exhaust tip for TDi
carmadaaron
KarlM
IIRC its something to do with back pressure. Two pipes increases the pressure and thus limits the power/noise and helps the turbo - I cant remember who told be this so i might not be 100% accurate.carmadaaron wrote:why do diesels have 2 btw? and petrols have 1?
As for a custom zorst you have 2 options
1) a decent custom manufacturer like Longlife can make 'retro' exhaust pipes which curve down. Shrick also do a universal single outlet that curves down, but I'm not sure what the fit and finish will be like on the 9n (it looks the t**s on the MK1 Golf!)
2) Any custom fabricator will cut a professional looking cut out for the muffler to poke through. most off the shelf items will hang under the bodywork though (not a good look)
hope that helps
carmadaaron
carmadaaron
I have one of these sitting in my garage, pretty sure there's no plastic on it tho. Decided not to fit it... so if anyone interested in taking it off me... give me a pm.... saves you having to walk into a Skoda dealerjazzy wrote:...you can tell its plastic.
http://www.tigerstyle.co.uk/poloforum/v ... 28&start=0
