Favi's Polo 6R 1.2TSI Red Flash "strawberry" :)
favi
Drives: 6R
Re: Favi's Polo 6R 1.2TSI Red Flash "strawberry" :)
Post by favi »
New bumper but... 1 error on IC - bulbs error
turned off the option: front fog instaled and cornering via indicator (09 ELECTRIC VCSD)
0 faults, but error on Instrument Cluster ;/
What bulbs are you using for the front fog lights?
Are your front fog lights connected to the BCM? (9b,10b -11b).
favi
Drives: 6R
Post by favi »
ciclo wrote: Sun Sep 10, 2023 8:57 pm What bulbs are you using for the front fog lights?
I don't have front fog light (WRC bumper don't have place for it) - so now i decoded front fog lights and cornering
I'm working on a housing prototype for fog lights (3D model printer).
I did it when i made HBA.
Before replace bumper - FOG LED bulmps work perfectly - no errors.
favi wrote: Mon Sep 04, 2023 9:56 pm
ciclo wrote: Mon Sep 04, 2023 6:57 am Nice look. 8) 👍
The front fog lights + SCLs disappeared... 😄
Yes but... comming soon back :)
I was thinking that you were going to install them...
Maybe I didn't understand it well, you are sparing in words... :lol:
maybe you need to disable the function in byte21 bit3.
Post an auto scan....
favi
Drives: 6R
Post by favi »
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 37 44 55 5F 77
VIN: WVWZZZ6RZBY
20-High Beam Assist. -- Status: Malfunction 0010
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 D    HW: 03F 906 070 D
   Component: SIMOS10.20H02 9851
   Revision: --------    Serial number:
   Coding: 001900D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070D 003015
   ROD: EV_ECM12TFS02103F906070BQ_003.rod
   VCID: 23455A8B2AD5F19E36-8076
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3217500B7842814E484DA00401300
   Shop #: WSC 27514 001 1048576
   VCID: 071D2E1BB22D3DBE4A-8052
   Component: LENKW.SENSOR  H06 0070
   Serial number: 15031304651874
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF34BFFE1F77C7679-802A
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
   Part No SW: 6R0 820 045 G    HW: 6R0 820 045 G
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 326BAFCF6D2F6816CD-8066
   Revision: B9080001    Serial number: 0771 071161174
   Coding: 2CB02BBF48E1240093380E007CCB1FD0C0C0670F604939E0210000030820
   Shop #: WSC 02737 022 157175
   VCID: 68DF0DA79B73D2C6A3-803C
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 170117 04  42  0106
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8610
   Serial number: KU0KU010091300015333
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8610
   Serial number: KU0KU006091300015370
   Coding: 1000AB
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 5G0 959 442 L    HW: 5G0 959 442 L
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29160003417360027086
   Coding: A40000
   Subsystem 7 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  007 1611
   Serial number: KU0KU015031100013211
   Coding: 08BC32
   Subsystem 8 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  007 1611
   Serial number: KU0KU014031100013620
   Coding: 08BC32
1 Fault Found:
01134 - Alarm Horn (H12)
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 236
                    Mileage: 302747 km
                    Time Indication: 0
                    Date: 2018.02.06
                    Time: 00:21:32
   Part No SW: 7E0 919 475 L    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0106
   Revision: --------    Serial number: 28231501401002
   Coding: 308002
   Shop #: WSC 07456 790 50316
   VCID: 3B7582EBB265A95E1E-806E
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GX00J3B65
   Coding: 003232
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4A9BD72FEDBF00D695-801E
   Serial number: 3575HRB40570G68U9HCH
   Serial number: 3585HRB40550G68U7HIK
   Serial number: 3515RRB405T0510IA8VI
   Serial number: 3525RRB405T0510IMOL.
   Part No SW: 6R0 920 870 B    HW: 6R0 920 870 B
   Component: KOMBI         H05 0609
   Coding: 140E01
   VCID: 3467A9D79F3B6626DF-8060
1 Fault Found:
13639168 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 9
                    Mileage: 302038 km
                    Date: 2023.09.09
                    Time: 19:55:31
   Revision: B9080001
   Coding: 002200
   Part No SW: 7E0 857 511 F    HW: 7E0 857 511 C
   Component: FLA           H09 0003
   Revision: AA001001
   Coding: 0404000000000000000000
   Shop #: WSC 35110 790 50316
   VCID: 2D51BCB37C1137EE90-8078
1 Fault Found:
13241857 - Databus
          U1123 00 [008] - Received Error Message
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 21
                    Mileage: 302747 km
                    Date: 2023.09.16
                    Time: 00:10:41
                    Communication status of data bus 1-Brake control module: No communication
                    Communication status of data bus 1-Diagnostic interface for data bus: Communications link
                    Communication status of data bus 1-Engine Control Module (ECM): No communication
                    Communication status of data bus 1-Vehicle Electrical System Control Module: Communications link
                    Communication status of data bus 1-Steering column electronics control module: Communications link
   Component: IMMO          H05 0609
   VCID: 6ADB77AF8D7FE0D6B5-803E
Address 37: Navigation
Cannot be reached
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F6DA6BBEA1D45FEA2-807A
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Revision: --------    Serial number: --------------
   Coding: 0D4A000001000000
   Shop #: WSC 12345 123 12345
   ROD: EV_HeadlRegulVWLWRCC.rod
   VCID: 3A7B87EFBD5F905605-806E
   Part No SW: 5C0 035 680 F    HW: 5C0 035 680 F
   Component: MU-S-N-ER     H41 0468
   Serial number: VWZAZ2U0639822
   Coding: 02720001FF0000001111000100080A001F0100D400200100CF
   Shop #: WSC 00567 048 00001
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 244759972FDBF6A64F-8070
   Data medium:
   Subsystem 1 - Part No SW: 5NA 919 866 DF    HW: -----------
   Component: ECE AS 23/24  --- 2010
1 Fault Found:
0001 - Antenna 1 for Radio
          B1119 13 [009] - Open Circuit
                    Fault Priority: 6
                    Fault Frequency: 8
                    Reset counter: 219
                    Mileage: 280448 km
                    Date: 2023.03.25
                    Time: 13:03:45
                    Voltage terminal 30: 13.8 V
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 04:26)--------------------------
Address 03: DTCs cleared
Gateway Installation List:  7E0 909 901
When you do not have front fog lights installed,
- Byte12_Bit6,
- Byte21_Bits3,7,
must be disabled.
favi
Drives: 6R
Post by favi »
ciclo wrote: Sat Sep 16, 2023 9:40 pm When you do not have front fog lights installed,
- Byte12_Bit6,
- Byte21_Bits3,7,
must be disabled.
disabled - no error on dashboard
so next retrofit? - Lane Change Assist (Side assist) ;)
How do you plan to install the LCA warning lights on the exterior mirrors?
favi
Drives: 6R
Post by favi »
Scan mirror cover by lidar scanner, design a lamp holder in 3ds max or other 3d program -> print it on a 3D printer.
favi
Drives: 6R
Post by favi »
I made the first hole :)
Looks good.
Image Image
I bought wirings, but I need scheme :D
I have:
1- Radar Master Left J769 7E0907566C
2- Radar Slave Right J770 7E0907568C
no button on/off
WD Transporter (2015 -->): :arrow: https://drive.google.com/file/d/0B2nv91 ... zd1OBVc1WQ
Request download if necessary.
favi
Drives: 6R
Post by favi »
Today I bought a new car :)
VW Polo 6R -> Audi A1 30 TFSI S-tronic (S-line)
VW will be for sale.
If anyone is interested in a side assist system (wirings, mirror housings, leds etc. - without radars) - it will also be for sale.
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
Congratulations on new car.
Someone is going to get lucky with so loaded 6R.
Will miss the updates though.
