Kuba591 Polo 6R 1.4 GTI Candy white 3D
Re: Kuba591 Polo 6R 1.4 GTI Candy white 3D
Hi Kuba, I sent an email to firegrafik for him to check his inbox, please wait for him to reply your private message.
Meanwhile, and as an information, read again what I told you here.
viewtopic.php?f=62&t=69223&p=564227#p564227 (it's just a reminder for you, and for those who read this thread )
Thank you.
Thank you.
Hello,
Finally I have all the necessary parts.
I received wiring from ciclo
And a new BCM 7E0937090D pre-set for LED headlights from rofireman with firegrafik help.
Thank you all for the help !
I also bought new airbag tape 6R0959654
Automatic lights switch 3C8941431A
PDC module 7E0919475L
Park sensors 1S0919275C
RVC 5K0827469AQ ULM
So my plan is to install automatic lights and BCM, change airbag tape this week, and later front park sensors and RVC.
It would be very nice if you can give me some tips, how to make it correct, which new connections I have to make, anything that would help.
thank you all
RVC 5K0827469AQ ULM
thank you all
For the new BCM 7E0 to work properly you have to install new CAN lines from the IC to the BCM.
You also have to install a new 1.0mm2 wire from T73b/4 BCM white connector to T6/3 dimmer connector. Remove and isolate T73b/1 and T6/3 original wire.
Today I've managed to do a couple of things:
BCM Max installation -7E0937090 D - I connect IC 28 ---> 54 T73b
IC 29 ---> 57 T73b
Tommorow I will do: T73b/4 BCM to T6/3 dimmer connector and remove and isolate T73b/1 and T6/3 wires.
Automatic Lights wiring - I connect wiring from ciclo + 3C8941431A Lights switch
Airbag tape with G85 sensor - 6R0959654
And for now it looks like this:
For now:
Automatic lights work: 1. without high beam on auto mode, 2. When I cover light sensor with hand -> no change (only DRL are on).
I have no horn, but it was like this before, I was thinking that it is due to broken airbag tape, but apparently not.
Cruse control is not working.
And I also have some questions:
To which BCM connectors and pins should be connected T14/14 wires ?
Should 3C8035730C bluetooth module support SMS and show bluetooth songs names and artist on radio screen ?
Thank you
IC 29 ---> 57 T73b
Address 01: Engine (J623-CAVE) Labels:. 03C-907-309-V1.clb
Part No SW: 03C 906 027 AR HW: 03C 906 027 AR
Component: 1.4l R4 TSI H15 9971
Revision: L2H15--- Serial number:
Coding: 00250012002400000000
Shop #: WSC 73430 031 73430
ASAM Dataset: EV_ECM14TSI01103C906027AR 001014
ROD: EV_ECM14TSI01103C906027AR.rod
VCID: 71E963C5A0A91DCCE7-8024
Readiness: 1110 0101
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 210248E3416D02B5842E12E682D940411700
Shop #: WSC 00788 648 00255
VCID: 071D2D1DB22D337C59-8052
Component: LENKW.SENSOR H06 0060
Serial number: 090465LGJ0013S
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF348F9E1F772B46A-802A
1 Fault Found:
1140738 - Steering angle sensor
B1168 54 [008] - Missing Calibration / Basic Setting
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 153851 km
Date: 2020.02.19
Time: 00:52:06
Voltage terminal 15: 11.70 V
Voltage terminal 30: 11.85 V
Terminal 15 status: On
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 326BACC96D2F66D4DE-8066
Part No SW: 7E0 937 090 D HW: 7E0 937 090 D
Component: BCM PQ25 Max4 H82 0762
Revision: B9082001 Serial number: 8602 116190032
Coding: 3CB029B848A3000001280EB17EAB0FD10AC067FF60051041200000000000
Shop #: WSC 01375 011 00200
VCID: 2C57B2B14F0B302494-8078
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 130411 05 54 0403
Coding: 03302D
Subsystem 2 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 007 1621
Serial number: KU0KU005041100013713
Coding: 08BC30
Subsystem 3 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 007 1621
Serial number: KU0KU031031100012484
Coding: 08BC30
Subsystem 4 - Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H06 0010
Serial number: 0032483
Coding: 830000
