Kuba591 Polo 6R 1.4 GTI Candy white 3D
kuba591
Drives: 6R 1.4 GTI
Post by kuba591 »
Hi people,
I am Kuba
And this is my Polo.
Our roads crossed in 2017 and since that time I like her more and more :D  but she's not easy one.
2017 - I found her in an ad...
Image   Image
She was not the prettiest, but after couple of days she was mine.
Image - Loaded on a tow truck in a traditional polish style  :roll:
It was imported from France. The car was put up for auction, showing signs of burglary with the use of primitive tools.
The thieves stole the headlights, bending the hood, breaking the radiator grille and forcibly pulling them out.
Then they smashed the passenger glass and stole the radio unit. All of that by the use of flat screwdriver.
There was a lot of broken parts: Windshield, stalks, dashboard, radio wires, passenger window, door panel, side skirts, rear wiper motor, rear dampers and many many more.
Firstly I started with a cleaning, there were a tons of glass particles everywhere, than installing new winter wheels, because steel wheels that were mounted, was too small to even move it.
After that I started the rebuild ---> collecting parts ---> doing repairs in every free time ----> it is still that way
Stalks where broken in that way, that rear wiper and washer were on all the time ---> So I bought correct stalks for cruise control retrofitting, but by the lack of time and need for repair more important things in that time I just installed without a proper wiring.
Same think was with the headlights.
Image   Image
Image    Image
In a shortcut - I was fixing everything along the time
For ex. restoring OEM rear lights and many many more.
Image -->  Image
Finally I bought new summer wheels and she looks much better.
But after some time I observed a little bit of white smoke, notice some vibration, which was getting worst every week ......
When I opened the engine it looks like this:
And here we have the cause -->  Image . Image
So engine rebuild was necessary to make it operational one more time.
I did the engine rebuild according to Lucifer666 1.4 tsi guide from seat forum, trying to fix it as much possible.
Lucifer's guide credits - https://forums.seatcupra.net/index.php? ... ms.407682/
In a big shortcut:
  • Revised pistons - 03C 107 065 CK
  • Piston ring kit -   03C 198 151 M
  • Coil packs -         036 905 715 H
  • Spark plugs -       NGK Iridium BRK7EIX
  • Timing chain -     03C 109 158 A
  • Updatet engine software
  • PCV mod + Catch can
  • Cylinder head rebuild
etc. ----> photos ---> https://imgur.com/a/XvNAjVw
Image  Image  Image
Image  Image  Image
Image  Image  Image
Image  Image  Image
Image  Image   Image
There is still some white smoke and some brownish fluid collecting in a catch can but now engine is working properly - at least I hope so.
Oil used : 0W40 Penrite 10 tenths
Last week I've also noticed oil smell in the cabin and oil in intake. After investigation it was faulty breather hose - so I change it and that result in no more oil smell.
Last thing that I have to replace is clutch kit and flywheel due to some vibration during 1-2 shift - but this will happen in January maybe.
Finally after investing money and time in rebuild I can start doing more pleasant things and ones I didn't have time for.
