Where do i get an ABS code to link new part to the car?
Canary1902
Drives: Polo 1.2 TDI 6R
Post by Canary1902 »
Hi
I bought my daughter a 1.2 TDI 6R RHD 55KW Polo CFWA. The abs light was on but i figured it was an easy fix... mechanic I took it to says that the ABS pump has been changed and not coded to the car. I can see from threads below that codes are available but I dont know where to get them or can anyone help me out? The VIN is WVWZZZ6RCUO34751
Thanks in advance
Re: Where do i get an ABS code to link new part to the car?
Canary1902 wrote: Fri May 30, 2025 10:32 am Hi
Thanks in advance
Well you need to write the model of your abs pump
Front brake size, rear brake size, gearbox, lhd, rhd...
esp? Tire pressure?
You will need a diagnostic tool, to input the coding for abs. I will probably take a few attempts.
And please dont be like most of users, get get the code, fix the problem and dont post results.
It really helps us all, with feedback on given information.
Canary1902
Thanks for your response
its RHD, 15" tyres, manual, cant see ESP but does have traction control
Thats as much as i know...
WVWZZZ6RZCU034751
looks like Bosch ESP8.2i
Doors
0A2
4 doors
Front stabilizer bar
0AQ
Rear stabilizer bar
0BA
Without rear stabilizer bar
CO2 variant
0C0
Standard
Vehicle class differentiation
powertrains/platform parts
0DF
Vehicle class differentiation - 6R0-
for build status Europe
Installation differentiation for
vehicle parts
0EJ
transmission MQ 250
-- vehicle components --
Fuel systems
0F5
Fuel system for diesel engine
Differentiation for manufacturing
process
0FV
South Africa manufacturing sequence
Labels (customer specific or campaigns)
0KA
Without decals and emblems
Rear axle
0N2
Heavy-duty rear axle
Tailpipes
0P0
Rear exhaust tailpipe (standard)
Ignition locking system/electronic
steering column lock
0RA
Without ignition/starter switch locking
system
Special labels
0SS
Labels in English and French
foot mats
0TA
without foot mats
Owner's manuals
0VF
Information kit in English
Climate zones
0Y1
Standard climatic zones
Weight category for rear axle
0YL
Weight range 11
installation control only, no
requirement forecast
Brake systems
1AT
Electronic stability control (ESC)
Antifreeze agent
1C1
Antifreeze up to -25 degree Celsius
tolerance up to -30 degree C
Trailer hitch
1D0
Without trailer hitch
Nameplate set
1DG
Nameplate set "TDI"
Activated carbon canister/gasoline
particulate filter
1E0
Without activated carbon canister
Identification labels
1EX
Special identification label for EC
for M1 passenger vehicles
Spare wheel/breakdown kit
1G1
Space-saving spare wheel
Shock absorption in rear
1JA
Rear shock absorption, basic version 1
Rear brakes
1KM
Drum brakes in rear
Air filter (engine)
1L0
Standard air filter
Steering wheels
1MH
Leather-wrapped steering wheel
Steering system
1N2
servo steering, electro/hydraulic
Wheel trims
1NL
Trims for alloy wheels
Lockable wheel bolts
1PE
Wheel bolts with anti-theft protection
(unlockable)
Counterweights for steering wheels
1Q0
steering wheel without balance weight
Vehicle tools and jack
1S1
Front-end underbody cladding
1SA
Without additional front underbody guard
First aid kit/warning triangle
1T0
Without first aid kit and warning
triangle
Cool box
1W2
Glove compartment cooling system
Fuel filling volume
1Z2
Increase in initial standard fuel
filling
Front brakes
1ZG
Disc brakes in front (Geomet D)
Delivery equipment
2A8
Delivery equipment, water border
Steering column systems
2C5
Axial and vertical adjustable steering
column
