Polo 6R MFSW problem: right buttons not working!
Jay-Jay
Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
Post by Jay-Jay »
Hi everybody,
I've just helped a friend installing a MFSW on his Polo 6R ComfortLine MY2010, but there is a very strange problem.
Left (Radio) buttons work perfectly.
Right (MFA) buttons don't work.
We checked many times all connections and BCM coding with VCDS: all is correct.
We swapped the steering column combi switch, installing the one with right MFA buttons and they work. Then we reinstalled the one without right buttons, to avoid any conflict with the right buttons on the steering wheel.
We also tried this MFSW on another Polo 6R and ALL the buttons work perfectly, so it seems to be a problem related to my friend's specific car.
This is the AutoScan of his Polo:
Saturday,19,January,2019,18:11:57:00007
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 18.9.0.2
Data version: 20180927 DS296.0
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44
Address 01: Engine (J623-CAYA)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 E    HW: 03L 906 023 D
   Component: R4 1.6l TDI   H13 9978
   Revision: --H13---    Serial number:
   Coding: 00114014000400080000
   Shop #: WSC 124697 483 00190
   ASAM Dataset: EV_ECM16TDI02103L906023E 003016
   ROD: EV_ECM16TDI02103L906023AH_003.rod
   VCID: 285F4EA153F31C0ABD-807C
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AF    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0005
   Revision: --------
   Coding: 210224E3417400B6842D24EB82D400421700
   Shop #: WSC 12345 123 12345
   VCID: 020B3C09990F165AC3-8056
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AP.clb
   Part No SW: 6R0 820 045 J    HW: 6R0 820 045 J
   Component: Climatic       25 0660
   Revision: 00 11 25
   VCID: 356197D59C4171E236-8060
   Part No SW: 6R0 937 087 D    HW: 6R0 937 087 D
   Component: BCM PQ25 H+4  H46 0207
   Revision: BF046001    Serial number: 0147 115100660
   Coding: 3CB02BBF08A10000003800007C2B9CD00000410F60860000200000000000
   VCID: 3E7388F9A977B2BAE7-806A
   Subsystem 1 - Part No SW: 6R0 959 801 R    HW: 6R0 959 801 R  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 0903
   Serial number: KU0-KU009.04.1012951
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 802 T    HW: 6R0 959 802 T  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 0902
   Serial number: KU0-KU007.04.1012302
   Coding: 08BC30
   Subsystem 3 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H05 0010
   Serial number: 0023619
   Coding: 830000
   Subsystem 4 - Part No SW: 6R0 959 811 F    HW: 6R0 959 811 F
   Component: J388__TSG_HL  006 0902
   Serial number: KU0-KU014.04.1012980
   Coding: 08BC32
   Subsystem 5 - Part No SW: 6R0 959 812 F    HW: 6R0 959 812 F
   Component: J389__TSG_HR  006 0902
   Serial number: KU0-KU016.04.1013383
   Coding: 08BC32
   Component: VW10Airbag00G H08 0020
   Revision: --------    Serial number: 003GX001KC98
   Coding: 003047
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4A9BD429EDBF0E1A4B-801E
   Serial number: 3572SRB40000B3C8A0CE
   Serial number: 3582SRB40000B3C8A0BE
   Serial number: 3515RRB405J6DUG6D84V
   Serial number: 3525RRB405J6DUG6A82R
   Part No SW: 6R0 920 861 D    HW: 6R0 920 861 D
   Component: KOMBI         H13 0024
   Serial number: 00000002316014
   Coding: 540800
   ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01004
   ROD: EV_DashBoardUDSJCIPQ25_A01_VW25.rod
   VCID: 366390D989477AFA3F-8062
   Part No SW: 6N0 909 901     HW: 6R0 937 087 D
   Component: GW-K-CAN TP20 0207
   Coding: 002200
   VCID: 70EF66C1A3A314CA25-8024
Address 25: Immobilizer (J285)       Labels:. 5K0-920-xxx-25.clb
   Component: IMMO          H13 X005
   Serial number:
   ASAM Dataset: EV_ImmobUDSJCIPQ25 A01001
   ROD: EV_ImmobUDSJCIPQ25.rod
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 12345
   VCID: 2F6DA5BDEA1D4B327C-807A
End-------------------------(Elapsed Time: 03:22)--------------------------
I really hope someone could help me figure this out! :oops:
Re: Polo 6R MFSW problem: right buttons not working!
