Polo 6R 1600 TDI Team
Re: Polo 6R 1600 TDI Team
You should also tell me what wiring looms you have installed so far so that I can code your new BCM. All without exception.
Post a new autoscan at the same time.
Turbodruk
Drives: Polo 6R 1600 TDI Team
Post by Turbodruk »
Hello !
So far I have installed:
http://www.carsystems.pl/bluetooth-mdi- ... d2034.html
( MDI & Bluetooth wiring harness for 5N0 035 729 A )
http://www.carsystems.pl/vw-microphone- ... id180.html
( Microphone for Telephone )
https://www.x2car.de/Adapter-fuer-VW-Po ... C-Facelift
( Adapter cables for 6C rear lights )
https://www.x2car.de/MFA-Kabelsatz-nach ... VW-Polo-6R
( Cables for retrofitting MFA on stalks & new stalks )
I made a wiring loom for my BCM to work thanks to you and iichell.
And cables for installing MFSW. I drove around with an original Polo MFSW, but I didn't like it at all so I bought the one I'm using now (in the OP).
In the future I would like Coming Home/Leaving Home in combination with automatic lights. Also looking to retrofit a OEM alarm system. Next year I want to try LED headlights from the 6C. This means a new front (R-Line :lol: ) bumper, headlight washer unit, auto leveling unit, "some" cables and ofcourse the LED lights. After that's finished I'm looking to retrofit front OPS and a rearview camera. That will probably mean I'll have to swap my RCD 510 for a RNS 510.
I've got an "old" 6R0953521B from my mom's 1600 TDI DSG, which I retrofitted with MFA. What's the differncee between this and 6R0953507B?
Here's the second autoscan after I programmed the keys.
Odd thing is, when I press the microphone button the steering wheel, I hear nothing. It only mutes the sounds, instead of a nice lady saying "Main Menu". Might have botched a cable behind the radio when I read the fault codes. :roll:
Friday,10,November,2017,18:16:13:51415
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4407.4
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZBY015008   License Plate: TURBODRUK KEYS
Mileage: 153430km-95336mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 2E 44 56 61 77 0B
VIN: WVWZZZ6RZBY015008   Mileage: 153430km-95336miles
56-Radio -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J623-CAYB)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 EP    HW: 03L 906 023 D
   Component: 1,6l R4 CR td H13 9970
   Revision: --H13---    Serial number:
   Coding: 00114034002401080000
   Shop #: WSC 124697 483 00190
   ASAM Dataset: EV_ECM16TDI02103L906023EP 003007
   ROD: EV_ECM16TDI02103L906023EP_003.rod
   VCID: 78A818B3A25FC6B763A-802C
Readiness: 1000 0000
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AJ    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3416E00B7842514E282D900521100
   Shop #: WSC 02069 000 00000
   VCID: 0654664BD86BA047616-8052
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AP.clb
   Part No SW: 6R0 820 045 J    HW: 6R0 820 045 J
   Component: Climatic       25 0660
   Revision: 00 11 25
   VCID: 3536D187F54DFBDFB8C-8060
   Revision: B9080001    Serial number: 0771 116170197
   Coding: 3CB029BF48A10000012807F07D2B1ED14F80610F60860049200000000000
   Shop #: WSC 18752 008 00032
   VCID: 688848F3F27F5637F3A-803C
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 180510 05  54  0403
   Coding: 0605F3
   Subsystem 2 - Part No SW: 6R0 959 801 R    HW: 6R0 959 801 R  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 0912
   Serial number: KU0-KU020.05.1010960
   Coding: 48BC30
   Subsystem 3 - Part No SW: 6R0 959 802 T    HW: 6R0 959 802 T  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 0912
   Serial number: KU0-KU018.05.1011444
   Coding: 48BC30
   Subsystem 4 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C
   Component: E221__MFL-TAS  H31 0033
   Serial number: 0361915
   Coding: 020000
2 Faults Found:
01504 - Bulb for License-Plate Light (X)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 23
                    Reset counter: 0
                    Mileage: 153414 km
                    Time Indication: 0
                    Date: 2017.11.10
                    Time: 10:19:00
03906 - Control Circuit for High Beam Relay
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 153414 km
                    Time Indication: 0
                    Date: 2017.11.10
                    Time: 15:15:52
Address 10: Park/Steer Assist (J446)       Labels:| 6R0-919-475.clb
   Part No SW: 6R0 919 475     HW: 6R0 919 475
   Component: PARKHILFE 4K  H07 0008
   Revision: --------    Serial number: 71391012733298
   Coding: 100001
   ASAM Dataset: EV_VW250ParkiAssis2 S01006
