RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
smg_shardul
Drives: Polo 6R
Post by smg_shardul »
I want to install RLS sensors, electrochromic mirror , auto lights to vento 2016
Required pictures and Vcds report are as follows
VCDS Scanning report
Monday,31,July,2017,16:01:59:39744
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: MEXA16608GT067313 License Plate: SHARDUL
Chassis Type: 60-VW25 (6RU)
Scan: 01 02 03 08 09 10 15 17 19 25 44 56
Address 01: Engine (J623-CWXB) Labels: None
Part No SW: 03L 906 023 SN HW: 03L 907 425 B
Component: R4 1.5l TDI H33 9977
Revision: --H33--- Serial number:
Coding: 00250116032500080000
Shop #: WSC 00000 000 08192
ASAM Dataset: EV_ECM15TDI02130L906023SN 001001
ROD: N/A
VCID: 040057528F805F66AE-8050
No ASAM data for: "EV_ECM15TDI02130L906023SN" (VW25)
Readiness: 0 0 0 0 0
Part No SW: 0AM 300 065 L HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6501
Revision: 00043014 Serial number: CU501510066015
Coding: 0000020
Shop #: WSC 01324 785 00200
VCID: 3878F3A24BC8CB8672-806C
Part No SW: 6R0 907 379 BN HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 62DD2C63422907C74617346A4254E0820908
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_Brake1EPS90iBOSCH 003031
ROD: N/A
VCID: 0B127C6EA2DE101EEF-805E
No ASAM data for: "EV_Brake1EPS90iBOSCH" (VW25)
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 418E9E46D8128A4EC5-8014
Part No SW: 6RU 937 087 M HW: 6RU 937 087
Component: BCM IM H+4 H40 0432
Revision: BZ040001 Serial number: 0300 358150270
Coding: 3A904BFF08E10200003806C07D4B9490B08841FF608C0040200000000000
Shop #: WSC 124697 483 00190
VCID: 6CD01FF28F10B72646-8038
Subsystem 1 - Part No SW: 6R0 959 802 CC HW: 6R0 959 802 CC Labels: 6R0-959-802.CLB
Component: ------------- 007 5521
Serial number: 13102670151005153008
Coding: 050000
Subsystem 2 - Part No SW: 6R0 959 801 BT HW: 6R0 959 801 BT Labels: 6R0-959-801.CLB
Serial number: 13202671151005132525
Coding: 050000
Subsystem 3 - Part No SW: 5TA 959 442 HW: 5TA 959 442
Serial number: 2991519341401746AJ2B
Coding: 250000
Subsystem 4 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Component: ------------- 006 5520
Serial number: 13202580151005230949
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Serial number: 13102581150929004312
Coding: 020000
Address 10: Park/Steer Assist (J446) Labels:. 7E0-919-475.clb
Part No SW: 7E0 919 475 J HW: 7N0 919 475
Component: PARKHILFE 8K H06 0105
Revision: -------- Serial number: 28261224902578
Coding: 300104
Shop #: WSC 02756 790 50316
ASAM Dataset: EV_VW75PXarkAssis8K 001003
ROD: N/A
VCID: 397EF6A6B8C2D28E8D-806C
No ASAM data for: "EV_VW75PXarkAssis8K" (VW25)
Address 15: Airbags (J234) Labels:. 5K0-959-655.clb
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW0121NNF
Coding: 003036
ASAM Dataset: EV_AirbaVW1B0PAVW250 A01001
ROD: N/A
VCID: 499E8666E822420E1D-801C
No ASAM data for: "EV_AirbaVW1B0PAVW250" (VW25)
Address 17: Instruments (J285) Labels:. 5K0-920-xxx-17.clb
Part No SW: 6RF 920 862 HW: 6RF 920 862
Component: KOMBI H01 0214
Coding: 140A000000
ASAM Dataset: EV_Kombi_UDS_VD_DRM09 A05729
ROD: N/A
VCID: 091E4666A8A2020EDD-805C
No ASAM data for: "EV_Kombi_UDS_VD_DRM09" (VW36 *)
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 6RU 909 901 HW: 6RU 937 087
Component: GW-K-CAN TP20 H40 0432
Revision: BZ040001
Coding: 002300
VCID: 193E16261002F28E6D-804C
Component: IMMO H01 0214
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6ADC19EA8DE4A91634-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_014_VW12.rod
VCID: 418E9E46D0128A4EC5-8014
Part No SW: 6RD 035 187 A HW: 6RD 035 187 A
Component: MIB2-S-R-CN 025 0210
Revision: -----001 Serial number: 02425GD0000489
Coding: 0000044004000A
Shop #: WSC 00081 790 00133
VCID: 45868A56CC3AA66EF9-8010
3 Faults Found
00876 - Treble Speaker Rear Left (R14)
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 183
Mileage: 55232 km
Time Indication: 0
Date: 2015.06.27
Time: 08:36:31
00875 - Treble Speaker Front Right (R22)
Fault Priority: 5
Fault Frequency: 1
Reset counter: 183
Mileage: 55232 km
Time Indication: 0
Date: 2015.06.27
Time: 08:36:31
00874 - Treble Speaker Front Left (R20)
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 107
Mileage: 55232 km
Time Indication: 0
Date: 2015.06.27
Time: 08:36:31
End-------------------------(Elapsed Time: 02:18)--------------------------
smg_shardul
Drives: Polo 6R
Re: RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
This parts I am going to order tell me about compatibility of these parts with my vehicle.
Look what I found on AliExpress
http://s.aliexpress.com/UvIFBB7n
You can install that mirror / sensor / switch from the sale of aliexpress (cheap, all in one).
Although there are more updated mirror/sensor models (from 2015). :arrow: Ask here, he will be able to help you with this information.
The image of the headlight range control switch conector is missing. T6. Please, add. And some interior and exterior images from your 6R (at least two). Thanks
What will your new BCM Max be?
Because you took a little time to open this topic, and because I have others pending works, I can start manufacturing your wiring in the week of September 10 to 15.
I guess all your wires will be finished on September 13th.
smg_shardul
Drives: Polo 6R
ciclo wrote:You can install that mirror / sensor / switch from the sale of aliexpress (cheap, all in one).
Thanks for the reply
No issues with the time
you can take your time for wires
I think my existing BCM will support to all my requirement
I will upload photos.
smg_shardul wrote: Mon Aug 28, 2017 5:37 pm
No. It's explained in my wiring sale and you should know it.
You must buy/have/install a BCM Max.
This is the best advice I'll give you, contact firegrafik.
Now think because it is the best advice.
smg_shardul
Drives: Polo 6R
No.
Current vehicles have same BCM and they are installed with auto dimming mirror and rain sensing wipers.
So I thought it will support my existing bcm..
Can I connect my existing headlamps with BCM?
They are twin barrel halogen headlights
I have future plans to install bixenon too...
Only BCM Max supports automatic lights and bixenon headlights.
Your BCM High does not support any of this. Supports rain sensor, but not light sensor. Both are in the same part.
Automatic lights need the light sensor.
All this you should already know.
In a BCM Max you can connect all models of lights (OEM).
smg_shardul
Drives: Polo 6R
ciclo wrote:Only BCM Max supports automatic lights and bixenon headlights.
I am new to all this so don't have vast knowledge of all this...[emoji2]
I will send pics whatever I have interior and exterior
I will install BCM max too...
Daytime pics I will send in morning
Very nice your Polo Sedan. 8) 8) Many thanks for the pictures.
Hmm...please, post a recent VCDS autoscan, with your current instrument cluster included. Thanks. (when possible)
I hope that even if you are new to all this you have enough skills to install my wiring looms in a correct way.
The auto dimming rear view mirror installation is not a simple task. Speak with graaja.
smg_shardul
Drives: Polo 6R
ciclo wrote:Very nice your Polo Sedan. 8) 8) Many thanks for the pictures.
For auto mirror installation I am going to install skoda rapid windshield , it comes with sensor brackets installed on it and I have already ordered required windshield because my windshield is already cracked due to hit of stone
so that is not an difficult task
Recent vcds scanned report I will send you tomorrow...
Ok. Thanks.
smg_shardul
Drives: Polo 6R
ciclo wrote:Ok. Thanks.
I have one question regarding bixenon headlamps
What is basic difference between LHS & RHS?
Modules are different or housing are different?
Suppose I installed LHS headlights on RHS will it work or it won't support?
I've been asked this question too many times.
You must buy bixenon headlights for RHD (right-hand drive). Mandatory.
The light pattern and settings are different. (LHD vs RHD)
smg_shardul
Drives: Polo 6R
ciclo wrote: Mon Aug 28, 2017 7:31 pm Very nice your Polo Sedan. 8) 8) Many thanks for the pictures.
LATEST SCANNED REPORT
Tuesday,29,August,2017,09:49:24:39744
www.Ross-Tech.com
56-Radio -- Status: OK 0000
ASAM Dataset: EV_ECM15TDI02103L906023SN 001001
ROD: EV_ECM15TDI02103L906023RS.rod
Coding: 0000020
Shop #: WSC 28939 002 1048576
ASAM Dataset: EV_BrakeE1SP90iBOSCH 003031
ROD: N/A
No ASAM data for: "EV_BrakeE1SP90iBOSCH" (VW25)
1 Fault Found
0931 - ROD - Unknown Error Code
- 00 [009]
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 1
Mileage: 27382 km
Date: 2017.14.21
Time: 09:42:56
Address 08: Auto HVAC (J255) Labels: None
Revision: V0000000
Coding: 050000
Coding: 050000
Coding: 250000
Coding: 020000
Coding: 020000
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Coding: 300104
ROD: EV_EPHVA18VW250GPCS.rod
Coding: 003036
Address 17: Instruments (J285) Labels: None
Part No SW: 2H0 920 871 B HW: 2H0 920 871 B
Component: KOMBI H04 1009
Coding: 140A000000
Shop #: WSC 13202 938 12345
ASAM Dataset: EV_Komb_iUDS_VDD_RM09 A05730
ROD: N/A
VCID: 275A20DE5E76547EEB-8072
No ASAM data for: "EV_Komb_iUDS_VDD_RM09" (VW25)
Revision: BZ040001
Coding: 002300
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H04 1009
ASAM Dataset: EV_Mimo_UDS_VDD_RM09 A03710
ROD: N/A
No ASAM data for: "EV_Mimo_UDS_VDD_RM09" (VW36 *)
Address 44: Steering Assist (J500) Labels:. 1Sx-909-144-44.clb
ASAM Dataset: EV_SeterAssisNSK 014008
ROD: N/A
No ASAM data for: "EV_SeterAssisNSK" (VW25)
End-------------------------(Elapsed Time: 02:15)--------------------------
Perfect!! It is exactly what I imagined after seeing the images. Thank you very much for this new VCDS autoscan. 8)
