Again - auto headlight retrofit. Where to get harness?
wide23
Drives: Polo 6R
Re: Again - auto headlight retrofit. Where to get harness?
Post by wide23 »
Finally I made my cable.
Just for fun a little bit Motorsport technology
Can I ask for help with VCDS coding? As I see manual I need special new coding.
Enable what the arrows indicate:
wide23
Drives: Polo 6R
Post by wide23 »
It works.
Hughe respect and big thanks.
8) 👍
wide23
Drives: Polo 6R
Post by wide23 »
Hi Again,
I have some problems:
1. Front fog lights works but during they are switched on, doesn't light indicator on dashboard. How ever indicator of rotary swith lights correct.
2.Rear fog lights works, indicator on dashboard works but light on rotary swith doesn't work.
3. Full beam headlights work only if I swith lever to my side. If I push it to the front, full beam headlights doesn't work.
I don't know how it works before retrofiting.
Best regards
Lukas
wide23 wrote: Mon Aug 14, 2023 8:45 am Hi Again,
Best regards
Lukas
1 and 2 is correct, it is as it should be.👍
3 for high beams to work permanently (by pushing the lever), the low beams must be ON. ... :?:
wide23
Drives: Polo 6R
Post by wide23 »
ciclo wrote: Mon Aug 14, 2023 7:28 pm 3 for high beams to work permanently (by pushing the lever), the low beams must be ON. ... :?:
Yup, and they didn't work even I switch from Auto position on low beams ON or during night when Auto position of switch turn on the lights.
wide23 wrote: Wed Aug 30, 2023 3:14 pm
I don't understand correctly what you mean due to the tense used, please post a full Autoscan to check BCM coding, etc. if the problem persists and you want me to help you solve the problem.
.. 'they didn't work' or 'they don't work' .. :?:
wide23
Drives: Polo 6R
Post by wide23 »
ciclo wrote: Wed Aug 30, 2023 8:41 pm
Are you asking about this?
Sobota,07,Październik,2023,15:13:24:00001
VCDS -- Emulator VAG/VAS pracujący w środowisku Windows, uruchomiony na Windows 8.1 x64
Wersja VCDS: AKP 17.1.3.0
Wersja danych: 20170621 DS267.7
www.vcds.pl
VIN: WVWZZZ6RZDU042950 Numer rejestracyjny:
Typ podwozia: 6R (6N0)
Skanowanie: 01 03 04 08 09 15 17 19 25 44 55 56 0B
01-Silnik -- Stan: OK 0000
03-ABS/hamulce -- Stan: OK 0000
04-Kąt skrętu kierow. -- Stan: OK 0000
08-Klimatyzacja -- Stan: Usterka 0010
09-Centr.zesp.elektr. -- Stan: OK 0000
15-Airbag -- Stan: OK 0000
17-Zest.wskaźników -- Stan: OK 0000
19-CAN Gateway -- Stan: OK 0000
25-Immobiliser -- Stan: OK 0000
44-Wsp.kierownicy -- Stan: OK 0000
55-Zasięg świateł -- Stan: Usterka 0010
56-Radio -- Stan: OK 0000
Adres 01: Silnik (J623-CBZC) Plik etykiet: 03F-906-070-CBZ.clb
Oznaczenie elementu SW: 03F 906 070 GD HW: 03F 907 309 AJ
Komponent: SIMOS10.22AH10 4039
Weryfikacja: --H10--- Numer seryjny:
Kodowanie: 001100D6200400080000
Kod serwisu: WSC 31414 790 50316
Zbiór danych ASAM: EV_ECM12TFS02013F906070GD 004006
ROD: B/D
VCID: 6ADAFA348D7FE81157-803E
Brak danych ASAM dla: "EV_ECM12TFS02013F906070GD" (VW25)
Nie znaleziono błędów.
Kody gotowości: 0000 0000
Adres 03: ABS/hamulce (J104) Plik etykiet: 6R0-907-37x-ESP90.clb
Oznaczenie elementu SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Komponent: ESP9.0i front H02 0002
Numer seryjny: --------------
Kodowanie: 21DD2885222700C2841D146E445100400904
Zbiór danych ASAM: EV_Brake1ESP90iBOSCH 003020
VCID: 0F2C8BA0D65D6D3960-805A
Adres 08: Klimatyzacja (J255) Plik etykiet: 6R0-907-044.clb
Oznaczenie elementu SW: 6R0 907 044 H HW: 6R0 907 044 H
Komponent: Climatronic H11 0711
Weryfikacja: V0000000
VCID: 387E107C8B538A8111-806C
3 - ilość znalezionych błędów. Oto one:
01271 - Silnik nastawczy klapy temperatury (V68)
000 - - - Sporadyczny
Ramka zamrożona:
Stan błędu: 00100000
Priorytet błędu: 3
Częstość błędu: 1
Wew.licznik błędów: 129
Przebieg: 135271 km
Wskaźnik czasu: 0
Data: 2020.14.23
Czas: 11:16:20
01272 - Silnik nastawczy klapy centralnej (V70)
Ramka zamrożona:
Priorytet błędu: 3
Częstość błędu: 1
Wew.licznik błędów: 108
Przebieg: 171743 km
Wskaźnik czasu: 0
Data: 2056.14.15
Czas: 07:23:47
00710 - Silnik nastawczy klapy rozmrażania (V107)
Ramka zamrożona:
Priorytet błędu: 3
Częstość błędu: 1
Przebieg: 171743 km
Wskaźnik czasu: 0
Data: 2056.14.15
Czas: 07:23:47
Adres 09: Centr.zesp.elektr. (J519) Plik etykiet: 7H0-937-08x-09.clb
Oznaczenie elementu SW: 7H0 937 090 HW: 7H0 937 090
Komponent: BCM PQ25 Max4 H72 0708
Weryfikacja: B9072001 Numer seryjny: 0531 354120253
Kodowanie: 7CB02B3F08A1000001300F916EEB0FD05A40472F60053041200000030000
Kod serwisu: WSC 31414 790 31414
VCID: 6BD4FF308A85F1192C-803E
Podsystem 1 - Oznaczenie elementu: 1K0 955 559 AH Plik etykiet: 1K0-955-559-AG.CLB
Komponent: RLS 280912 05 54 0403
Kodowanie: 06302D
Podsystem 2 - Oznaczenie elementu SW: 6R0 959 801 AB HW: 6R0 959 801 AB Plik etykiet: 6R0-959-801.CLB
Komponent: J386__TSG_FT 008 1611
Numer seryjny: KU0KU019091200016826
Kodowanie: 18BC30
Podsystem 3 - Oznaczenie elementu SW: 6R0 959 802 AD HW: 6R0 959 802 AD Plik etykiet: 6R0-959-802.CLB
Komponent: J387__TSG_BT 008 1611
Numer seryjny: KU0KU024091200014930
Kodowanie: 18BC30
Podsystem 4 - Oznaczenie elementu SW: 6R0 959 811 G HW: 6R0 959 811 G
Komponent: J388__TSG_HL 008 1611
Numer seryjny: KU0KU002111200011081
Kodowanie: 18BC32
Podsystem 5 - Oznaczenie elementu SW: 6R0 959 812 G HW: 6R0 959 812 G
Komponent: J389__TSG_HR 008 1611
Numer seryjny: KU0KU002111200016384
Kodowanie: 18BC32
Adres 15: Airbag (J234) Plik etykiet: 5K0-959-655.clb
Oznaczenie elementu SW: 6R0 959 655 K HW: 6R0 959 655 K
Komponent: VW10Airbag01M H10 0020
Weryfikacja: -------- Numer seryjny: 003GX01J1AHE
Kodowanie: 00314D
Zbiór danych ASAM: EV_AirbaWV10BPAVW250 A01001
ROD: B/D
VCID: 4A9A5AB4EDBF081177-801E
Podsystem 1 - Numer seryjny: 3575HRB400G4UOJAE0O5
Podsystem 2 - Numer seryjny: 3585HRB400M4UNTA9989
Podsystem 3 - Numer seryjny: 3515RRB40084UP68N1BR
Podsystem 4 - Numer seryjny: 3525RRB40084UP68P9B
Brak danych ASAM dla: "EV_AirbaWV10BPAVW250" (VW25)
Adres 17: Zest.wskaźników (J285) Plik etykiet: 5K0-920-xxx-17.clb
Oznaczenie elementu SW: 6R0 920 860 K HW: 6R0 920 860 K
Komponent: KOMBI H05 0605
Numer seryjny: 00000000000000
Kodowanie: 140600
Zbiór danych ASAM: EV_Kombi_UD_SVDD_RM09 A04716
ROD: B/D
VCID: 3C760C6CB76BA6A1F5-8068
Brak danych ASAM dla: "EV_Kombi_UD_SVDD_RM09" (VW36 *)
Adres 19: CAN Gateway (J533) Plik etykiet: 6N0-909-901-6R.clb
Oznaczenie elementu SW: 6N0 909 901 HW: 7H0 937 090
Komponent: GW-K-CAN TP20 H72 0708
Kodowanie: 002200
VCID: 70EEE85CA3A312C119-8024
Adres 25: Immobiliser (J334) Plik etykiet: 5K0-920-xxx-25.clb
Oznaczenie elementu SW: 5K0 953 234 HW: 5K0 953 234
Komponent: IMMO H05 0605
Numer seryjny:
Kodowanie: 000000
Kod serwisu: WSC 00000 000 00000
Zbiór danych ASAM: EV_Immo_DUS_VDD_RM09 A03709
ROD: B/D
Brak danych ASAM dla: "EV_Immo_DUS_VDD_RM09" (VW36 *)
Adres 44: Wsp.kierownicy Plik etykiet: 6Q0-423-156.clb
Oznaczenie elementu: 6R0 423 156 C
Komponent: LenkhilfeTRW V278
Kodowanie: 11250
Kod serwisu: WSC 26471
VCID: 306E285CF72352C159-8064
Adres 55: Zasięg świateł (J431) Plik etykiet: 6R0-907-357.clb
Oznaczenie elementu SW: 6R0 907 357 HW: 6R0 907 357
Komponent: LWR-ECU H02 0070
Weryfikacja: -------- Numer seryjny: --------------
Kodowanie: 0112000001000000
Zbiór danych ASAM: EV_HeadrLegulVWLWRPt 001004
ROD: B/D
VCID: 77FCD340CECD45F9D8-8022
Brak danych ASAM dla: "EV_HeadrLegulVWLWRPt" (VW25)
Znaleziono 1 błąd:
13705985 - ROD - Nieznany kod błędu
- 00 [008]
Sporadyczny - Potwierdzony - Testowany od skasowania kodów błędów
Ramka zamrożona:
Stan błędu: 00000001
Priorytet błędu: 6
Częstość błędu: 25
Wew.licznik błędów: 131
Przebieg: 172410 km
Data: 2120.14.31
Czas: 19:09:57
Adres 56: Radio (J503) Plik etykiet: 5M0-035-1xx-56.clb
Oznaczenie elementu SW: 5M0 035 186 J HW: 5M0 035 186 J
Komponent: Radio RCD310 042 0082
Weryfikacja: 01000001 Numer seryjny: VWZ1Z2M4714512
Kodowanie: 05000400020001
VCID: 33642750923569D924-8066
Koniec --------------------(Skanowanie trwalo: 02:53)----------------------
ciclo wrote: Wed Aug 30, 2023 8:41 pm.. 'they didn't work' or 'they don't work' .. :?:
don't work, sorry.
Best regards
Lukas
To make High beam work, try this new BCM coding:
7CB02B3F08A1000001300F916EEB0FD05A40672F60053041200000030000
viewtopic.php?p=598823#p598823... 🤷‍♂️
wide23
Drives: Polo 6R
Post by wide23 »
ciclo wrote: Sat Oct 07, 2023 6:05 pm To make High beam work, try this new BCM coding:
Interesting. I verified all checkboxes and I had choosed as you showed. So I putted your new coding and works now. Why?
P.S
Chapeau bas once again.
When you copy the BCM coding from the forum it is associated with a completely free magic seed for activating high beams. It is uk-polos.net's way of thanking you for the trust placed in this magnificent forum. :wink:
Now seriously, Byte18 Bit5 enable, or Byte18 from 47HEX to 67HEX.
wide23
Drives: Polo 6R
Post by wide23 »
ciclo wrote: Sat Oct 07, 2023 7:48 pm When you copy the BCM coding from the forum it is associated with a completely free magic seed for activating high beams. It is uk-polos.net's way of thanking you for the trust placed in this magnificent forum. :wink:
Now it's clear :lol:
ciclo wrote: Sat Oct 07, 2023 7:48 pm Now seriously, Byte18 Bit5 enable, or Byte18 from 47HEX to 67HEX.
I was there but I had a list without this option to choose.
Another topic:
Can I setup more parameters to display?
I have cruise time only and outside temperature.
Dot
Dot
With your MFD-low, if you have or install :arrow: viewtopic.php?t=65096 the right stalk/lever with the TRIP - OK/Reset switches you can access some more information.
:arrow: :arrow: https://www.team-bhp.com/forum/diy-do-y ... st3484474🙏
With a new IC with MFD-High and a multifunction steering wheel*/*2 you will have access to more information and menus.
* Several models. Configuration depending on the year of construction.
*2 Everything has dependencies, do not purchase parts without properly informing yourself of what is possible.
wide23
Drives: Polo 6R
Post by wide23 »
ciclo wrote: Fri Oct 13, 2023 6:40 pm With your MFD-low, if you have or install :arrow: viewtopic.php?t=65096 the right stalk/lever with the TRIP - OK/Reset switches you can access some more information.
I dont have column swith like this. So I have to switch it to 6Q0953503EE or 6Q0953503EH (DT, EJ?) (with cruise control)?
Does it require any other mods (say nothing of coding) if I want to keep MFD-low?
Regards
Lukas
