is wrong because it keeps rejecting and giving this error. But now I have a Genuine Ross-Tech HEX+CAN cable, so I'm hoping it will work.
But i'll try and find the code.
habib_123
Post by habib_123 »
:D :D :D
OMG!!! I just noticed you highlighted the car year. The car was registered on 31-12-2011. So i am confused if its 2011/2012.
habib_123
Post by habib_123 »
This is the coding he gave me:
Coding ABS: 210248E3416E02B7842612E782D440411700
habib_123
Post by habib_123 »
But when I put it in I kept getting the error 22 code. So I thought coding is probably wrong.
habib_123
Post by habib_123 »
habib_123
Post by habib_123 »
i tried all the coding. I kept getting the error 22 code. I have no idea what it means. I have uploaded photos. help?
Error 22: I understand that is the way you enter the coding.
Maybe you need to activate the security access before put the coding.
The coding from belouadi it is also based on your VIN number.
Another coding (if you need):
230224E3416E00B7C42624E782D400921300 according to your VIN number and polo 6r from South Africa. (RHD, I guess) http://vwclub.co.za/forum/viewtopic.php ... 9#p1694595
habib_123
Post by habib_123 »
Hi Ciclo,
Can you download a program called Teamviewer so you can connect to my laptop and do it yourself?
habib_123
Post by habib_123 »
UPDATE:
CODING HAS WORKED!!!!!!!!! USED ABOVE CODING AND IT ACCEPTED IT. I put security access in and clicked coding 08 and pasted the code (I did not go into coding helper) and it said code accepted!!!!????
wierd.....
:lol:
habib_123
Post by habib_123 »
I have cleared all DTC's from all modules and i have no errors.
The ABS light is still on even though there is no errors in ABS module....what do I do?
and on the speedo it says:
ERROR:
BRAKES
WORKSHOP!
habib_123
Post by habib_123 »
show us the errors in vcds
did you do the brake adaptation reset as shown?
viewtopic.php?f=56&t=68290#p510097
