Long code abs
Re: Long code abs
Then I'm out of options, sorry.
Fredydx7
Drives: Polo 2014 1.2
Re: Long code abs
Post by Fredydx7 »
Thanks for your help I think my car will stay like this, I have seen in forums that you are the best at this.
Re: Long code abs
The problem is that it is very difficult to find any reference scan for your polo from Mexico. This if a model that not always follows the normal pattern for coding. Do you have any idea why your coding is lost?
Fredydx7
Re: Long code abs
Post by Fredydx7 »
I lost it when I removed my cluster and put the one on it for a while, they brought it to me because it had some LEDs burned out, I changed them and the problem was good that when I wanted to put mine again it already appeared like this, I did not know what would happen that
Re: Long code abs
Did you put your own original cluster back in?
Fredydx7
Re: Long code abs
Post by Fredydx7 »
if it is the original
Re: Long code abs
I'm sorry I can't make up a valid coding. Best next step is to try the dealership with svm.
Re: Long code abs
Fredydx7 wrote: Tue Jan 11, 2022 7:55 pm if it is the original
If by chance, ever, you made some modification in the long coding of the ABS unit before that IC change, inside the VCDS program there is a folder called "Debug", inside it there is an Excel file with all the changes you have made in codings with your VCDS in any unit of any vehicle.
Look in that file for your ABS unit, there will be your old long coding.
Fredydx7
Re: Long code abs
Post by Fredydx7 »
ciclo wrote: Tue Jan 11, 2022 9:48 pm
thanks for your help, i don't have any previous scan as i was using launch
zmiikata_82
Drives: 6R
Re: Long code abs
Post by zmiikata_82 »
Hallo can some one help me whit long code for abs for polo 1.2tdi 75hp, I have problem whit ECU and I change whit new set (ecu, cluster and bsn) and now I can't code abs to the ecu
Re: Long code abs
Yes it's possible
zmiikata_82
Drives: 6R
Re: Long code abs
You need a full log bro?
Re: Long code abs
Yes, to start with, and it is good to know I'm not able to do these support calculations for free anymore given the time effort it takes to do a manual calculation.
HellBell
Drives: Fabia
Re: Long code abs
Post by HellBell »
Hello there!
I know I am not on the „right” forum, as I am asking about Skoda Fabia Mk2 (even tho its kinda same car) but I am really desperate and so I told myseld I could try it here..
Can anyone of you kind people help me with coding of my new ESP unit? I retrofitted original ABS 8.2 for ESP 8.2i. My problem is that none of the suggested codes did work, I always get this this error in VCDS: Coding denied, error 22.
Current coding of the unit is only zeros.
I tried these codes and few subvariants, i.e.:
410124DB216E00B6822B24E384DA00400000,
or this one from ESP calculator:
410124DB216E00B6822B24E384DA00420700
original ABS code is this one:
400100DB006E00B6022B00E300DA00000000
VIN: TMBEA25J8D3014619. It is LHD, Manual, 2012, CGPB(CGPA), brakes: front 256/rear drum, HHC, TPMS and XDS on (probably). New unit number is 6R0 907 379 AA - it was advertised as for Fabia..
Thanks in advance! Would be really gratefull.
Re: Long code abs
I'm sorry but I will no longer be making ABS/ESP codings for free on the forum.
I put a lot of effort in manually calculating every coding and more often than not I hear nothing back.
Example from last week: viewtopic.php?p=593672#p593672
