Polo 6R 1600 TDI Team
Turbodruk
Drives: Polo 6R 1600 TDI Team
Post by Turbodruk »
Hi all!
After lurking for some months I decided to finally make an account here. I’ve been active for about a month on MyPolo forums over in the Netherlands. I used to drive a 9N3 Comfortline but I sold that. Now I drive a 2010 66kw 1600 TDI Polo 6R Team Comfortline.
Things I have done so far:
Interior:
Black headliner
Leather door interiors
Leather arm rest
Leather shifter knob
GTI handbrake
Leather / Alcantara seats
Black glossy trim in interior
RCD510 instead of RCD310
MDI and Bluetooth controle module with microphone
Skoda Fabia instrument cluster
Audi A1 footrest
VW sport pedals
Glove box that wasn’t damaged
Led interior lights
Mfa retrofit
Mfsw retrofit (currently not working on the right side)
6C central locking button
Chrome window switch and mirror adjustment knob
Sunglasses storage in headliner
Exterior:
Painted lower grilles black
6C R-Line grille
6C GTI taillights
Osram Cool Blue Intense
H&R 35/55mm springs
Black shark fin dummy (OEM)
Black cap for cooling fluid
Black brake fluid cap
R8 oil cap
Things I want to do:
R-Line bumper kit
17 inch rims
Merge Skoda cluster with one from a Toledo (I don’t like Skodas font)
Toledo gas struts for the boot
Gas struts for the hood
PDC front
Coming Home/Leaving Home
TPMS
.... might do OEM Xenon or 6C LED .... so...
SWRA
LWR
etc...
But my main priority is to get the mfsw to work on the right side. I have no clue on how to get it to work, the buttons aren’t illuminated either.
I even tried a BCM swap from a T6, 7E0937090Z9A, but I couldn’t get it to work because I’m an idiot :oops:. Made the wires because I have an external CAN gateway, and could access it in VCDS, but it gave errors because it couldn’t reach the IC. I stopped at this point. If anyone knows how I can either get the BCM to work or the right side of the steering wheel, I am forever greatfull.
Anyways, here are some photos
(Photo with old cluster, now I have this one:)
Shoutout to @ciclo and @iichel for being so active and my main source of inspiration!
Re: Polo 6R 1600 TDI Team
Sunglasses storage in the head lining, is that the old Golf version that replaces a grab handle? If not which type is it? Also, has anyone checked out the interior lights cluster on the latest Polo to see if it sunglasses storage - built into the interior lights cluster, will fit a 6R and 6C Polo?
I think it goes in the roof handle:
https://www.aliexpress.com/item/OEM-for ... ed11d4702d
peter_dk25
Drives: Blue GT
Post by peter_dk25 »
iichel wrote: Wed Oct 25, 2017 8:43 pm I think it goes in the roof handle:
Spot on - have it in my Blue GT
Turbodruk wrote: Tue Oct 24, 2017 12:53 am
Hi Turbodruk, welcome.
Imagine you do this for your new 7E0 BCM.
What would happen?
Try it. :wink:
Apart, you have to carry some CAN lines that arrive at your old Gateway to the new 7E0 BCM (with internal gateway), also the LIN.
Something like this:
https://drive.google.com/file/d/0B2nv91 ... 8zdGc/view
This is the idea, but you should visually check and point to the exact numbering of the wires on both connectors (white BCM, red Gateway) with pen and paper. :)
Therefore, first install the CAN lines for IC, and check which CAN lines reach your white BCM connector (powertrain, comfort, diagnosis), then it's as simple as running the missing lines on your BCM white connector from the red connector on your old Gateway to the BCM white connector (including the LIN).
From the red connector of the old Gateway it is only necessary that you take out the required lines/wires, the rest of wires you have to leave installed in this connector, this way they will be perfectly isolated. Remove the Old Gateway forever and install the new 7E0 BCM.
Once completed, it will be necessary to correctly code the Gateway and BCM.
This will not be a problem if you post an autoscan. :wink:
We've been tryiing a little on the Dutch MyPolo forum but without succes. I agree with ciclo that it should not be very difficult but it's a delicate job.