I am planing to: :mrgreen:
Firstly:
  • Fix headlights ---> proper wiring + coding
  • Lights auto switch ---> wiring from ciclo + coding
  • Connect cruise control --> proper wiring + coding
  • Connect MDI --> just installation of interface + coding
  • Dab antenna --> installation
  • RVC camera --> installation + coding
  • PDC Front ---> installation + coding
Fix all bad coding
Already installed:
  • RNS 510 - 1T0 035 680 P
  • Bluetooth - 3C8 035 730 C
  • Stalks - 6Q0 953 503 DS
  • GTI Led headlights - 6C1 941 773 A / 6C1 941 774 A
  • Motorsport wheels - 6R0 071 497 AX1
  • VW Valve caps - 00 00 71 21 5A
Autoscan :
VIN: WVWZZZ6RZBY303948   License Plate:
Mileage: 150850km-93733mi   Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 37 44 55 56 77
VIN: WVWZZZ6RZBY303948   Mileage: 150850km-93733miles
37-Navigation -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J623-CAVE)       Labels:. 03C-907-309-V1.clb
   Part No SW: 03C 906 027 AR    HW: 03C 906 027 AR
   Component: 1.4l R4 TSI   H15 9971
   Revision: L2H15---    Serial number:
   Coding: 00250012002400000000
   Shop #: WSC 73430 031 73430
   ASAM Dataset: EV_ECM14TSI01103C906027AR 001014
   ROD: EV_ECM14TSI01103C906027AR.rod
   VCID: 71E963C5A0A91DCCE7-8024
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 050 K    HW: 0AM 927 769 D
   Component: GSG DSG AG7     411 9058
   Revision: 00041014    Serial number: TFK01103240843
   Coding: 0000020
   Shop #: WSC 37806 001 1048576
   VCID: 3169A3C5AB295DCCA7-513C
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210248E3416D02B5842E12E682D940411700
   Shop #: WSC 00788 648 00255
   VCID: 071D2D1DB22D337C59-8052
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 6R0 820 045 G    HW: 6R0 820 045 G
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 326BACC96D2F66D4DE-8066
Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
   Part No SW: 7H0 937 089 D    HW: 7H0 937 089
   Component: BCM T5GP Li4  H47 0230
   Revision: BS047001    Serial number: 0398 097110111
   Coding: 3CB029BF48A1000001280EB17E2B0FD00AC067FF60051041200000000000
   Shop #: WSC 85046 004 02308
   VCID: 377D9DDD864D83FCE9-8062
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 130411 05  54  0403
   Coding: 03302D
   Subsystem 2 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  007 1621
   Serial number: KU0KU005041100013713
   Coding: 08BC30
   Subsystem 3 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  007 1621
   Serial number: KU0KU031031100012484
   Coding: 08BC30
   Subsystem 4 - Part No SW: 5K0 959 542     HW: 5K0 959 542
   Component: E221__MFL-TAS  H06 0010
   Serial number: 0032483
   Coding: 830000
11 Faults Found:
03428 - Activation of Left Adaptive Light
            006 - Short to Plus - Intermittent
                    Fault Status: 00100110
                    Fault Priority: 3
                    Fault Frequency: 254
                    Reset counter: 77
                    Mileage: 134567 km
                    Time Indication: 0
                    Date: 2013.08.29
                    Time: 00:51:28
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 3
                    Reset counter: 49
                    Mileage: 134567 km
                    Time Indication: 0
                    Date: 2013.08.29
                    Time: 00:31:40
03429 - Activation of Right Adaptive Light
                    Fault Priority: 3
                    Reset counter: 77
                    Mileage: 134567 km
                    Time Indication: 0
                    Date: 2013.08.29
                    Time: 00:51:28
            011 - Open Circuit
                    Fault Priority: 3
                    Reset counter: 49
                    Mileage: 134567 km
                    Time Indication: 0
                    Date: 2013.08.29
                    Time: 00:31:41
03432 - Activation of Right Parking Light
                    Fault Priority: 2
                    Reset counter: 76
                    Mileage: 147954 km
                    Time Indication: 0
                    Date: 2014.03.08
                    Time: 18:22:57
            011 - Open Circuit
                    Fault Priority: 2
                    Reset counter: 49
                    Time Indication: 0
03591 - Control Circuit for Horn
            012 - Electrical Fault in Circuit
                    Fault Status: 01101100
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 32
                    Mileage: 150354 km
                    Time Indication: 0
                    Date: 2014.04.26
                    Time: 20:15:16
02745 - Bulb for Daytime Running Light; Left
            010 - Open or Short to Plus - Intermittent
                    Fault Status: 00101010
                    Fault Priority: 3
                    Reset counter: 89
                    Mileage: 134568 km
                    Time Indication: 0
                    Date: 2013.08.29
                    Time: 00:58:46
02746 - Bulb for Daytime Running Light; Right
                    Fault Priority: 3
                    Reset counter: 89
                    Mileage: 134573 km
                    Time Indication: 0
                    Date: 2013.08.29
                    Time: 20:48:43
02898 - Control Circuit for LED Module for DRL and Parking Light; Right
            007 - Short to Ground
