6R to 6C Headlight upgrade help
Re: 6R to 6C Headlight upgrade help
Yeah I thought they have been the case. Well I have them both now and had a quick look today.. however the right one doesn’t seem to fit! It hits the washer filler pipe and seems quite tight. Need to have a proper look but they are def quite a bit deeper than my H4 headlights.
Hi, I am in the same position as Sbozzy, although I was looking at simply installing H4 LED bulbs, I was not aware that the 6C headlights were able to fit straight in.ciclo wrote: Thu Feb 13, 2020 2:33 am Hi Sbozzy, welcome.
Please post an Autoscan, or BCM coding. Thanks.
Easy for your 6R Bluemotion:
1- Buy the 6C H7 headlights.
2- Install them.
3- New BCM coding.
4- Level/correct the light beam patterns with a suitable regloscope.
Would you mind assisting and letting me know what does and doesn't fit my 2011 bluemotion and what needs done to make them work?
Cheers,
Kyle
Hi, if you are in the same situation, please post the VCDS Autoscan to tell you that you have to modify once you install the H4 LED bulbs.
Please first read the regulations on the use of LED bulbs in reflector headlights.
I would quite like to try and convert to the 6C headlight's as opposed to LED bulbs in a halogen headlight as that certainly seems the best option now.ciclo wrote: Mon Feb 01, 2021 6:36 pm Hi, if you are in the same situation, please post the VCDS Autoscan to tell you that you have to modify once you install the H4 LED bulbs.
It's certainly do-able. I've done a couple of these retrofits on the past months.
Halogen headlights should be banned.
Feel free to baby step me through it, if you don't mind.iichel wrote: Mon Feb 01, 2021 7:48 pm It's certainly do-able. I've done a couple of these retrofits on the past months.
Cars aren't my thing, motorcycles though? that's my jam! lol
Do you have vcds or something similar?
I have a bluetooth OBD II reader and some phone apps, would that suffice?
no, if you want to install anything other than incandescent headlights, you'll need to modify the coding of your BCM
So what will I need to alter the coding?
The tool I personally prefer is VCDS, but something like OBD eleven would also do the trick.
I have an OBD II (eleven as you call it), it is a simple bluetooth one that connects to my phone, unless you know of a specific app on the phone or software on my laptop for doing this.
I see, is your OBD eleven capable of doing coding of control modules?
I don't think so, all it does is connect to my phone or laptop via bluetooth.
Do you have a link for something that I could use? I am not out to spend megabucks lol.