Yes that one works okay, I have fitted that to my wife's Polo - and her previous Polo 9N back in 2003, I was more interested in finding out if the sunglasses storage unit from the centre roof mounted console in the next Polo will fit the 6C Polo.
Turbodruk
Post by Turbodruk »
Thanks for all the replies!
I think I seem to know what went wrong, I used pin 47 instead of 57 on the B connector on the BCM, so that's probably why my IC didn't get recognized. Pin 47 is for CC, which I pinned out, and when it didn't was successfull I put the old BCM back and didn't have CC. So I put that one back. :)
These are the other cables that I connected, which seemed to work because I could acces the new BCM in VCDS.
T73b/18 -> powertrain low T20/pin 6
T73b/19 -> powertrain high T20/pin 16
T73b/22 -> diagnostics low T20/pin 9
T73b/23 -> diagnostics high T20/pin 19
T73b/37 -> LIN T20/12
I do have a few questions. I seem to have disabled the factory mode on the BCM, yes shame one me, but does it matter? Will I still be able to program my transponder keys?
What kind of crimping pliers do you use? I had a Knipex MQS crimping tool, but I sent that back because I coulnd't justify the price of 240 euro's.
I currently use VCDS 12.12 clone cable, yes shame again. Will I need a genuine RossTech cable to fully program my new BCM?
Here is the VCDS autoscan :)
Tuesday,01,October,2013,23:30:03:40973
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVWZZZ6RZBY015008   License Plate: TURBODRUK
Chassis Type: 6R (6R0)
Scan: 01 03 08 09 10 15 17 19 25 2E 44 56 61 77
Address 01: Engine (J623-CAYB)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 EP    HW: 03L 906 023 D
   Component: 1,6l R4 CR td H13 9970
   Revision: --H13---    Serial number:
   Coding: 00114034002401080000
   Shop #: WSC 124697 483 00190
   ASAM Dataset: EV_ECM16TDI02103L906023EP 003007
   ROD: EV_ECM16TDI02103L906023EP_VW25.rod
   VCID: 78FF0E62C37346DEAC3-802D
Readiness: 1000 0000
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AJ    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3416E00B7842514E282D900521100
   Shop #: WSC 02069 000 00000
   VCID: 8603F09A3587A02E2EF-80D3
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045.clb
   Part No SW: 6R0 820 045 J    HW: 6R0 820 045 J
   Component: Climatic       25 0660
   Revision: 00 11 25
   VCID: 3561C7569CE17BB6775-8060
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 6R0 937 088 B    HW: 6R0 937 088
   Component: BCM PQ25 Re4  H46 0321
   Revision: BU046001    Serial number: 0328 151100250
   Coding: 3CB029BF48A10000012807F07D2B1ED1CF80610F7E860049200000000000
   Shop #: WSC 12469 483 00190
   VCID: 3D71DF76A4D1A3F6BF5-8068
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 180510 05  54  0403
   Coding: 0005F3
   Subsystem 2 - Part No SW: 6R0 959 801 R    HW: 6R0 959 801 R  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 0912
   Coding: 48BC30
   Subsystem 3 - Part No SW: 6R0 959 802 T    HW: 6R0 959 802 T
   Component: J387__TSG_BT  006 0912
   Coding: 48BC30
   Subsystem 4 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
   Component: E221__MFL-TAS  H09 0013
   Coding: 020000
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475     HW: 6R0 919 475
   Component: PARKHILFE 4K  H07 0008
   Revision: --------    Serial number: 71391012733298
   Coding: 100001
   ASAM Dataset: EV_VW250ParkiAssis2 S01006
   ROD: EV_VW250ParkiAssis2.rod
   VCID: FBF5916E7245EDC6411-80AE
   Part No SW: 6R0 959 655 C    HW: 6R0 959 655 C
   Component: VW10Airbag00L H09 0018
   Revision: --------    Serial number: 003DW00G103P
   Coding: 00304C
   ROD: EV_AirbaVW10BPAVW250_VW24.rod
   VCID: 428BAC8AD52FDC0EC27-8017
   Crash sensor for side airbag; driver side:
   Serial number: 3572SRB40000B8408ACB
   Crash sensor for side airbag; passenger side:
   Serial number: 3582SRB40000B8185282
   Crash sensor for side airbag; rear driver side:
   Serial number: 3516GRB401R9OICD64ET
   Crash sensor for side airbag; rear passenger side:
   Serial number: 3526GRB401T9OICCSB69
   Part No SW: 6R0 920 870 A    HW: 6R0 920 870 A
   Component: KOMBI         H04 0709
   Coding: 540800
   Shop #: WSC 00788 648 00255
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: 3365F94E9A956586591-8066
Address 19: CAN Gateway        Labels: 6R0-907-530-V1.clb
   Part No SW: 6R0 907 530 B    HW: 1K0 907 951
   Component: J533  Gateway   H28 0020
   Revision:   H28       Serial number: 190510F1000173
   Coding: 7D231F00080000000000
   Shop #: WSC 46012 001 104857
   VCID: 326BFC4AAD8F6C8E527-8067
   Component: IMMO          H04 0709
   Serial number:
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
   VCID: EADBA42A0DDF644EAA7-80BF
Address 2E: Media Player 3
Cannot be reached
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 00788
   VCID: 2F6DF53EEABD41663D9-807A
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190 B    HW: 5K0 035 190 B
   Component: Radio RCD510  005 0236
   Revision: 00000001    Serial number: VWZ1Z3P0376022
   Coding: 05000401020001
   Shop #: WSC 00020 790 12345
   VCID: 24470A12277BF23ED0B-8071
1 Fault Found:
03138 - Input AUX IN
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 152521 km
                    Time Indication: 0
                    Date: 2018.14.12
                    Time: 21:45:16
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 6R0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H28 0020
   Coding: 030B1A5A
   VCID: F4E7BA52571BA2BE00B-80A1
   Component: J367-BDM  H07 0125
Address 77: Telephone (J412)       Labels: None
   Part No SW: 5N0 035 729 A    HW: 5N0 035 729 A
   Component: TELEFON       H05 0315
   Revision: 1B001001    Serial number: 00007665485869
   Coding: 0A10030080010110
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_UHVUMI 001007
   ROD: EV_UHVUMI_VW25.rod
   VCID: 2E53E83A71B7486E36F-807B
End   ---------------------------------------------------------------------
Turbodruk wrote: Thu Oct 26, 2017 11:20 pm Thanks for all the replies!
Those who never do anything never make mistakes. :wink:
T73b/18 -> powertrain low T20/pin 6 OK...
T73b/19 -> powertrain high T20/pin 16 OK...
T73b/22 -> diagnostics low T20/pin 9 OK
T73b/23 -> diagnostics high T20/pin 19 OK
T73b/37 -> LIN T20/12 OK
I do have a few questions. I seem to have disabled the factory mode on the BCM, yes shame one me, but does it matter? No. Will I still be able to program my transponder keys? Yes, no problem at all.
Japanese and Chinese crimping tools. Certain skills and experience are needed for the chinese tools... :lol:
For example
http://www.engineer.jp/en/products/pa09e.html (eBay)
I currently use VCDS 12.12 clone cable, yes shame again. Will I need a genuine RossTech cable to fully program my new BCM? Yes, it is especially recommended for these installations (DIY).
The autoscan that you have post is perfect, now we need another one with 7E0 BCM installed. (when possible, no hurry... :))
hahaha www.watbenjedan.nl :mrgreen:
no just kidding, good to hear you're continuing! curious to see the result! you are in good hands here.
Turbodruk
Post by Turbodruk »
iichel wrote: Fri Oct 27, 2017 9:27 am
Oh please! :oops:
Do I need to remind you it was you who stated pin 47 over at MyPolo? :twisted:
All jokes aside, I’m looking forward to this project, and I am sure I will succeed (with a little help)
Thanks ciclo for your reply, I will buy a RossTech cable and Japanese/Chinese pliers.
Cheers!
Turbodruk
Post by Turbodruk »
Hello !
I've managed to get the BCM to work, evreything works, except for two things. :oops:
Central locking doesn't work, I have to program the keys. Whatever I try within Adress 09 -> Adaptation -> Channel 1, doesn't seem to work.
Also, the right side of my steering wheel doesn't work, it's not lit up and it won't respond to any input.
Here's an autoscan and a bonus pic which I've done earlier this week. I merged the plates and needles from a Toledo cluster with my Fabia cluster. Way better font, and red needles (they look a little pink here)
Thursday,09,November,2017,18:18:57:51415
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4407.4
Data version: 20170721 DS276.2
www.Ross-Tech.com
Mileage: 153410km-95324mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 2E 44 56 61 77 0B
VIN: WVWZZZ6RZBY015008   Mileage: 153410km-95324miles
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J623-CAYB)       Labels:. 03L-906-023-CAY.clb
   ROD: EV_ECM16TDI02103L906023EP_003.rod
   VCID: 78A818B3A25FC6B763A-802C
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Revision: --------
   VCID: 0654664BD86BA047616-8052
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AP.clb
   Revision: 00 11 25
   VCID: 3536D187F54DFBDFB8C-8060
   Revision: B9080001    Serial number: 0771 116170197
   Coding: 3CB029BF48A10000012807F07D2B1ED14F80610F60860049200000000000
   Shop #: WSC 18752 008 00032
   VCID: 688848F3F27F5637F3A-803C
   Coding: 0605F3
   Serial number: KU0-KU020.05.1010960
   Coding: 48BC30
   Subsystem 3 - Part No SW: 6R0 959 802 T    HW: 6R0 959 802 T  Labels: 6R0-959-802.CLB
   Serial number: KU0-KU018.05.1011444
   Coding: 48BC30
   Subsystem 4 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C
   Component: E221__MFL-TAS  H31 0033
   Serial number: 0361915
   Coding: 020000
2 Faults Found:
01504 - Bulb for License-Plate Light (X)
            010 - Open or Short to Plus - Intermittent
                    Fault Status: 00101010
                    Fault Priority: 3
                    Fault Frequency: 15
                    Reset counter: 40
                    Mileage: 153393 km
                    Time Indication: 0
                    Date: 2017.11.09
                    Time: 00:58:04
03906 - Control Circuit for High Beam Relay
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 153393 km
                    Time Indication: 0
                    Date: 2017.11.09
                    Time: 17:05:52
Address 10: Park/Steer Assist (J446)       Labels:| 6R0-919-475.clb
   Coding: 100001
   VCID: 7BA207BF9369EDAF0E8-802E
   Coding: 00304C
   VCID: 42DCBA5BB4035C670DE-8016
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Coding: 540800
   VCID: 3332EF9FFBB9E5EF968-8066
   Revision: B9080001
   Coding: 002020
   Serial number:
   VCID: 6A8C32FBECF36427E5E-803E
Cannot be reached
   Coding: 11230
   Shop #: WSC 00788
   VCID: 2F3AE3EF1E51C10FF20-807A
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   VCID: 24101CC34ED772571F2-8070
1 Fault Found:
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 153393 km
                    Time Indication: 0
                    Date: 2017.11.09
                    Time: 00:58:09
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0736
   Coding: 030B1A5A
   Shop #: WSC 12345 123 12345
   Serial number: 00000000002790237207
Address 77: Telephone (J412)       Labels:| 5N0-035-729.clb
   Coding: 0810030080010110
   ROD: EV_UHVUMI.rod
   VCID: 2E04FEEB109BC807F96-807A
1 Fault Found:
9457426 - Left audio channel for speech/telephone
          B104F 12 [009] - Short to GND
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 153393 km
                    Date: 2017.11.09
                    Time: 00:58:05
End----------(Elapsed Time: 01:29, VBatt start/end: 12.5V/12.5V)-----------
Turbodruk
Post by Turbodruk »
I am so sorry, I managed to program the keys with no hiccups. I was conviced I needed to put the number of the amount of keys I wanted to program, not 0.
I was also thinking, I first retrofitted the MFA with the buttons on the stalk, before I fitted the MFSW. Would it matter that I remove the stalks and place the original stalks back?
I ran a second autoscan with the keys programmed but no new errors occured.
Thank you Master Ciclo! :lol:
Turbodruk wrote: Fri Nov 10, 2017 9:39 am I was also thinking, I first retrofitted the MFA with the buttons on the stalk, before I fitted the MFSW. Would it matter that I remove the stalks and place the original stalks back?
You should do it.
Image :arrow: viewtopic.php?f=56&t=58703&start=1080#p496280 :lol:
