The new spark leads arrived yesterday.
They are made by MrRetroLeads (UK), which is a little company run by a guy (Anthony) who personally hand-makes the wires per order.
I phoned him twice and he has been very kind to me, explaining all the tech stuff behind the making of high performances spark leads.
Yesterday, as soon as the lead set arrived to me, I measured the resistance with a multimeter. It is ~0,6kOhm for all 4 wires, which is an incredibile value.
Later, I installed them and, as soon as I started the engine, I immediately felt a difference in how it sounded. Smoother, quieter and without even the most little vibration at idle.
Then I took the car for a test-drive and I've been surprised of the increase in throttle response and in torque all over the entire revs.
But "not everything that shines is gold"!
While I was driving I casually looked at the instrument cluster and noticed that the oil temp. indication was intermittent.
I connected VCDS and checked the oil temp. sensor values: when the indication on the cluster disappears, the sensor feels like the oil is at -58°C.
Initally I suspected the sensor was faulty. But it all started as soon as I installed the new spark leads...
So I reinstalled the old ones as a little try. The problem immediately disappeared!
I did this exchange of spark wires three times and the problem came back only with the MrRetroLeads spark wires.
After these tests, I have to sadly say NrRetroLeads spark wires cause some weird problems with EMI, which makes the oil temp. sensor go crazy.
I am going to call Anthony to see what he can suggest to fix the problem.
If you have any tip, it would be really appreciated.
