Page 11 of 13
Re: Bixenon headlights with AFS For polo gt Tsi 2015
Posted: Tue Nov 13, 2018 4:30 pm
by hmthakur
In which slot should i put SB44b to convert this wire loom to +15 switching off through ignition??
Posted: Tue Nov 13, 2018 6:13 pm
by ciclo
Posted: Wed Nov 14, 2018 12:10 am
by hmthakur
ciclo wrote:
Thanks master [emoji1303]
Posted: Thu Nov 15, 2018 12:23 pm
by hmthakur
If supply 12v to tpms receiver via +15 (supply through ignition will it work?? Or the tpms requires supply from +30 ( directly from battery)
Posted: Thu Nov 15, 2018 7:23 pm
by ciclo
+30 is how it should be.
Posted: Fri Nov 16, 2018 4:49 am
by hmthakur
If i install tpms to Sb44b will it work??
Posted: Fri Nov 16, 2018 5:17 am
by ciclo
Yes!!
Posted: Fri Jan 18, 2019 6:49 pm
by BlueEyesGT
hmthakur wrote: Mon Jan 01, 2018 2:54 pm
master ciclo,
will this receiver and valve sensors work with tpms of my car.
IC software = 0705 or higher
BCM = 7E0 937 090B or higher
TPMS unit = 3AA 907 273 F
Sensors/valves = 3AA 907 275 F
have installed gti cluster 6RD920870A, ic software:-0805
Already posted latest vcds scan
hi hmthakur
I have Polo GT TSI(2015 MY). I am planning to change the stock cluster from my car to the GTI maxi dot cluster and I noticed you have upgraded MFD on your car which has the same part # 6RD920870A as what seller here in Bangalore has shown me. Upon searching further I see that this particuler cluster was installed in cars sold in China. I am just being little cautious here before investing to make sure that I am paying for the right product and wanted to know from you, since you have it installed. I believe it''s matter of upgrading to the right software but seeking little more clarification here. Moreover, I am little confused to understand the difference between 6RD920870
A and 6RD920870 (this one is installed in this Indian Polo GT:
https://goo.gl/gpq1VX)
Would highly appreciate your quick reply before I commit to this seller, thanks!!
Posted: Fri Jan 18, 2019 9:19 pm
by ciclo
I also have the A model installed, it has the updated software (which is better in case of future retrofits), works wonderfully once it's adapted.
The Gannu thread warns you of everything you need to know.
Posted: Sat Jan 19, 2019 5:44 am
by BlueEyesGT
ciclo wrote: Fri Jan 18, 2019 9:19 pm
Thank you so much for the reply
I will go ahead with the purchase, on similar note would it be possible to have direct TPMS just by adding TPMS module along with new cluster or do I have to upgrade the BCM from stock (6R0 937 087)?
Also, I am planning for GTI steering with paddles along with maxi dot cluster. Sellers here are quoting exorbitant prices!! An ebay seller (from Maxico, from whom many in India have successfull installations) looks like he has shut shop, would be great if you or someone from forum give some pointers to source the steering.
hmthakur, could you please post here about your GTI steering? where was this sourced from?
Huge thanks again, am very excited for upcoming upgrades on my ride
Posted: Sat Jan 19, 2019 6:37 am
by hmthakur
Hi blueeyes
Sourcing gti cluster is not a problem but for installation you would have to go to VW service centre.
Even I had sourced one from China through Taobao. Got it installed in Vw service.
As per my knowledge you can activate TPMS with existing bcm and upgrading to gti cluster, just check that cluster has software 0805. Master cicolo could answer it correctly.
I had got my steering from GCP Tunning. It seems their website doesn’t work any more. So can’t help you their.
Posted: Sat Jan 19, 2019 12:04 pm
by BlueEyesGT
hmthakur wrote: Sat Jan 19, 2019 6:37 am
Hi blueeyes
Understood, person I am purchasing it from had done this earlier from his contacts at VW service center, so that should take are of it.
I will patiently wait for his response before commiting to this project. Unless it involves BCM upgrade I definitely want to get it done.
I will try my luck with other vendors and keep looking up online.
Thank you so much for your response.
Posted: Sun Jan 20, 2019 4:16 am
by ciclo
BlueEyesGT
Direct TPMS ---> Address 65 must be present in the Gateway installation list.
VCDS: gateway, installation list, search for 65 address.
The BCM has to be changed if it is not present.
Recommendation: open a new personal thread in 6R section, post Autoscan, pics from your car, links, etc... that is, the information that you consider most appropriate to receive help.
For the GTI steering wheel with paddles search on eBay o googled ...
vagretrofit..., maybe they have what you are looking for. I do not know if they ship to India. (without airbag and with the appropriate buttons about € 300)
Posted: Mon Jan 28, 2019 5:21 pm
by hmthakur
download/file.php?mode=view&id=2050
are these pins of same size?? name of the pins and size??
Posted: Mon Jan 28, 2019 7:01 pm
by ciclo
NO
SB60 = SPT Standard Power Timer
SB5/6 = JPT Junior Power Timer
They're usually the most common.