Tank filler neck for unleaded fuel/fuel
type
2G5
Filler neck module 1 without insert
Bumper
2JF
Painted bumpers
Fuel tank material treatment
2LB
Fuel tank with special material
treatment
Loading edge protector
2P1
Plastic loading edge protection
Fresh air intake for vehicle interior
(with particle filter)
2V1
dust and pollen filter
Additional tires (snow tires)
2WA
without spare tyre
Additional child seat anchorage
3B3
Child seat anchors
Center seat belts in rear
3C7
Three-point inertia reel belt for rear centre seat
Roof insert/convertible top
3FA
Without roof insert (standard roof)
Luggage/load compartment floor in rear
3GD
Plane luggage/load compartment floor
in rear
Backrest release
3H0
Without backrest release for front seats
Head restraints
3J1
Hight-adjustable head restraints for
front seats
Seat adjustment
3L3
Manual height adjustment for front seats
Special approval measures
3M0
Without special measures
Rear seats
3NC
Rear bench seat/backrest, split folding
Brackets
3P1
Bracket for first aid kit and warning
triangle
Head restraints in rear
3Q6
3 rear head restraints
Roof rails/roof rack
3S0
Without roof rails/roof load rack
Luggage compartment cover
3U1
Folding trunk cover
Sound insulation measures for interior
noises
3W3
Special interior noise insulation
Outer seat belts in rear
3ZB
3-point seat belts, outer rear with ECE
label
seat heater
4A0
without seat heater
Door and side trim panels
4AU
door and side trim panels
Door and tailgate/trunk lid locking
mechanism
4K3
Central locking w/ radio remote control,
interior controls and SAFELOCK
Side and rear windows
4KF
heat protective glass for door, side and rear
windows, darkened from b-pillar
Breakaway interior rearview mirror
4L2
Breakaway interior rearview mirror,
dimming
Controls (steering wheel/steering column)
4LN
Multi-function module radio control
Beverage holders
4M0
Without beverage holder
Dashboard
4N2
Instrument panel
standard
Rear floor panel platform module
4P2
Rear floor panel module, type 3
Restraint systems in front
4QV
3-point seat belts in front, with
electric pretensioner and height
adjustment
Window regulator
4R3
Power windows with comfort operation
Vanity mirror on the left
4SD
Left vanity mirror, illuminated
Vanity mirror on the right
4TD
Right vanity mirror illuminated
Luggage net/bag on backrest(s)
4U5
Luggage pockets on backrests
Airbag
4UE
Airbag for driver and front passenger
Side airbag
4X1
Side airbag in front
Luggage compartment trim
5A6
Full nonwoven luggage compartment trim
Body measures
5C6
Additional measures for the body
Carrier frequency for remote control
5D1
Carrier frequency 433.92 to 434.42 Mhz
Paint preservation/transport protection
5K7
Transport protection film (minimum
protection) with additional transport
protection measures
Right exterior mirror
5RV
Right exterior mirror, aspherical
Left exterior mirror
5SJ
Left exterior mirror, convex
Fire extinguisher
6A0
without fire extinguisher
Center armrest
6E0
Without center armrest in front
Additional body protective covers, side
6EA
Without additional side body covers
(stone guard)
Components with special surfaces
6FF
Exterior mirror housing and various attachments
colour coded to vehicle
Radiator grille
6KC
Radiator grille
Molded headliner
6NA
Unsplit molded headliner
Rear license plate carrier
6P1
Rear license plate carrier (ECE)
Hand brake lever
6PC
Hand brake lever handle in leather
Gearshift knob/gearshift handle
6Q2
Gearshift knob/handle in leather
Gearshift boot/gearshift trim
6R1
Leatherette gearshift lever boot
Luggage compartment floor covering
6SC
Luggage compartment floor covering in
needle-punched nonwoven
Interior lighting in footwell
6T0
Without interior light in footwell
License plate carrier in front
6W1
Front license plate carrier (large)
Exterior mirror adjustment
6XD
Exterior mirrors, power-adjustable/
heated
Speed alert system/speed limiter
6Y0
Without speed warning system
CD changer/CD player
7A0
Without CD changer/CD player
Theft protection system
7AA
Electronic immobilizer
Outlet
7B0
without electrical socket
Thermal energy storage system/auxiliary
heater
7E6
Electric auxiliary air heater
Tire pressure monitoring system
7K6
Start-stop system/regenerative braking
7L3
Without start-stop system without
Scuff plates
7M5
Without impact protection film for door sill
Emission standard
7MG
Emission standard EU5
Lumbar support in backrests
7P0
Without lumbar support
in seat backrests
Platform group class
7PA
Platform group class 1
Navigation system
7Q0
not with navigation system
CD-ROM/DVD/SD card
7QA
Without CD/DVD for navigation
Dashboard illumination
7V1
Standard dashboard illumination
Park distance control
7X0
Without park distance control
Radios
8AE
Radio "RCD310 MP3"
Main headlamps
8BK
Twin headlamps for driving on the left,
with integrated high beam
Speedometer cable and seal
8CC
Speedometer sensor without seal
(electronic speedometer sensor)
Alternators
8GU
Alternator 140 A
Wiper and washer system for rear windows
8M1
Rear window wiper washer system with
intermittent wipe
Intermittent windshield wiper control/
light/rain sensor
8N4
Windshield wiper intermittent control
with potentiometer (four speeds)
Headlight range control
8Q1
Loudspeaker installation
8RL
6 speakers (passive)
reading light
8S3
Additional reading lights in rear
Rear combination lamps
8SG
Rear combination lamps, standard design
(type 2)
cruise control system
8T0
Without cruise control system (CCS)
rear fog lamp
8TD
Rear fog lamp for driving on the left
Washer fluid level indicator
8W0
not with washer fluid level indicator
Front fog lamps/additional headlamps
8WB
Front fog lamps
Headlamp washer system
8X0
Without headlamp washer system
Horns
8Y1
Two-tone horn
Engine cooling
8Z5
not hot country
Antennas
8ZH
Antenna for AM/FM reception, "diversity"
Heating system/air conditioning system
9AB
Manually controlled air conditioning
system
Luggage compartment lighting
9E1
Interior light in cab
9GA
Interior light with contact switches on
the doors
Headlight control
9I0
Low beam as daytime running light
Smoker's/non-smoker's version
9JA
Non-smoker version
Seat belt reminder
9P3
Seat belt reminder, electric contact in
buckle
Multi-function display/trip computer
9Q1
Heated washer nozzles
9T0
Without heated washer nozzles
Brake pad wear indicator
9U0
without brake wear indicator
Telephone/telematics
9W0
Without car phone preparation/
installation
Multimedia/video/DVD/notebook connection
9WL
Jack for external audio source
Equipment lines
A8M
high luxury equipment level
Vehicle type
AZ0
Vehicle with production equipment
Type-approval testing countries/
countries with specific requirements
B09
Type approval country GB/Northern
Ireland
Part set for country-specific
prescriptive standards
B0N
Part set, complying with
vehicle type for Great Britain, various
parts
General operating license additions
C10
Operating permit, alteration
Wheels
CJ5
Alloy wheels 6J x 15
Engine specification
D28
3-cyl. diesel engine 1.2 l/55 kW (4V)
TDI common rail
base engine is TS4/TK4
Special editions
E0A
no sales compaign version
Follow-on warranty
EA0
Without follow-on warranty
Vehicle specifications
F0A
No special purpose vehicle, standard
equipment
Customized installation
FC0
Without customized installation
Transmission specification
G0C
5-speed manual transmission
Shock absorption in front
G10
Tires 215/45 R16 86V
H8E
Tires 185/60 R15 84T
Batteries
J0N
Battery 330 A (61 Ah)
Body forms
K8G
Hatchback
License plate lighting
KL0
Standard license plate lighting
Steering system setup
L0R
Right-hand drive
Weight category for front axle
L40
Suspension range 40
Seat trim covers
N0J
Seat trim covers in knit velour
Battery/alternator capacities
NY0
Standard battery/alternator capacity
P02
"Riverside" alloy wheels GB,France
PH4
Air conditioning
PJZ
Spare wheel with original equipment
tire, steel for 15-inch, 16-inch and
17-inch alloy wheels
PU2
Multifunction leather steering wheel
(3-spoke) with decorative matte chrome
inserts
Front seats
Q1A
Standard seats in front
LongLife Service Regime
QG1
Chrome package
QJ1
Chrome package
Drawers under front seats
QN0
Without drawers under front seats
TV reception/digital radio reception
QV0
Without TV reception/digital radio
reception
RGZ
"Radio RCD 310"
Base engine
TS4
3-cylinder diesel engine 1.2 l
unit 03P.A
Dashboard inserts
U0L
Instrument cluster with tachometer,
clock and mph speedometer
Electric interface for external use
UF6
(MEDIA-IN jack)
Hill start assist
UG1
Hill start assist
Tire suppliers
V0A
Tires without specification of tire
brand
Pedal cluster
VF0
Foot pedal unit"standard"
Ventilation duct in front
VK0
Air duct, standard
Pedestrian protection
VL1
Extended pedestrian protection
W4B
4-door, including electric window
lifts,front and rear
WYG
"Match" mandatory condition with 8WH
country: GB
WYH
"Match 2" mandatory condition with P02,
PH1 country: GB
Canary1902
Thank you - that is most helpful.
Can anyone supply the code given this - or where can I go to get it - i assume the dealership will mug me off unless they replace it?
The dealer can program it in minutes. They might charge you 1hr of labor, or diagnostic cost. Best to give them a call, and explain that you need abs pump to be coded to the car.
Unless you can get a diagnostic tool that can read the pump, hex can, launch, obd11, vas5054a- etc. There are many.
Canary1902
Hi
The local mechanic has said he will do it for free - but neds the code to input it- if that makes sense?
Try maybe, wait there might be someone else to provide the code. then bring it all and try.
if its esp8.2i
210224C2217000B6842C24E784D200520000
210224C2217000B6842C24E784D200520200
if its esp 9.0i
21DD2C85212600C4841B346E845200521401
21DD2C85212600C4841B346E845200521501
21DD2C85212600C4841B346E845200521505
21DD2C85212600C4841B346E845200521400
or
41DC2C7D222608C4821B346E445210521501
41DC2C7D222608C4821B346E445210521401
41DC2C7D222608C4821B346E445210521400
Canary1902
Thank you I will try and report back!
Much appreciated! :D
Canary1902
OK its 9 months later and now the MOT is due and I have tried the codes you guys kindly provided - is tehre any way of finding out? Lucj=kily she still has not passed her test - but the rest is in a month and she wiull defo need ABS!
Thanks in advance for any replies
Canary1902
iichel wrote: Fri May 30, 2025 12:09 pm WVWZZZ6RZCU034751
Doors
0A2
4 doors
0AQ
Rear stabilizer bar
0BA
CO2 variant
0C0
Standard
0DF
vehicle parts
0EJ
transmission MQ 250
Fuel systems
0F5
process
0FV
0KA
Rear axle
0N2
Tailpipes
0P0
0RA
system
Special labels
0SS
foot mats
0TA
without foot mats
Owner's manuals
0VF
Climate zones
0Y1
0YL
Weight range 11
Brake systems
1AT
Antifreeze agent