Coding: 830000
:?: Coding: 820000 :?:
Remember
Jay-Jay
Post by Jay-Jay »
Thank you, ciclo!
Yes, I know that the buttons to move on the left and on the right don't work, if you don't have MFA+, but in this case even up, down and center buttons aren't working.
I'll try the coding you suggest and I'll let you know as soon as possible! :)
Inviato dal mio MHA-L09 utilizzando Tapatalk
83 = DSG, automatic gearbox.
82 = non-DSG
In case you don't get good results:🤷‍♂️
I have this unit (below) in very good condition with the airbag wiring for MFSW in my storage room, the one I used for my MFSW (old model):
Subsystem 7 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H09 0013
Coding: 820000
I can send you both for a reasonable price.
€ 20? + € 10 shipping cost (tracking number, registered).
Total = 30€ :?:
Paypal. (totaly safe)
The intention is to help, in no case sell.
maxym
Drives: 6R
Post by maxym »
Hi ciclo, do u know what is the function of the last bit in the first byte in the same subsystem(5K0 959 542)? 82 vs 02?
Jay-Jay
Post by Jay-Jay »
ciclo wrote:83 = DSG, automatic gearbox.
82 = non-DSG
I forgot to say that the MFSW I installed on my friend's Polo 6R has the gear selectors for the DSG gearbox, even if his Polo has a manual gearbox.
But, although this detail, we tested this MFSW on another Polo 6R with manual gearbox and ALL the buttons perfectly work. [emoji848] So, I can't really understand why it's not working in this case.
Tonight I'll try the modified coding you suggested and I'll let you know.
ciclo wrote: In case you don't get good results:🤷‍♂️
Coding: 820000
Total = 30€ :?:
I really thank you a lot! I'll keep you updated!
maxym wrote: Mon Jan 28, 2019 3:46 pm Hi ciclo, do u know what is the function of the last bit in the first byte in the same subsystem(5K0 959 542)? 82 vs 02?
I think I had it documented, but at this moment, I don't remember and I can't find it either. Sorry.🙏
Jay-Jay
Post by Jay-Jay »
Hi ciclo, I tried to modify the coding as you suggested, but it's rejected.
I also made another try: I tried using another buttons control (5K0 959 542 A, E221, H09 0013: the same as yours), but right buttons don't work anyway.
I honestly don't know what else I can do. This is a mistery of this specific car. [emoji26]
Maybe I'm making a stupid question:
Jay-Jay
Post by Jay-Jay »
No, that's not a stupid question, Ciclo.
Sometimes, problems like this one have a very simple cause.
Unfortunately, I already thought about the little connector, and I already tried to unplug and plug it again, but nothing changes.
If I install this MFSW on another Polo, it works like a charm, so it doesn't seem to be a problem related to the MFSW or the buttons control unit or the airbag wiring.
Could it be that the BCM doesn't completely support the MFSW?
I don't think BCM is the problem.
What will happen if you replace 540800 by 140800 coding in Address 17: Instruments (J285)?
Jay-Jay
Post by Jay-Jay »
I'll try that and report you back! :)
maxym
Drives: 6R
Post by maxym »
ciclo wrote: Wed Jan 30, 2019 7:56 am I don't think BCM is the problem.
Bit 3(Multifunction-Function-Display active/installed shouldn't be checked(08 vs 0A)? Maybe that is the cause? 54 vs 14 is Japan vs Other the World? :shock:
Jay-Jay
Post by Jay-Jay »
You are making confusion.
Bit 3 is already checked.
"08" means that ONLY bit 3 is checked.
"0A" means that bit 1 and bit 3 are checked.
Ciclo,
"14" is "Country: Rest of World".
"54" is "Country: Japan".
As far as I know, this modifies only consumption unit (and only on some clusters it modifies also the hour from 24h to 12h a.m./p.m.).
I highly doubt this could be the cause of the malfunction, but I'll try it anyway.
Jay-Jay
Post by Jay-Jay »
Well, I tried modiying the coding from "54" to "14", but it didn't fixed the problem.
What if there is a cable missing from BCM to Instrument Cluster?
The steering button control unit communicate with the BCM, but the BCM cannot transfer the signal to the cluster, because a single cable is missing. Could it be possible?
