Armrest USB Ports
Armrest USB Ports
Hi Guys
I am new here, I was wondering if anyone has fitted the usb hub on the back of the armrest when they have fitted one? Sorry if this has been posted somwhere as I have had a search through and could only find posts on just fitting the armrest.
The question is mainly to do with the wiring is there a retro fit harness or has anyone made one for themselves? I have spoken to my local Tps and my local Vw dealer and they arent really sure what I need. I have access to the wiring diagrams i was just looking for the easiest option for installing them.
I have the part numbers for the Armrest trim, Usb Hub and Usb hub plug if anybody is interested
- OomStu_ZA
- Drives: 2019 VW Polo GTi
Re: Armrest USB Ports
Do you mean an external hub that connects to the rear USB ports?
My vehicle already has USB at the rear but havent tried using an externder hub as yet, not sure if there would be sufficient power to drive more powerful devices.
I am trying to work out how to power the rear usb ports for the armrest as my car didn't have a armrest fitted at the factory so I have retrofitted one and I wanted to add the rear usb ports to
- OomStu_ZA
Understood, sorry I can't assist mate. I thought all GTI's had rear USB from facotry.MD_GTI wrote: Fri Jul 16, 2021 1:58 pm I am trying to work out how to power the rear usb ports for the armrest as my car didn't have a armrest fitted at the factory so I have retrofitted one and I wanted to add the rear usb ports to
For UK Market, the early ones with no GPF didn't have rear USBs.OomStu_ZA wrote: Fri Jul 16, 2021 2:06 pmUnderstood, sorry I can't assist mate. I thought all GTI's had rear USB from facotry.MD_GTI wrote: Fri Jul 16, 2021 1:58 pm I am trying to work out how to power the rear usb ports for the armrest as my car didn't have a armrest fitted at the factory so I have retrofitted one and I wanted to add the rear usb ports to
Andy Beats
How early is early?monkeyhanger wrote: Fri Jul 16, 2021 2:29 pm For UK Market, the early ones with no GPF didn't have rear USBs.
My Gti is September 2020 and doesn't have USB in the back.
Does this mean I don't have a GPF?
Didn't have an armrest either, retrofitted it myself.
When trying to find out the part number for the different trim for the back of the armrest that had the usb charger slot in it there was 2 part numbers one for release to late 2018 and one from then on not sure if that corresponds with when Gpfs where fitted
Is it a GTI+?Andy Beats wrote: Fri Jul 16, 2021 2:39 pmHow early is early?monkeyhanger wrote: Fri Jul 16, 2021 2:29 pm For UK Market, the early ones with no GPF didn't have rear USBs.
Pretty sure the armrest was an added extra for the GTI+.
Andy Beats
There's your answer.
As for the GPF you probably do have it. Don't think there's too many out there without it, unless you got the car very early during its lifecycle.
@S_94 I’d go further and say that Andy’s car will have a GPF. Pretty certain VW fitted GPF’s to the Polo GTI as part of WLTP compliance from late 2018.S_94 wrote: Fri Jul 16, 2021 5:01 pmThere's your answer.
Anything built prior to the mid-July shutdown didn't have a GPF. At that point VW had to get their WLTP compliance sorted. Anything built after that shutdown had a GPF. Cars were getting built in Sep/Oct and then held while the WLTP testing for multiple iterations of optioned cars. They got released in Nov if I remember rightly.SRGTD wrote: Fri Jul 16, 2021 5:23 pm@S_94 I’d go further and say that Andy’s car will have a GPF. Pretty certain VW fitted GPF’s to the Polo GTI as part of WLTP compliance from late 2018.S_94 wrote: Fri Jul 16, 2021 5:01 pmThere's your answer.
GTI+ always had an armrest, only the MY19s and on with GPFs got double USB on the back of the arm rest.
Mike222
- Drives: Tiago R Line (Black edition)
my gti +is a 2020 MY and it has an arm rest and 2 USB ports
Hi, I just came across this forum and I would like to install the USB ports on my Polo which did not have an armrest when I bought it. I currently have the armrest as well as the USB ports but I cannot find the cable to connect these sockets or even a wiring diagram allowing me to know how to connect the sockets. I understand that you have the wiring diagram as well as the serial number of the cables. If you see this message contact by email xxxxxxx or reply to this message if possible. Thank you in advanceMD_GTI wrote: Fri Jul 16, 2021 12:23 pm Hi Guys
USB port 2G6035718 + connecter 8K0973754
Pin 1 permanent power
Pin 2 switched power
Pin 3 illumination
Pin 4 Ground
you can also use switched power (terminal 15/75) on pin 1 and 2. I put one in the car of my partner and i just used terminal 15 for 1-3 and ground for 4.
Pin 3 illumination
Pin 4 Ground