                    Fault Status: 01100111
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 19
                    Mileage: 134567 km
                    Time Indication: 0
                    Date: 2013.08.29
                    Time: 00:31:40
02896 - Control Circuit for LED Module for DRL and Parking Light; Left
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 19
                    Mileage: 134567 km
                    Time Indication: 0
                    Date: 2013.08.29
                    Time: 00:31:40
Address 10: Park/Steer Assist (J446)       Labels:| 6R0-919-475.clb
   Part No SW: 6R0 919 475 B    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0012
   Revision: --------    Serial number: 47301109001708
   Coding: 108104
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3D718FF5AC71A9AC33-8068
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 6R0 959 655 M    HW: 6R0 959 655 M
   Component: VW10Airbag012 H09 0020
   Revision: --------    Serial number: 003GZ000HFMM
   Coding: 003132
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4C97D231E7CB1024B4-8018
   Serial number: 3575HRB405V0GR3468BI
   Serial number: 3585HRB405V0GR34APG2
   Serial number: 3515RRB405J0H4DQB1MT
   Serial number: 3525RRB40650ESC6GGBQ
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 6R0 920 870     HW: 6R0 920 870
   Component: KOMBI         H21 0320
   Coding: 140C00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
   VCID: 72EB6CC9A5AF26D41E-8026
Address 19: CAN Gateway (J533)       Labels:. 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 7H0 937 089
   Component: GW-K-CAN TP20 0230
   Coding: 002000
   VCID: 70EF66C1A3A314C4E8-8024
3 Faults Found:
            000 -  -  - Intermittent
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 134567 km
                    Time Indication: 0
                    Date: 2013.08.29
                    Time: 00:27:11
00463 - Control Module for Digital Sound Package (J525)
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 18
                    Mileage: 134567 km
                    Time Indication: 0
                    Date: 2013.08.29
                    Time: 00:13:31
03590 - Control Module for Multifunction Module
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 18
                    Mileage: 134567 km
                    Time Indication: 0
                    Date: 2013.08.29
                    Time: 00:07:52
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H21 0320
   Serial number:
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB74A98D7FEE14A6-803E
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 686 C    HW: 1T0 035 686 C
   Component: RNS-MID       H10 5238
   Revision: AB001001    Serial number: VWZ6Z7S513740Y
   Coding: 00010400040000810001
   VCID: 3467AAD1973B68E4CC-8060
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V14  8477
2 Faults Found:
00821 - Antenna 2 for Radio (R93)
            011 - Open Circuit
                    Fault Priority: 5
                    Reset counter: 49
                    Mileage: 134560 km
                    Time Indication: 0
02877 - Digital Radio Antenna (R183)
            011 - Open Circuit
                    Fault Priority: 5
                    Reset counter: 49
                    Mileage: 134560 km
                    Time Indication: 0
Address 44: Steering Assist        Labels: 6Q0-423-156.clb
   Part No: 6R0 423 156 B
   Component: LenkhilfeTRW        V277
   Coding: 11241
   Shop #: WSC 00788
   VCID: 2F6DA5BDEA1D4B3CB1-807A
Address 55: Headlight Range (J431)       Labels:. 6R0-907-357.clb
   Part No SW: 6R0 907 357     HW: 6R0 907 357
   Component: LWR-ECU       H02 0070
   Revision: --------    Serial number: --------------
   Coding: 0116000001000000
   VCID: 77FD5DDDCECD43FC29-8022
1 Fault Found:
5275220 - Headlight
          C107E 54 [137] - Missing Calibration / Basic Setting
                    Fault Status: 00000001
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 18
                    Mileage: 134567 km
                    Date: 2019.04.08
                    Time: 00:08:57
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
2 Faults Found:
            011 - Open Circuit
                    Fault Priority: 5
                    Reset counter: 49
                    Mileage: 134560 km
                    Time Indication: 0
            011 - Open Circuit
                    Fault Priority: 5
                    Reset counter: 49
                    Mileage: 134560 km
                    Time Indication: 0
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 C    HW: 3C8 035 730 C
   Component: Telefon       012 0822
   Revision: --------    Serial number: 35909603489117
   Coding: 020000000100011000000400
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_UHVPremi A02705
   ROD: EV_UHVPremi_A02.rod
   VCID: 2345598D2AD5FF5C25-8076
1 Fault Found:
9458451 - Cellular Antenna
          B1053 13 [009] - Open Circuit
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 49
                    Mileage: 150855 km
                    Date: 2019.12.14
                    Time: 16:23:03
End-------------------------(Elapsed Time: 04:15)--------------------------
Current look-->
I am happy to share my story with you guys. Tnx
Re: Kuba591 Polo 6R 1.4 GTI Candy white 3D
Hi Kuba, welcome again.
