Armrest USB Ports
Re: Armrest USB Ports
Thank you for your reply. I deduce that it is impossible to order the original cable directly and that I must design it myself with the connector (8K0973754) as well as 4 electrical wires. However, I do not know in which socket I will have to connect these 4 wires because on one side I have the connector which plugs into the USB socket of the armrest but on the other side, where should I connect the wire? Thank you in advance
