Brake light sensor issue
adamswiatek
Drives: Seat Ibiza
Post by adamswiatek »
Hi forum members.
I would like to introduce my problem with car.
I have Seat Ibiza 2013 , today I recognised I lost break light at all. I checked fuse nr 20 which is ok and scanned car with Vagcom which shown no errors.
I heard it could be break light sensor issue but I can not locate it close to break pedal.
Does anybody know where the sensor is located and how to replace it?
Thanks a lot
Re: Brake light sensor issue
if you have vag com you should be able to read the status of the brake light sensor
adamswiatek
Drives: Seat Ibiza
I checked, there was no errors at all in all modules
we're not looking for errors, but simply to see the status of the brake light switch.
adamswiatek
Drives: Seat Ibiza
I understand. How to check it then?
you enter a module with the brake light switch connected. i.e. the BCM. then you go to advanced measurement values, and then select brake light switch. in rest, it should say 'OFF' or 'non activated' and should go to a different state when you push the brake.
adamswiatek
Drives: Seat Ibiza
Hi.
I went to check it again with Vagcom. There was not brake light sensor in BCM module in advanced measurement.
I found sensor in braking system in module ABA/ Brake.
I went to advanced measurements and found sensor in breaking system. I choosen/ticked it from the list and got information about it on screen. The first status was unpushed. When I pushed brake pedal , it changed to pushed status.
I am not really sure if it is that I should check.
Sorry but I have vagcom in Polish only
could you please translate what it means?
adamswiatek
Drives: Seat Ibiza
Yes. First position:
Sensor in braking system unpushed
When I push brake pedal:
Sensor in braking system pushed.
When I push brake pedal , status is changing to 'pushed'
That's likely the pressure sensor in the braking system. Not the electric brake light switch.
sammy21
Drives: playa
Post by sammy21 »
gbwa wrote: ↑
Hi forum members.
Thanks a lot
Be careful on road, it is not safe to drive in this situation.
Maarten
Post by Maarten »
Probably brakelight switch behind pedal defective
In pq25 its located on the master brake cylinder and not on the pedal box.
Maarten
Post by Maarten »
I stand corrected :mrgreen:
Wrong year :oops:
Aava
Drives: TDI
Post by Aava »
adamswiatek wrote: Fri Jan 07, 2022 11:30 pm WhatsApp aero downloadHi forum members.
Thanks a lot
Looks like your car is trying to go incognito mode with no brakes lights! :) But sorry, I'm not much help in finding the sensor. :cry:
