Polo 6R MFSW problem: right buttons not working!
Re: Polo 6R MFSW problem: right buttons not working!
maxym wrote: Wed Jan 30, 2019 10:24 am
ciclo wrote: Wed Jan 30, 2019 7:56 am I don't think BCM is the problem.
What will happen if you replace 540800 by 140800 coding in Address 17: Instruments (J285)?
Bit 3(Multifunction-Function-Display active/installed shouldn't be checked(08 vs 0A)? Maybe that is the cause? 54 vs 14 is Japan vs Other the World? :shock:
:wink:
Yes
It was checked from the beginning, it should work anyway.
Jay-Jay wrote: Wed Jan 30, 2019 11:58 am Well, I tried modiying the coding from "54" to "14", but it didn't fixed the problem.
What if there is a cable missing from BCM to Instrument Cluster?
The steering button control unit communicate with the BCM, but the BCM cannot transfer the signal to the cluster, because a single cable is missing. Could it be possible?
Inviato dal mio MHA-L09 utilizzando Tapatalk
No, MFSW LIN -- BCM/Gateway -- CAN lines IC (powertrain in this case).
Wires only are used with Trip computer on stalk.
The last attempt for this weird problem, 020000 (MFSW coding)
I suppose this SW with paddles for DSG was very cheap. Try with other different buttons (without DSG paddles :)).
Jay-Jay
Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
Post by Jay-Jay »
We tried another MFSW without DSG paddles and right buttons didn't work anyway...
I'll try the coding you suggest and I'll let you know.
Jay-Jay
Post by Jay-Jay »
I tried the last coding but it is rejected.
I honestly don't know what else to do...[emoji20]
I don't have any other suggestions regarding this MFSW buttons issue either, maybe someone can contribute something else.
An unrelated question, have you experienced any problems when modifying the engine coding (to GTI engine coding?) of your 6R to be accepted the ABS system coding for front 288mm discs?
Any advice related to this matter is welcome. TIA
Jay-Jay
Post by Jay-Jay »
I thank you so much anyway for your help.
Maybe the cluster has a weird software which doesn't support right button on the steering wheel. In any case, I guess my friend will have to live with that.
Regarding the ABS coding, no, I hadn't experienced any problem at all! All works perfectly.
Jay-Jay wrote: Thu Jan 31, 2019 8:43 pm Regarding the ABS coding, no, I hadn't experienced any problem at all! All works perfectly.
Ok, Thank you very much Jay-Jay.
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
hi, any update or further development on this? i have exactly one friend with similar issue. its 6R 1.2tsi cbzb 2013 model year
hi benzinkopf
Send me the autoscan by email, I'd like to take a look at the units.
benzinkopf
thanks my friend. i will send his autoscan soon. [emoji1362]
Jay-Jay
Post by Jay-Jay »
If the problem is the same of my friend's car, could you share it here too, please?
It be could be useful, if you figure it out.
benzinkopf
Jay-Jay wrote:If the problem is the same of my friend's car, could you share it here too, please?
sure. will do. thats why we are all here! but since its a friends car, its not going to be fast.
Jay-Jay
Post by Jay-Jay »
Thank you in advance!
I really hope we'll find a solution! :)
SeanYang0831
Drives: 2012 model 6R 1.4
Post by SeanYang0831 »
I have same problem, and it was not show on auto scan(MFSW option check in 09 BCM and 17 Instruments).
Im not sure that could cause deactivate Right-side buttons?
