Retrofit of the electric power steering from polo AW into polo 6R =)
til3tsio
Drives: Seat Toledo KG
Re: Retrofit of the electric power steering from polo AW into polo 6R =)
Post by til3tsio »
There are some options that could work,
I am afraid that my ABS would limit them though.
Shadow109
Drives: Vw t5.1 2013
Post by Shadow109 »
Well done, I already got this unit but I am afraid its alot more complicated to install it on a transporter
sejuani
Drives: POLO 6R
Post by sejuani »
til3tsio wrote: Mon Sep 09, 2024 7:31 pm
from now on you have to do everything in VW EOL mode using 28183 login code.
go to flasher and select dsdl2 option and flash system parameters
after off/on ignition repeat the procedure with steering maps
After off/on ignition again go in adaptations and change
Plausibility check to Disabled
Characteristic curve of steering assistance to Dynamic
Driving profile switchover to Direct: controlled over threshold value
I also encountered the same problem during the calibration process of the 2QD 909 144 steering rack.
This method also applies to the calibration of the 2QD steering rack.
Thanks so much!
Address 44: Steering Assist (J500)       Labels:. 2Qx-909-144-V3.clb
   Part No SW: 2QD 909 144 F    HW: 2QD 909 144 A
   Component: EPS_ECU       420 4220
   Serial number: 000009.12.21000 Dataset Number: V03935307HU 0001
   Coding: 00000000010000000000020101000100000001000002
   ASAM Dataset: EV_SteerAssisNSKGEN3MQB 003008
   ROD: EV_SteerAssisNSKGEN3MQB_VW25.rod
   VCID: 489505E2F3B3F2DB48-801C
No ASAM data for: "EV_SteerAssisNSKGEN3MQB" (VW25)