2 Faults Found:
03433 - Terminal 30 for Backup Lights and Adaptive Lights
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 6
Reset counter: 0
Mileage: 153851 km
Time Indication: 0
Date: 2014.07.12
Time: 00:52:08
03591 - Control Circuit for Horn
012 - Electrical Fault in Circuit
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Mileage: 153851 km
Time Indication: 0
Date: 2014.07.12
Time: 01:03:25
Address 10: Park/Steer Assist (J446) Labels:| 6R0-919-475.clb
Part No SW: 6R0 919 475 B HW: 7E0 919 475
Component: PARKHILFE 4K H11 0012
Revision: -------- Serial number: 47301109001708
Coding: 108104
ROD: EV_VW250ParkiAssis2.rod
VCID: 3D718FF5AC71A9AC33-8068
Part No SW: 6R0 959 655 M HW: 6R0 959 655 M
Component: VW10Airbag012 H09 0020
Revision: -------- Serial number: 003GZ000HFMM
Coding: 003132
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4C97D231E7CB1024B4-8018
Serial number: 3575HRB405V0GR3468BI
Serial number: 3585HRB405V0GR34APG2
Serial number: 3515RRB405J0H4DQB1MT
Serial number: 3525RRB40650ESC6GGBQ
Part No SW: 6R0 920 870 HW: 6R0 920 870
Component: KOMBI H21 0320
Coding: 140C00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
VCID: 72EB6CC9A5AF26D41E-8026
1 Fault Found:
13639168 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Mileage: 153851 km
Date: 2020.02.19
Time: 01:08:26
Part No SW: 7E0 909 901 HW: 7E0 937 090 D
Component: GW-K-CAN TP20 H82 0762
Revision: B9082001
Coding: 002000
VCID: 68DF0EA19B73DC04B0-803C
2 Faults Found:
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 153851 km
Time Indication: 0
Date: 2014.07.12
Time: 00:55:47
01771 - Control Module for Headlight Range (J431)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 153851 km
Time Indication: 0
Date: 2014.07.12
Time: 00:55:48
Component: IMMO H21 0320
Serial number:
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADB74A98D7FEE14A6-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7660510927
Coding: 010000
Shop #: WSC 01357 011 00200
VCID: 29594BA540F9250C6F-807C
1 Fault Found:
03138 - Input AUX IN
009 - Open or Short to Ground
Fault Status: 01101001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 0
Mileage: 153851 km
Time Indication: 0
Date: 2014.07.12
Time: 01:12:16
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 686 C HW: 1T0 035 686 C
Component: RNS-MID H10 5238
Revision: AB001001 Serial number: VWZ6Z7S513740Y
Coding: 00010400040000010001
Shop #: WSC 85046 004 02308
VCID: 3467AAD1973B68E4CC-8060
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V14 8477
2 Faults Found:
00857 - CD Changer Unit (R41)
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 153848 km
Time Indication: 0
02877 - Digital Radio Antenna (R183)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 3
Reset counter: 0
Mileage: 153848 km
Time Indication: 0
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11241
Shop #: WSC 00788
VCID: 2F6DA5BDEA1D4B3CB1-807A
Address 55: Headlight Range
Cannot be reached
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
2 Faults Found:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 153848 km
Time Indication: 0
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 3
Reset counter: 0
Mileage: 153848 km
Time Indication: 0
Address 77: Telephone (J412) Labels:| 3C8-035-730-A.clb
Part No SW: 3C8 035 730 C HW: 3C8 035 730 C
Component: Telefon 012 0822
Revision: -------- Serial number: 35909603489117
Coding: 020000010100010000000401
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_UHVPremi A02705
ROD: EV_UHVPremi_A02.rod
VCID: 2345598D2AD5FF5C25-8076
End-------------------------(Elapsed Time: 04:21)--------------------------
Thank you
This is the starting point for the new BCM coding.
Note:
It is the first BCM coding that I provide according to the information in this thread, mainly focused on automatic lights, new BCM 7E0 and LED headlights. The rest of the faults seen in Autoscan will be corrected later.
New BCM coding (Automatic lights + CH/LH ... "New 7E0 BCM and 6C LED headlights")
3CB029B848A3000001280EB07CEB0FD100C0606F60853961210000000020
If the electrical installations were carried out and verified correctly, many things should start to work correctly.
Report the results (you must know the correct operation of the systems to report the results correctly).
Autoscan faults
-Make the G85 sensor basic setting in Address 03 ABS. It must be performed every time a new G85 sensor is installed.
-Check fuse 57. (T73b/11 BCM)
-Check the ground connection in the airbag wiring.
Address 17: Instruments (J285)
-140E00 Check if it is the coding you want.
Address 19:
-The faults in the Gateway are related to other modules.
-For the rest of the faults check the electrical installations and codings.
LED headlights - BCM
https://drive.google.com/file/d/1x2piv7 ... sp=sharing
Recommendation:
- Use a newer version of VCDS.
- Take detailed photos of systems that do not work properly.
Note:
Autoscan faults
Address 19:
Recommendation:
Hi !
Weekend was quite busy for me
I applied and installed:
1. New BCM coding you send me - I record video how lights work after coding is applied - according to my observation and knowledge only problem now is:
After turning off high beam, low beam is turning off for a moment, parking lights works correct, fog lights - correct, cornering lights - correct, low beam - correct, CH - correct, LH - not working, turning lights - correct, light sensor- correct.
https://vimeo.com/393493627
I hope it is enough information. If you need some more details please tell me and I will check and post.
2. Installed wires for dimmer: T73b/4 BCM to T6/3,
3. Remove and isolate T73b/1 and T6/3 wires,
4. I done the basic setting of G85 sensor - no fault now
5. Figure out problem with the horn - it was due to missing fuse :p
6. Changed fuse 57 - then immediately it was broken, so I checked wiring and it was my fault - some mistakes. I've fix it and now everything is ok.
7.Installed front PDC - sensors work correct but I have no visualisation on RNS when I press PDC button, only sound.
8. Installed RVC - Camera works fine but I have problem - I cannot open trunk using VW emblem when car is not on ignition/running, only via remote.
Also when I drive on reverse, then change to P and turn off car and leave, camera remains open.
9. Changed fuse 57 - Now it is alright
10. Enable byte 27 bit 1 - because I have no power to dimmer and I wanted to check if I make wirings in correct way.
New autoscan
I will upload more photos soon
I will be glad for every help with my faults.
New autoscan
Sunday,23,February,2020,19:53:08:00007
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: WVWZZZ6RZBY303948 License Plate:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 2E 37 44 55 56 77
VIN: WVWZZZ6RZBY303948 Mileage: 153850km-95597miles
2E-Media Player 3 -- Status: Not registered 0001
37-Navigation -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
Cannot be reached
Revision: --------
Coding: 01
Revision: 0002S 02
Coding: 3CB029B848A3000001280EB07CEB0FD100C0606F60853961210000020020
Coding: 03302D
Coding: 08BC30
Coding: 08BC30
Coding: 830000
1 Fault Found:
00979 - Lamp for Low Beam; Right (M31)
010 - Open or Short to Plus - Intermittent
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 3
Reset counter: 40
Mileage: 153851 km
Time Indication: 0
Date: 2014.07.16
Time: 00:57:56
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 7N0 919 475
Component: PARKHILFE 8K H06 0106
Revision: -------- Serial number: 28231602500620
Coding: 308101
Shop #: WSC 02739 790 50316
VCID: 3B7581EDB265A79C0D-806E
Coding: 003132
Coding: 140E00
Revision: B9082001
Coding: 002000
1 Fault Found:
000 - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 153851 km
Time Indication: 0
Date: 2014.07.16
Time: 00:56:22
Serial number:
Coding: 020000
Coding: 00010440040000010000
1 Fault Found:
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 153848 km
Time Indication: 0
Coding: 11241
Shop #: WSC 00788
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
VCID: 77FD5DDDCECD43FC29-8022
1 Fault Found:
5275220 - Headlight
C107E 54 [137] - Missing Calibration / Basic Setting
Fault Priority: 1
Fault Frequency: 1
Reset counter: 0
Mileage: 153851 km
Date: 2020.02.23
Time: 00:56:21
1 Fault Found:
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 153848 km
Time Indication: 0
End-------------------------(Elapsed Time: 04:15)--------------------------
Well, we have improved a little.
