Where do i get an ABS code to link new part to the car?
Canary1902
Drives: Polo 1.2 TDI 6R
Re: Where do i get an ABS code to link new part to the car?
Post by Canary1902 »
iichel wrote: Mon Feb 23, 2026 1:16 pm I can but it's not for free I'm afraid.
Not a problem - can you message me privately?
Canary1902
Thanks for the message - I cant respond as I havent posted enough in the forum apparently. My email is [redacted]
Not sure if presenting it that way will stop the bots spamming me!
Thanks in advance
Canary1902
Ha ha that didnt work very well!
With 10 posts on the forum, any user can send PMs to whomever they want and post Autoscans.
By ciclo. Emperor of the minuscule.
MrCollayder
Drives: Polo 614 sedan (cczb+dq250 awd+pq35)
Post by MrCollayder »
ciclo wrote: Sat Feb 28, 2026 9:37 am
MrCollayder wrote: Thu Feb 26, 2026 8:19 am More information about ESP8.2 is here as usual.
Use google translate or similar
Hey, do you remember if anyone on Drive2.ru made a 'Frankenstein' firmware or was able to load firmware from an A1 onto the following hardware?
Address 03: ABS Brakes (J104) Labels:. User\6R0-907-37x-ESP82.lbl
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
The goal is for these units to be able to read the wheel rotation direction signals with the new ABS speed sensors.
The AI ​​says someone from Drive2.ru did it, but I can't find the thread.🤷‍♂️ (FW: 8X0907379H or J)
:lol:
Hi! I tried to flash it 2 times, but both were unsuccessful... and there is another problem. With 8X0 fw you need to change 7th and 8th symbols of VIN in the dash from 6R to 8X to enable coding. So I think that it's easier to retrofit ATE mk60ec1 ABS unit with the same VIN manipulation)) mk60ec1 much better than esp8.2 even with A1 fw))
Hey, thank you so much for your input!
I'll keep your advice in mind for future actions.👍