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 7BA207BF9369EDAF0E8-802E
   Part No SW: 6R0 959 655 C    HW: 6R0 959 655 C
   Component: VW10Airbag00L H09 0018
   Revision: --------    Serial number: 003DW00G103P
   Coding: 00304C
   VCID: 42DCBA5BB4035C670DE-8016
   Serial number: 3572SRB40000B8408ACB
   Serial number: 3582SRB40000B8185282
   Serial number: 3516GRB401R9OICD64ET
   Serial number: 3526GRB401T9OICCSB69
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 6R0 920 870 A    HW: 6R0 920 870 A
   Component: KOMBI         H04 0709
   Coding: 540800
   Shop #: WSC 00788 648 00255
   VCID: 3332EF9FFBB9E5EF968-8066
   Revision: B9080001
   Coding: 002020
   Component: IMMO          H04 0709
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6A8C32FBECF36427E5E-803E
Address 2E: Media Player 3
Cannot be reached
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 00788
   VCID: 2F3AE3EF1E51C10FF20-807A
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190 B    HW: 5K0 035 190 B
   Component: Radio RCD510  005 0236
   Revision: 00000001    Serial number: VWZ1Z3P0376022
   Coding: 01000401020001
   Shop #: WSC 00020 790 12345
   VCID: 24101CC34ED772571F2-8070
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0736
   Coding: 030B1A5A
   Shop #: WSC 12345 123 12345
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790237207
Address 77: Telephone (J412)       Labels:| 5N0-035-729.clb
   Part No SW: 5N0 035 729 A    HW: 5N0 035 729 A
   Component: TELEFON       H05 0315
   Revision: 1B001001    Serial number: 00007665485869
   Coding: 0810030080010110
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_UHVUMI 001007
   ROD: EV_UHVUMI.rod
   VCID: 2E04FEEB109BC807F96-807A
2 Faults Found:
9457426 - Left audio channel for speech/telephone
          B104F 12 [009] - Short to GND
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 153414 km
                    Date: 2017.11.10
                    Time: 10:19:50
9457170 - Right audio channel for speech/telephone
          B104E 12 [009] - Short to GND
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 153414 km
                    Date: 2017.11.10
                    Time: 10:19:50
End----------(Elapsed Time: 01:30, VBatt start/end: 12.4V/12.4V)-----------
Thank you for your time, I can't thank you enough! :D
I'm close to Nordhorn next week and I got a spare auto light wire loom. If you are interested we can have a look
Turbodruk
Post by Turbodruk »
This is what I like about this forum in general. Having a spare wire loom laying around :lol:
I’m interested, I’ll pm you some details and your preferred method of paying you and where we’ll meet up.
Turbodruk wrote: Fri Nov 10, 2017 6:10 pm Here's the second autoscan after I programmed the keys.
There are three addresses where this should be coded:
- BCM
- Radio
- Phone
Find the coding combination that suits your needs.
Your MDI/Bluetooth unit is unknown to me in terms of coding and installation.
When I had installed the same steering wheel model that you currently have I coded it for the mute function.
Two reasons:
- Very useful.
- My rns must be the dumbest of those that were made ever, it always ends up saying "repeat please" in the last instruction after 3-5 min speeching with "it". :lol:
6R0953521B... from factory with ring included.
6R0953507B... Stalks only.
New 7E0 BCM coding, without automatic lights wiring installed, H7 headlights.
3CB029BF48A10000012805906C2B1ED15F80412F60840040200000030000
Report the results with a new autoscan. Some faults will be erased, but new ones may arise due to poor installation, we'll try to correct them.
Remember that you must delete all the DTCs at least twice before making a new Autoscan, which is the one you should post.
Explain us the reason for this Gateway coding:
002020
Byte2 Bit5 :?:
Turbodruk
Post by Turbodruk »
Thank you Ciclo. I will try this as soon as I am home, currently at work, as I don’t drive around with a VCdS cable. :lol:
Turbodruk
Post by Turbodruk »
Hi!
Ran the VCDS autscan, erased DTC's 2 times, some errors went away, others came around.
As you can see, there is a fault in the interior lighting, most of the buttons don't light up anymore. I also recognized you disabled "Dauerfahrlicht", my headlight and taillights are now off in position "0" on the light switch. :o
Like I told you, I installed a MFSW, and the illumination signal for the steering wheel I "highjacked" from the lightswitch with this nifty little thing:
http://www.elektronica-shop.nl/contents ... lklem.html
Could that be a reason for the errors?
Or the factory installed Dauerfahrlicht?
Here is the autoscan
Saturday,11,November,2017,19:19:36:51415
www.Ross-Tech.com
VIN: WVWZZZ6RZBY015008   License Plate: TURBODRUKNEWBCMCODING
Mileage: 153480km-95368mi   Repair Order:
VIN: WVWZZZ6RZBY015008   Mileage: 153480km-95368miles
Readiness: 1110 1000
   Revision: --------
   Revision: 00 11 25
   Coding: 3CB029BF48A10000012805906C2B1ED15F80412F60840040200000030000
   Coding: 0605F3
   Coding: 48BC30
   Coding: 48BC30
   Coding: 020000
3 Faults Found:
02745 - Bulb for Daytime Running Light; Left
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 153487 km
                    Time Indication: 0
                    Date: 2017.11.11
                    Time: 19:16:38
02746 - Bulb for Daytime Running Light; Right
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 153487 km
                    Time Indication: 0
                    Date: 2017.11.11
                    Time: 19:16:38
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 41
                    Mileage: 153487 km
                    Time Indication: 0
                    Date: 2017.11.11
                    Time: 19:16:57
   Coding: 100001
   Coding: 00304C
   Coding: 540800
   Revision: B9080001
   Coding: 002200
   Serial number:
Cannot be reached
   Coding: 11230
   Shop #: WSC 00788
   Coding: 030B1A5A
   ROD: EV_UHVUMI.rod
2 Faults Found:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 153487 km
                    Date: 2017.11.11
                    Time: 19:16:39
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 153487 km
                    Date: 2017.11.11
                    Time: 19:16:39
End----------(Elapsed Time: 01:15, VBatt start/end: 12.4V/12.4V)-----------
EDIT:
I put the Gateway coding to 002200 again, I think I played with VCDS around too much... :lol:
Turbodruk wrote: Sat Nov 11, 2017 6:31 pm I also recognized you disabled "Dauerfahrlicht", my headlight and taillights are now off in position "0" on the light switch. :o
AFAIK this option is only legal for the Scandinavian countries.
But if you want to activate it ... do it ... :)
NO.
You have to install the wire that reaches T73b/1 in T73b/4 in BCM white connector, or install a 1.0mm2 new wire from T6/3 Dimmer connector to T73b/4 (isolate original terminals T6/3 and T73b/1).
The second option is better. :wink:
... ... and all the interior lighting of switches/etc will work perfectly.
Turbodruk wrote: Sat Nov 11, 2017 6:31 pm EDIT:
:lol: ... :wink:
Edit:
... to solve the two faults of DRLs, we will wait for your answer about the "Dauerfahrlicht".
you have an unusual coding for it ... that I preferred not to touch ... better we await your answer to know what your wishes are about the daytime running lights.
Turbodruk
Post by Turbodruk »
Thank you for the clarification Ciclo. The way the lights work now is no problem at all, as I want to install an auto light switch with personal help from iichel. :lol:
Forgive me for my many questions, but what connector would I use with the 1mm2 cable?
https://www.a4-freunde.com/showwiki.php ... zu+gehoert
The dauerlicht uses H7 and was setup this way from the factory if I recall correctly. Could be wrong though.
Cheers :mrgreen:
T73a/4 is a MCP1,5. I'll give you some terminals on Friday. I'll have to look where we meet, depending on the great Dutch weather.
Well, the terminals are JPT for the Dimmer connector and MCP 1.5 for T73b/4, as iichel has said.
iichel can/could include this wire in your wiring for automatic lights. I would do it . :lol:
This way, this wiring would be perfect for your 6R.
By the way, your new RLS coding, 06302D.
Shortly I explain the reason for your BCM coding from factory and your TFL (DRLs). Easy (I'm editing a picture).
hey ciclo, i have this information relating the the Dauerfahrlicht for byte 23 in the BCM:
byte 2 and 3: 10 = DRL over dip beam, 11 = DRL over pos lights, 00 = DRL over DRL, 01 = DRL over cornering lights
Yes, this is absolutely clear iichel, but the important thing is to know why a Bluemotion has an unprecedented configuration in the DRLs.
Let's go with it:
To date and agreement with all possible configurations for all European countries, all 6R Bluemotion with H7 headlights had the DRLs included/beside the fog lamps and controlled by the BCM. But in the German 6R of Turbodruk this does not happen.
Being a "B" MY and the way in which the 6R were sold and configured in the German VW configurator, it may even be normal for this to happen.
This can be checked in the German configurator for the VWs, ... you have to pay for each screw ...
Therefore, Turbodruk, enter this BCM coding and everything solved for your TFL.