Tomorrow I will study all that seems not to work properly.
At a quick glance:
- The AFS unit is not correct.
- There is no DAB antenna installed. (look at the last pgs of my thread)
viewtopic.php?f=56&t=58703&start=4725#p564816
viewtopic.php?f=56&t=58703&start=4740#p564905
- Byte27 Bit1... OK!! Perfect!
At a quick glance:
First, the part related to automatic lights, which is what corresponds to me.
- Once I have checked the BCM and RLS coding ... (OK)
How the CH and LH functions work on PQ25 (Light switch in AUTO)
'Coming home'
Turn off the ignition switch, pull from HB lever/stalk once, open the door, the lights will turn on for the set time.
Also works if you have the door already open.
'Leaving home'
Press the door opening button on the remote control, the lights will turn on for the set time.
Please, check it.
Problem solved, easy.
'Coming home'
'Leaving home'
Please, check it.
Regarding the 6C LED Headlights.
Thank you very much for the video, once I have seen it ...
There is a clear delay in lighting when switched from HB to LB with the stalk, I don't know the reason for this little period of darkness. It must be corrected.
(I consider it very dangerous for driving)
Well, maybe it's related to the AFS unit, which is not correct.
Are the control units of the LED headlights brand new?
New coding RNS510 (suggested coding)kuba591 wrote: ↑Mon Feb 24, 2020 7:49 pm
00000440040000A10001
For the changes/codings to take effect on the RNS510 you must press ... < + > + Eject + Micro buttons ... at the same time until the screen turns off. Release the buttons and wait, it wil come back to life with the new functions.
It seems that you have connected the RVC positive wire to a +15 signal (wrong), instead of a +30 signal (correct).
Help images
Hmm... HB --> LB
6C Led headlights in 6R WRC
6C GTI
LB always ON...
6C GTI
LB always ON...
I rewired RVC to terminal 30 - of course everything works correct now
I applied new coding for navi and really like “dark mode “, pdc button also works when I pressed it, but only once ( I have to double check it cause I have no time)
I bought headlight modules as new but not directly from vw dealer, so I cannot tell for 100%
I also checked first bcm coding that you ever sent me ( before automatic lights wiring) and then this hb —> lb delay is not present.
Also when I changed lights settings from T5 double lights to T5 bi-xenon lights this gap disappeared.
I record video of that.
But I observed that right headlight blinks sometime.
I’ve done it only for a research and I recoded bcm with previous coding.
https://vimeo.com/393761147
Also in my Polo there is not present this function that is visible in this movie with polo Wrc —> Turn On = LB off
And CH/LH is working after I followed your instructions.
6R WRC without Autolights, position '0' of light switch. DRL ON.
(Btw... wrc with T6 BCM 7E0937090/Z4Y ... Once upon a time in a far fairy kingdom... )
Please explain this better, provide data (autoscan or BCM coding) or what the conditions were (bcm model), etc ... Thanks
It may be necessary for me to clarify a couple of things.
I am glad that everything that corresponds to me (Automatic lights) works super perfect.
Hi
Sorry but I was really busy last days.
So to make it all organised:
In all cases it is the same BCM - Part No SW: 7E0 937 090 D HW: 7E0 937 090 D . Component: BCM PQ25 Max4 H82 0762
I checked once more time position of the pins in headlight wiring and wiring.
As it was easy to do I've done experiment and I changed value of Byte 18 (T5 double lights --> T5 bi-xenon lights)
Maybe this videos and autoscans will somehow help to find a solution
Q - Which AFS unit should I use ? 6R0907357C ?
