CNK
Drives: 6R
Post by CNK »
ciclo wrote:-Kit Bluetooth: Mfsw Voice comand A2DP SDS(RNS 510) oem.
What is part number of this Bluetooth Foam Cover?
Is it 1K0919737M (from Golf 5/6)? :?:
https://www.dropbox.com/sc/3gu9ow8tzdzl ... vKBk1OK0-a :D
that be correct!
Image :lol:
gti16
Drives: VW Polo 6r 1.6 TDI
Post by gti16 »
ciclo I tried to do what you said but not working. the button of the tires does not draw the error and VDCs also could not. I entered the ABS module, I put the code 40168, went to BASIC SETTINGS, G85, appeared information the green, pressed the button ON / OFF / NEXT and nothing does not happen, the information that showed the green disappeared. 2 times and tried to do anything well. I walked to the car after that and nothing.
ORiOn
Drives: Polo BlueGT / Audi S5
Post by ORiOn »
Google the vcds code error, you will find the answer :)
I pretty sure you will have to reset the ABS sensors...
CNK
Drives: 6R
Post by CNK »
iichel wrote:that be correct!
ciclo wrote:Image
Image :lol:
THX! :D
I also need Microphone 3B0035711B and this wire :?:
What is part number of the SDS wire? (http://www.servimg.com/image_preview.ph ... u=18061781)
gti16 wrote:ciclo I tried to do what you said but not working. the button of the tires does not draw the error and VDCs also could not. I entered the ABS module, I put the code 40168, went to BASIC SETTINGS, G85, appeared information the green, pressed the button ON / OFF / NEXT and nothing does not happen, the information that showed the green disappeared. 2 times and tried to do anything well. I walked to the car after that and nothing.
ORiOn wrote:Google the vcds code error, you will find the answer :)
gti16
fault code?
ORiOn
Link?
CNK wrote: Image
http://www.carsystems.pl/wiring-harness,c79.html Choose the one you need. Fast shipping for you ... I guess ... :wink:
gti16
Post by gti16 »
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AJ HW: 6R0 907 379 AF
Revision: --------
Coding: 210248E3417200BA842D12E882D700421300
Shop #: WSC 00788 648 00255
VCID: 8603F09335D2762E2EF-80D3
1 Fault Found:
00493 - ESP-Sensor Unit (G419)
005 - No or Incorrect Basic Setting / Adaptation
Fault Status: 01100101
Fault Priority: 0
Fault Frequency: 1
Reset counter: 202
Mileage: 55790 km
Time Indication: 0
Date: 2056.14.29
Time: 18:48:56
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x12E1
Hex Value: 0x20A0
Hex Value: 0x007F
Hex Value: 0x7F7B
Hex Value: 0x7FF9
gti16, try to make the basic settings again (all green with OK), it is the only way I know. :roll:
ORiOn
Post by ORiOn »
I'm pretty sure you will have to reset the Longitudinal/Lateral Acceleration Sensor or something related...
I don't know if this will work on the Polo, but try this:
[Select]
[03 - Brake Electronics]
[Measuring Blocks - 08]
Group 006
[Go!]
Check field 1, the value has to be between -1.5 and +1.5 m/s².
[Done, Go Back]
[Coding-II - 11]
OR (if Coding-II is not available)
[Security Access - 16]
Enter 40168, to enable the basic setting.
[Do it!]
[Basic Settings - 04]
Group 069
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
After a successful basic setting, field 2 should say "OK".
[Done, Go Back]
To make sure the basic setting was succesful, check the sensor again.
Group 006
[Go!]
[Done, Go Back]
[Close Controller, Go Back - 06]
[Select]
Group 004
[Go!]
Check field 2, the value has to be between -1.5 and +1.5 m/s².
[Done, Go Back]
[Coding-II - 11]
[Do it!]
Group 063
[Go!]
[ON/OFF/Next]
[Done, Go Back]
Group 004
[Go!]
[Done, Go Back]
ORiOn
Post by ORiOn »
Or if that didn't work, try reseting the esp sensor...
Once again i don't know if it's the same on the Polo, please don't mess to much around the 03 ABS Brakes on vcds if this isn't straight forward...
[Select]
[03 - ABS Brakes]
Enter 40168
[Do It!]
Group 069
[Go!]
Field 2 should show OK after a successful Calibration.
[Done, Go Back]
[Meas. Blocks - 08]
Group 010 Field 1/2 (Longitudinal Acceleration Sensor (G251))
Specification: ±1.25 m/s²
[Done, Go Back]
[Fault Codes - 02]
All fault codes should have disappeared.
[Done, Go Back]
ciclo wrote:gti16, try to make the basic settings again (all green with OK), it is the only way I know. :roll:
Taken for granted you will make the basic settings with the engine running. :mrgreen:
CNK
Drives: 6R
Post by CNK »
ciclo wrote:http://www.carsystems.pl/wiring-harness,c79.html Choose the one you need. Fast shipping for you ... I guess ... :wink:
Thanks, I was looking for on this site, but I don't see the beam such as yours...
http://www.carsystems.pl/bluetooth-mdi- ... id922.html
Rud031
Drives: Bluemotion 1.2TDI Comfortline
Post by Rud031 »
@ciclo
There i am again..
Few days ago, i told you about the "magic behaviour" of my car..
After that i thought the problem was solved, but i was wrong..
The point is that in daylight, the lights also turn on if the switch is in Auto mode..
I had cut one of the wires that goes to pin nr 1&37, to avoid the magic mode that my engine turns off through the lightswitch..
So,
My question is if you can help me out of this or tell me what to do..
If you need anything, like longcode or something else, just tellme..
Locked
