VW Bettle 5C Automatic Lights
kantusjack
Drives: GTI 6R
Re: VW Bettle 5C Automatic Lights
Post by kantusjack »
ciclo wrote: Thu Feb 20, 2020 8:22 am Hi Santos. :)
Thanks for the report.
So, is your Beetle with original LED License Plate Lights?
Not yet ..... :D
I'm waiting for the new led license plate lights ... Then I'll recode the 09 module
kantusjack
Drives: GTI 6R
After reading some threads ...
is this the right coding once we have done the new installation???
6CB8697808410C0093A809316E8B86C4F8C2670F60851841B2A004000000
kantusjack
Drives: GTI 6R
Hi again,
retrofitted done ... everything works perfect except one issue
When the ignition is ON and the headlamp switch is in the "0" position the DRL are activated ...
This only should occur in the "AUTO" position (DRL are activated in this position). I've cheked with my VW Sharan and with the ignition ON and the headlamp in "0" position DRL are not activated.
Hi Santos.
By law, DRLs must be turned on with the ignition switch ON, and 0 position of light switch. :wink:
It is mandatory for several years now.
What is the manufacturing date of your VW Sharan?
Depending on the date of manufacture and the existing laws in each place/country, multiple combinations have been made in the electrical/electronic systems for the operation of the DRLs.
kantusjack
Drives: GTI 6R
VW Sharan 7N MY 2011
WVWZZZ7NZB
It was bought in Germany 5 years ago ...
Yes, 2010-2011 are complex dates in terms of mandatory use of DRLs.
Everything changes, e.g. the fog lights that we all know now begin to be called bad weather lights. :lol:
The lightning is missing ... and the sound of thunder when the button is pressed/touched. :mrgreen:
Click->⚡
Nightbreaker1964
Drives: Beetle 5C 2.0 TFSI 147kW Jear 2013
Post by Nightbreaker1964 »
Hello manusjack
I found your entry on automatic lighting here.
I have a 2013 Beetle 5c with xenon lights, rain sensor, fog lights and LED number lighting and would very much like to retrofit the automatic lights. Unfortunately, I can no longer find a corresponding cable set from any retrofit supplier. Sold out everywhere.
Perhaps you, or a reader of my post, have a list with the manufacturer OEM numbers of all the required plugs and relays, so that I could almost certainly rebuild this myself.
Thanks for any help, from wherever (maybe Ciclo?)
Kind regards
Nightbreaker1964 (Peter)
Nightbreaker1964
Hy Ciclo
and thanks for your fast answer.
Yes, it is with original LED-licenseplatelight.
Greetz
Hi, I only provide help altruistically in case of incidents or coding.
Everything is written here in the forum, but scattered in countless posts.🤷‍♂️
Maybe some other forum user can make your PQ25 automatic lights wiring.
Nightbreaker1964
Hello Ciclo
Thanks for your reply, I'll start searching the forum.
If I can just find a manufacturer/seller for the necessary plugs, my biggest problem will be solved.
I always wish you a safe journey :D
The installation guide for AL wiring is in the first post of this thread, faithfully follow the diagram - at the end of the guide -.
E.g:
The red/black 10-pin coupling is an ISO connector, you can buy it in many well-known places (googling, etc).
Also here: www.tme.eu (search in 4CARMEDIA), see applications, contact terminals, etc. on that same website.
The other connectors and relay support/carrier are original VW.
Buy from VW dealers or VW stores near where you live, they are also offered on well-known websites (googling, etc).
Help link: ETKA online and more.
