Long code abs
Fredydx7
Drives: Polo 2014 1.2
Long code abs
Post by Fredydx7 »
Hello, I have a problem with my long abs code, someone who can help me, please remove my cluster and when I put it, the code 00000000 appeared ... I didn't know what would happen. :(
Fredydx7
Re: Long code abs
Post by Fredydx7 »
Es un polo 2014 1.2 tsi
Re: Long code abs
What tool do you use?
Fredydx7
Re: Long code abs
Post by Fredydx7 »
iichel wrote: Mon Jan 10, 2022 9:33 pm What tool do you use?
Vag com
Re: Long code abs
OK so let's start with basics.
Engine starts and runs?
Autoscan?
Fredydx7
Re: Long code abs
Post by Fredydx7 »
Lunes,10,Enero,2022,16:38:17:00009
VCDS -- Windows-based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: EST 20.12.0.2
Data Version: 20210130 DS322.1
www.vag-com-espanol.com
VIN: WVWCN46R5EY111079 Registration:
Chassis Type 6N0)
See ECUs 01 03 08 09 15 17 19 25 44 56
VIN: WVWCN46R5EY111079 Mileage: 161710km
01-Engine -- Condition: Correct 0000
03-Brakes ABS -- Status: Fault 0010
08-Air conditioning. -- Condition: OK 0000
09-Central electr. -- Status: OK 0000
19-Gateway CAN -- Status: Correct 0000
44-Assist Steering -- Status: Correct 0000 -- Status: OK 0000
56-Radio -- Status: Fault 0010
Address 01: Engine (J623-CBZB) Tags:. EST\03F-906-070-CBZ.clb
Part No. SW: 03F 906 070 HE HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 5459
Version: --H10--- Serial no:
Codificación: 001900D6200400080000
Workshop No.: WSC 00788 648 00255
ASAM Data: EV_ECM12TFS02103F906070HE 004007
ROD: EV_ECM12TFS02103F906070FP.rod
VCID: 6CDD9972878BFEE4CD-8038
No fault detected.
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Tags: EST\6R0-907-37x-ABS82.clb
SW Part No.: 6R0 907 379 AE HW Part No.: 6R0 907 379 AC Part No.: 6R0 907 379 AE HW Part No.: 6R0 907 379 AC
Component: ABS8.2 front H04 0001
Version: --------
Codificación: 000000000000000000000000000000000000
VCID: 0103D8C69C09038C0E-8054
1 Fault detected:
01042 - Control unit not coded.
000 - -
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 18
Meter Resets: 29
Mileage: 161634 km
Time indication: 0
Date: 2016.05.31
Time: 19:48:22
Hex value: 0x0005
Hex value: 0x0000
Hex value: 0x1213
Hex value: 0x149D
Hex value: 0x00FF
Hex value: 0x007F
Hex value: 0x7F00
Hex value: 0x0000
Fredydx7
Re: Long code abs
Post by Fredydx7 »
iichel wrote: Mon Jan 10, 2022 10:42 pm OK so let's start with basics.
Autoscan?
If it turns on perfectly I have no problem, only the abs lights and low rim turn on
Re: Long code abs
Difficult to say, perhaps something like this:
100228E3006E00B3082514E900DA00000000
Fredydx7
Re: Long code abs
Post by Fredydx7 »
says error 22: conditions not correct or request sequence error
Re: Long code abs
ignition on - engine off?
Fredydx7
Re: Long code abs
Post by Fredydx7 »
Yes
Re: Long code abs
next try: 100200E3006E00B3082500E900DA00000000
Fredydx7
Re: Long code abs
Post by Fredydx7 »
says the same
Re: Long code abs
next try: 100200E3016E00B3082500E980DA00000200
Fredydx7
Re: Long code abs
Post by Fredydx7 »
Same :(