Great story of a 6R GTI. Thanks for sharing! 8)
We will improve it as much as possible.
Please can you tell us how you solved the 'forbidden' problem to be able to post the photos, autoscan, etc.
JavaScript enabled?
Thank you.
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
very nice.
a lot of hard work.
kuba591
Drives: 6R 1.4 GTI
Post by kuba591 »
Hi ciclo,
I’ve post it via tapatalk, without any problems.
Using chrome it was impossible ;)
Lovely job. Welcome here
While we wait for you to receive the wiring for automatic lights we will try to solve the faults detected in the autoscan.
If everything works correctly with your phone-antenna module,
please read here :arrow: https://forums.ross-tech.com/showthread ... it-problem
enter this new coding to disable antenna diagnostics:
020000010100011000000400
Please provide the information you deem appropriate and report the results. Thanks.
kuba591
Drives: 6R 1.4 GTI
Post by kuba591 »
Hello :)
I was really busy during Christmas and New Year.
But today I did some work, as I am waiting for package to be delivered I tried to fix things.
Ciclo I tried to disable antenna diagnostics via new coding you send me, but it won't accept new coding, so I will check the wiring tomorrow.
I also connect wires for a cruise control, migrate T14/14 wires to fog lights, connect double fakra adapter.
As I was making new wires, I decide that I will try to make a proper wiring to my headlights, even if as you said my BCM is very likely not suitable.
I was pulling new wire to ECU during CC retrofit, so as I was there I connect a new wires from ASF positive to T14/8, and from BCM T73b/54 and 56 to T14/14 and change places of pins in T14, according to guide that iichel posted on mypolo.nl
Just to see what happens, if it will not work I will change BCM :)
As day come to an end I didn't finished assembly so I will continue tomorrow :?: :?: :?:
I'll post updated autoscan and some photos.
I would recommend to do all the wiring at once for you headlights and bcm max. it will save you a lot of time overall and will give you the best result.
kuba591 wrote: Sun Jan 05, 2020 12:22 am As I was making new wires, I decide that I will try to make a proper wiring to my headlights, even if as you said my BCM is very likely not suitable.
A good option is to contact firegrafik, he can help you get a new 7E0 BCM Max of the latest models, this is what many people did here in the forum. :wink:
I think I remember that my old original BCM 7H0937089F (a long time since then), did not work properly after installing the new CAN lines for the Instrument panel/cluster in order to install the new 7E0 BCM models. (54b / 57b <---> 28 / 29 .... BCM <---> IC)
I guess your BCM 7H0937089D (oldest still) will happen the same.
kuba591
Drives: 6R 1.4 GTI
Post by kuba591 »
Ok, thank you guys for your advices. I will contact firegrafik, and try to install all at once. :)
If you reply to this/my post you will have reached the 10 necessary posts to be able to send private messages, and thus be able to contact firegrafik by private message.
If you liked this/my post, post a 'LIKE' 👍 in your next post. :mrgreen:
kuba591
Drives: 6R 1.4 GTI
Post by kuba591 »
JakeF52
Drives: POLO S
Post by JakeF52 »
What're the name of the summer alloys you put on?
kuba591
Drives: 6R 1.4 GTI
Post by kuba591 »
JakeF52 wrote:What're the name of the summer alloys you put on?
Hi ! VW motorsport alloy wheel 17” Black
Part number: 6R0071497AX1
https://www.volkswagenpartsuk.co.uk/par ... -17-black/
JakeF52
Drives: POLO S
Post by JakeF52 »
kuba591 wrote: Fri Jan 10, 2020 11:24 am
Cheers mate, checked the link and they're out of stock atm will have to keep an eye on them!
Thanks!
