UK-POLOS.NET - THE VW Polo Forum • Long code abs - Page 2
Page 2 of 3
Re: Long code abs
Posted: Tue Jan 11, 2022 4:13 pm
by iichel
Then I'm out of options, sorry.
Re: Long code abs
Posted: Tue Jan 11, 2022 6:34 pm
by Fredydx7
Thanks for your help I think my car will stay like this, I have seen in forums that you are the best at this.
Re: Long code abs
Posted: Tue Jan 11, 2022 6:45 pm
by iichel
The problem is that it is very difficult to find any reference scan for your polo from Mexico. This if a model that not always follows the normal pattern for coding. Do you have any idea why your coding is lost?
Re: Long code abs
Posted: Tue Jan 11, 2022 6:53 pm
by Fredydx7
I lost it when I removed my cluster and put the one on it for a while, they brought it to me because it had some LEDs burned out, I changed them and the problem was good that when I wanted to put mine again it already appeared like this, I did not know what would happen that
Re: Long code abs
Posted: Tue Jan 11, 2022 7:07 pm
by iichel
Did you put your own original cluster back in?
Re: Long code abs
Posted: Tue Jan 11, 2022 7:55 pm
by Fredydx7
if it is the original
Re: Long code abs
Posted: Tue Jan 11, 2022 8:20 pm
by iichel
I'm sorry I can't make up a valid coding. Best next step is to try the dealership with svm.
Re: Long code abs
Posted: Tue Jan 11, 2022 9:48 pm
by ciclo
Fredydx7 wrote: Tue Jan 11, 2022 7:55 pm if it is the original
If by chance, ever, you made some modification in the long coding of the ABS unit before that IC change, inside the VCDS program there is a folder called "Debug", inside it there is an Excel file with all the changes you have made in codings with your VCDS in any unit of any vehicle.
Look in that file for your ABS unit, there will be your old long coding.
Re: Long code abs
Posted: Wed Jan 12, 2022 1:33 am
by Fredydx7
ciclo wrote: Tue Jan 11, 2022 9:48 pm
thanks for your help, i don't have any previous scan as i was using launch
Re: Long code abs
Posted: Thu Apr 14, 2022 9:09 am
by zmiikata_82
Hallo can some one help me whit long code for abs for polo 1.2tdi 75hp, I have problem whit ECU and I change whit new set (ecu, cluster and bsn) and now I can't code abs to the ecu
Re: Long code abs
Posted: Thu Apr 14, 2022 10:15 am
by iichel
Yes it's possible
Re: Long code abs
Posted: Thu Apr 14, 2022 11:18 am
by zmiikata_82
You need a full log bro?
Re: Long code abs
Posted: Thu Apr 14, 2022 12:43 pm
by iichel
Yes, to start with, and it is good to know I'm not able to do these support calculations for free anymore given the time effort it takes to do a manual calculation.
Re: Long code abs
Posted: Sat Oct 15, 2022 4:51 pm
by HellBell
Hello there!
I know I am not on the „right” forum, as I am asking about Skoda Fabia Mk2 (even tho its kinda same car) but I am really desperate and so I told myseld I could try it here..
Can anyone of you kind people help me with coding of my new ESP unit? I retrofitted original ABS 8.2 for ESP 8.2i. My problem is that none of the suggested codes did work, I always get this this error in VCDS: Coding denied, error 22.
Current coding of the unit is only zeros.
I tried these codes and few subvariants, i.e.:
410124DB216E00B6822B24E384DA00400000,
or this one from ESP calculator:
410124DB216E00B6822B24E384DA00420700
original ABS code is this one:
400100DB006E00B6022B00E300DA00000000
VIN: TMBEA25J8D3014619. It is LHD, Manual, 2012, CGPB(CGPA), brakes: front 256/rear drum, HHC, TPMS and XDS on (probably). New unit number is 6R0 907 379 AA - it was advertised as for Fabia..
Thanks in advance! Would be really gratefull.
Re: Long code abs
Posted: Sat Oct 15, 2022 5:32 pm
by iichel
I'm sorry but I will no longer be making ABS/ESP codings for free on the forum.
I put a lot of effort in manually calculating every coding and more often than not I hear nothing back.
Example from last week: viewtopic.php?p=593672#p593672