1C1
Trailer hitch
1D0
Nameplate set
1DG
Nameplate set "TDI"
particulate filter
1E0
1EX
1G1
1JA
Rear brakes
1KM
Drum brakes in rear
Air filter (engine)
1L0
Standard air filter
Steering wheels
1MH
Steering system
1N2
Wheel trims
1NL
1PE
(unlockable)
1Q0
1S1
1SA
1T0
triangle
Cool box
1W2
Fuel filling volume
1Z2
filling
Front brakes
1ZG
Delivery equipment
2A8
2C5
column
type
2G5
Bumper
2JF
Painted bumpers
2LB
treatment
2P1
2V1
2WA
without spare tyre
3B3
Child seat anchors
3C7
3FA
3GD
in rear
Backrest release
3H0
Head restraints
3J1
front seats
Seat adjustment
3L3
3M0
Rear seats
3NC
Brackets
3P1
triangle
3Q6
3S0
3U1
Folding trunk cover
noises
3W3
3ZB
label
seat heater
4A0
without seat heater
4AU
mechanism
4K3
4KF
4L2
dimming
4LN
Beverage holders
4M0
Dashboard
4N2
Instrument panel
standard
4P2
4QV
adjustment
Window regulator
4R3
4SD
4TD
4U5
Airbag
4UE
Side airbag
4X1
5A6
Body measures
5C6
5D1
5K7
protection measures
5RV
5SJ
Fire extinguisher
6A0
Center armrest
6E0
6EA
(stone guard)
6FF
Radiator grille
6KC
Radiator grille
Molded headliner
6NA
6P1
Hand brake lever
6PC
6Q2
6R1
6SC
6T0
6W1
6XD
heated
6Y0
7A0
7AA
Outlet
7B0
heater
7E6
7K6
7L3
Scuff plates
7M5
Emission standard
7MG
7P0
in seat backrests
7PA
Navigation system
7Q0
CD-ROM/DVD/SD card
7QA
7V1
7X0
Radios
8AE
Radio "RCD310 MP3"
Main headlamps
8BK
8CC
Alternators
8GU
Alternator 140 A
8M1
intermittent wipe
light/rain sensor
8N4
8Q1
8RL
reading light
8S3
8SG
(type 2)
8T0
rear fog lamp
8TD
8W0
8WB
Front fog lamps
8X0
Horns
8Y1
Two-tone horn
Engine cooling
8Z5
not hot country
Antennas
8ZH
9AB
system
9E1
9GA
the doors
Headlight control
9I0
9JA
Non-smoker version
Seat belt reminder
9P3
buckle
9Q1
9T0
9U0
9W0
installation
9WL
Equipment lines
A8M
Vehicle type
AZ0
B09
Ireland
B0N
parts
C10
Wheels
CJ5
D28
TDI common rail
Special editions
E0A
Follow-on warranty
EA0
F0A
equipment
FC0
G0C
G10
H8E
Batteries
J0N
Body forms
K8G
Hatchback
KL0
L0R
Right-hand drive
L40
Suspension range 40
Seat trim covers
N0J
NY0
P02
PH4
Air conditioning
PJZ
PU2
inserts
Front seats
Q1A
QG1
Chrome package
QJ1
Chrome package
QN0
QV0
reception
RGZ
"Radio RCD 310"
Base engine
TS4
unit 03P.A
Dashboard inserts
U0L
UF6
(MEDIA-IN jack)
Hill start assist
UG1
Hill start assist
Tire suppliers
V0A
brand
Pedal cluster
VF0
VK0
Air duct, standard
VL1
W4B
WYG
country: GB
WYH
PH1 country: GB
|Hello mate - please can you build a code from that - i have tried to download one on an Autel and it keeps coming back with "Conditions not Meet"? Many thanks in advance
I can but it's not for free I'm afraid.
MrCollayder
Drives: Polo 614 sedan (cczb+dq250 awd+pq35)
Post by MrCollayder »
If you find vcds, you should use custom lbl file for esp8.2 coding.
Here you can download zip with lbl's for lots of different ABS types. Of course, you need 6Rx-907-37x-ESP82.lbl
Replace lbl with xml and put it into %vcds%\datadb\user
Than try it
MrCollayder
More information about ESP8.2 is here as usual.
Use google translate or similar
MrCollayder wrote: Thu Feb 26, 2026 8:19 am More information about ESP8.2 is here as usual.
Hey, do you remember if anyone on Drive2.ru made a 'Frankenstein' firmware or was able to load firmware from an A1 onto the following hardware?
Address 03: ABS Brakes (J104) Labels:. User\6R0-907-37x-ESP82.lbl
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
The goal is for these units to be able to read the wheel rotation direction signals with the new ABS speed sensors.
The AI ​​says someone from Drive2.ru did it, but I can't find the thread.🤷‍♂️ (FW: 8X0907379H or J)
:lol:
