RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
smg_shardul
Drives: Polo 6R
Re: RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
Post by smg_shardul »
iichel wrote:you don't, it's the same connector.
No there are 4 connectors
1 for H4 halogen
2 for parking lights
3 for indicators
4 for headlight range motor
Sent from my Pixel 2 using Tapatalk
Yes. But the same connector is fitted with the same pin layout on the H7 and H4 headlights.
smg_shardul
Drives: Polo 6R
iichel wrote:Yes. But the same connector is fitted with the same pin layout on the H7 and H4 headlights.
H7 has 10 pin connector
You mean If I take 10 pin connector I have to insert wire according to H7 headlight diagram
smg_shardul wrote:Fri Jan 12, 2018 3:34 am Hi ciclo how r u?
I want to know how to install H7 twin barrel headlight to H4 setup
H4 has 4 different wires to connect and H7 have single 10 pin connector
Now I got 10 pin connector for H7 headlight I will insert all wires from 4 connectors of H4 headlights as per the below pic
Now my question is in H4 setup only one beam either high or low will work at a time and in H7 when full beam both high and low bulbs works together
Any solution for this ?
Best Regards
ShardulImage
Hi, in response to your private message (above). Image... :lol:
the solution is:
If you don't report the results I will never help you again. :lol:
(By the way, the H4 headlights from some VW models have four connectors as shown in the picture, I say this for those who want to keep learning :mrgreen:)
smg_shardul
Drives: Polo 6R
Where is T5zv/2?
Rest all things I got
I will surely report the result
In the back side of relay holder. YOU should know where is the J331 relay.
You have to remove the BCM to be able to extract the relay holder, once the relay holder is removed from the relay carrier, you have to slightly extract the terminal locking mechanism and then remove the terminal with the tool.
Estimated time to do this work, about 5-10 min max, but I guess it will take you a couple of hours.
smg_shardul
Drives: Polo 6R
ciclo wrote: Fri Jan 12, 2018 6:48 pm In the back side of relay holder. YOU should know where is the J331 relay.
We just need to add 1 extra wire that's it
Nothing else is required?
The simplest thing is always the best. You do not have to do anything else.
smg_shardul
Drives: Polo 6R
ciclo wrote:The simplest thing is always the best. You do not have to do anything else.
Ok thank u...
Will update the result on Monday...
Fatherless One
Drives: GTI 6C
Post by Fatherless One »
So what is the end result.
Photo’s would be good :)
The end result should be 100% perfect...
smg_shardul
Drives: Polo 6R
ciclo wrote:The end result should be 100% perfect...
1 wire added as per you guidance and headlights are working perfectly...
Thanks Ciclo..
Thanks for letting us know.
Did you take pictures of the process?
smg_shardul
Drives: Polo 6R
ciclo wrote:Thanks for letting us know.
Yes I took I will edit and upload here tomorrow...
Perfect.
