Brake light sensor issue
Re: Brake light sensor issue
It would be good if someone with this problem actually resolved, ie fixed it and came back with what had caused this problem.
I've seen many SEAT Ibiza owners complaining about this - but no one has returned and said what the root cause of this fault was.
I'm guessing it is a wiring problem where this brake switch wiring passes over the bolt on the chassis leg area, especially for the cars that end up with the brake lights stuck ON and remaining on after the connector has been unplugged from the (hall effect) switch on the brake master cylinder.
sanamkali
Drives: --------
Post by sanamkali »
RUM4MO wrote: Fri Mar 17, 2023 5:43 pm It would be good if someone with this problem actually resolved, ie fixed it and came back with what had caused this problem.
Hey, I've noticed this too! It's baffling how no one's shared the fix yet.WhatsApp Blue Maybe it's time for some detective work to crack this wiring mystery? Let's brainstorm solutions together!
arshu1
Drives: horsepool
Re: Brake light sensor issue[url=https://gbwaplus.org/].[/url]
Post by arshu1 »
A brake light sensor issue can cause your brake lights to stay on constantly or not illuminate at all. This problem is often due to a faulty brake light switch, wiring issues, or misalignment. Replacing the switch or adjusting its position usually resolves the problem. If the issue persists, consult a mechanic to inspect the electrical system.