1. High Beam gap is present with this coding BCM coding:
It is the first coding you send me (with activation Byte 27 Bit 1 for dimmer)
Autoscan with this coding
2. High Beam gap is not present with this coding
- but another adverse effect is observed - blinking of Low Beam approx. once in 5 min. (blink is visible in last part of video)
- firstly Right headlight then after some time both
3CB029B848A1000001280EB07CEB0FD100C0666F60853961210000020020
https://vimeo.com/395047123
3. This coding change I've done only research only.
- High beam gap is not present
- Blinking is present in a same manner as above
- Headlight warning light on IC is not present
3CB029B848A1000001280EB07CEB0FD100C0646F60853961210000020020
Friday,28,February,2020,18:56:52:00007
www.Ross-Tech.com
VIN: WVWZZZ6RZBY303948 Mileage: 154120km-95765miles
56-Radio -- Status: OK 0000
Cannot be reached
Revision: --------
Coding: 01
Revision: 0002S 02
Coding: 03302D
Coding: 08BC30
Coding: 08BC30
Coding: 830000
4 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
007 - Short to Ground - Intermittent
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 4
Reset counter: 57
Mileage: 154124 km
Time Indication: 0
Date: 2014.07.21
Time: 22:41:11
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 8
Reset counter: 17
Mileage: 154124 km
Time Indication: 0
Date: 2014.07.21
Time: 22:41:13
Fault Priority: 3
Fault Frequency: 1
Reset counter: 57
Mileage: 154124 km
Time Indication: 0
Date: 2014.07.21
Time: 22:41:11
Fault Priority: 3
Fault Frequency: 17
Reset counter: 57
Mileage: 154124 km
Time Indication: 0
Date: 2014.07.21
Time: 22:41:13
Coding: 308101
Coding: 003132
Coding: 140E00
Revision: B9082001
Coding: 002000
Serial number:
Coding: 020000
Coding: 00000440040000A10001
Coding: 11241
Shop #: WSC 00788
1 Fault Found:
5275220 - Headlight
Fault Priority: 1
Fault Frequency: 1
Reset counter: 17
Mileage: 154124 km
Date: 2020.02.28
Time: 22:17:35
End-------------------------(Elapsed Time: 04:16)--------------------------
Friday,28,February,2020,18:24:35:00007
www.Ross-Tech.com
Readiness: 0000 0000
Cannot be reached
Revision: --------
Coding: 01
Revision: 0002S 02
Coding: 3CB029B848A1000001280EB07CEB0FD100C0666F60853961210000020020
Coding: 03302D
Coding: 08BC30
Coding: 08BC30
Coding: 830000
2 Faults Found:
Fault Priority: 3
Fault Frequency: 86
Reset counter: 57
Mileage: 153947 km
Time Indication: 0
Date: 2014.07.19
Time: 00:42:39
Fault Priority: 3
Fault Frequency: 138
Reset counter: 57
Mileage: 153945 km
Time Indication: 0
Date: 2014.07.19
Time: 00:37:20
Coding: 308101
Coding: 003132
Coding: 140E00
Revision: B9082001
Coding: 002000
1 Fault Found:
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 153851 km
Time Indication: 0
Date: 2014.07.17
Time: 00:56:22
Serial number:
Coding: 020000
1 Fault Found:
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 93
Reset counter: 56
Mileage: 153848 km
Time Indication: 0
Coding: 11241
Shop #: WSC 00788
1 Fault Found:
5275220 - Headlight
Fault Priority: 1
Fault Frequency: 1
Reset counter: 0
Mileage: 153851 km
Date: 2020.02.24
Time: 00:56:21
1 Fault Found:
Fault Priority: 5
Fault Frequency: 93
Reset counter: 56
Mileage: 153848 km
Time Indication: 0
End-------------------------(Elapsed Time: 04:20)--------------------------
Friday,28,February,2020,18:47:38:00007
www.Ross-Tech.com
Cannot be reached
Revision: --------
Coding: 01
Revision: 0002S 02
Coding: 3CB029B848A1000001280EB07CEB0FD100C0646F60853961210000020020
Coding: 03302D
Coding: 08BC30
Coding: 08BC30
Coding: 830000
Coding: 308101
Coding: 003132
Coding: 140E00
Revision: B9082001
Coding: 002000
Serial number:
Coding: 020000
Coding: 11241
Shop #: WSC 00788
1 Fault Found:
5275220 - Headlight
Fault Priority: 1
Fault Frequency: 1
Reset counter: 17
Mileage: 154124 km
Date: 2020.02.28
Time: 22:17:35
End-------------------------(Elapsed Time: 04:04)--------------------------