3CB029BF48A10000012805906C2B1ED15F80412F60840048200000030000
All this must be taken into account in the future if you install Bixenon headlights or LED headlights. :wink:
it's a bit offtopic, but yesterday I had the same configuration, owner came for some VCDS changes. 2014 Polo 6R 1.2 TSI Bluemotion Technologies in Highline spec (H7 headlights) with dauerfahrlicht.
This is how it arrived (aftermarket radio)
Saturday,11,November,2017,11:42:42:62066
VCDS Version: 17.10.0.2
Data version: 20171106 DS283.3
www.Ross-Tech.com
Dealer/Shop Name: iichel
Workshop Code: 321 54321 054321
VIN: WVWZZZ6RZEYxxxxxx   License Plate:
Mileage: 124880km-77596mi   Repair Order:
Chassis Type: 6R-VW25 (6N0)
VIN: WVWZZZ6RZEYxxxxxx   Mileage: 124880km-77596miles
2E-Media Player 3 -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine (J623-CBZC)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 FJ    HW: 03F 907 309 K
   Component: SIMOS10.23AH10 5465
   Revision: --H10---    Serial number:
   Coding: 001100B6202401080000
   ASAM Dataset: EV_ECM12TFS02103F906070FJ 004008
   ROD: EV_ECM12TFS02103F906070FP.rod
   VCID: 6FE7D5C3B66F7E52553-803A
Readiness: 0000 0000
   Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0003
   Serial number: --------------
   Coding: 21DD2885212B00C484191471845300500905
   Shop #: WSC 01383 785 00200
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   VCID: 0F27B543D6AF1E52353-805A
   Serial number: 08011404651096
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF9F887E10507DACE5-802A
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
   Component: Man AC        H02 0202
   Revision: 0003SH02
   VCID: 39732B9BB0ABE0E2BB7-806C
Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
   Part No SW: 7H0 937 090 B    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H74 BCM PQ25 Max4 H74 07120712
   Revision: B9074001    Serial number: 0571 353131707
   Coding: 7AB02B3F48A90000013009306D2B0ED80FC0410F7E840048A00000020000
   VCID: 2D5B0FCB74E34C4227F-8078
   Component: RLS 281113 05
   Coding: 03302D
   Subsystem 2 - Part No: 6R0 959 801 AT  Labels: 6R0-959-801.CLB
   Coding: 0400A0
   Subsystem 3 - Part No: 6R0 959 802 BE  Labels: 6R0-959-802.CLB
   Coding: 1400A0
   Subsystem 4 - Part No: 6R0 959 811 N
   Component: J388__TSG_HL
   Coding: 0400A0
   Subsystem 5 - Part No: 6R0 959 812 N
   Component: J389__TSG_HR
   Coding: 1400A0
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47331336102456
   Coding: 108001
   VCID: 3E793887A185C7DA8E5-806A
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01ZYCCH
   Coding: 00314D
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4A916457ED4D7B7A22D-801E
   Serial number: 3575HRB401050NTO9154
   Serial number: 3585HRB405H25BG0CGJB
   Serial number: 3515RRB400O50RN0P15L
   Serial number: 3525RRB401G50R5MJHG/
   Part No SW: 6R0 920 860 M    HW: 6R0 920 860 M
   Coding: 140801
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H74 0712
   Revision: B9074001
   Coding: 002200
   VCID: 70E5D6BFA35161AA4C9-8024
1 Fault Found:
01304 - Radio
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 22
                    Mileage: 122527 km
                    Time Indication: 0
                    Date: 2017.09.14
                    Time: 16:02:15
   Serial number:
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AD1C4D78D8D9B7A02D-803E
   Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Component: SG EXT.PLAYER H19 0770
   Revision: A1001003    Serial number: 7665648217
   Coding: 010100
   VCID: 2B5F01D34AF7427239B-807E
1 Fault Found:
01304 - Radio
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 22
                    Mileage: 0 km
                    Time Indication: 0
   Part No: 6R0 423 156 C
   Component: LenkhilfeTRW        V278
   Coding: 11250
   Shop #: WSC 00788
   VCID: 306516BFF7D121AA0C9-8064
Address 56: Radio
Cannot be reached
   Part No SW: 7H0 907 534     HW: 7H0 937 090
   Component: Batt.regelung H74 0712
   Coding: 032B7A64
   VCID: 6BDFC1D38A77827279B-803E
   Subsystem 1 - Part No SW: 6R0 915 181 E    HW: 6R0 915 181 E
   Component: J367-BDM  H08 0181
   Serial number: 50310509412031393988
End-------------------------(Elapsed Time: 03:09)--------------------------
I was also bit surprised, but there were no DRLs in the foglight units.
