BCM Max Transporter 2013
RobertVW
Drives: T6
Re: BCM Max Transporter 2013
Post by RobertVW »
Cool project.
I was always convinced that ELV checks the brand with the ECU(pretty sure yours is VW) so curious how SEAT KESSY is going to work with yours.
Very interesting, please keep us informed of your progress on your projects. Thanks.👍
Shadow109
Drives: Vw t5.1 2013
Post by Shadow109 »
RobertVW wrote: Wed Mar 01, 2023 9:38 pm Cool project.
Thanks for the info, I will try to swap it to vw
Did you finish your kessy project?
RobertVW
Drives: T6
Post by RobertVW »
Not yet Abdullah.
Yes stick to VW Kessy otherwise it will not work.
I think I am doing too many retrofits simultaneously :D.
The biggest slow down for Kessy on a Transporter is door handles grafting.
Shadow109
Post by Shadow109 »
I have an idea for the door handles, I will share it work out
Shadow109
Post by Shadow109 »
I have brought another elv from vw
I have connected 30,31, and canbus for the elv and kessy unit on the car just to access coding, but still can’t access it
Any ideas?
RobertVW
Drives: T6
Post by RobertVW »
Have you also connected positive supply to "15" and "S" pins?
Shadow109
Post by Shadow109 »
I didn’t modify my ignition switch
Shadow109
Post by Shadow109 »
I have sorted out the wiring issue.
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 05 08 09 10 13 14 15 17 19 20 25 2B 37 3C 55 5F 61
          65 77 0B
VIN: WV1ZZZ7HZDH036544   Mileage: 279960km-173959miles
05-Acc/Start Auth. -- Status: Malfunction 0010
14-Susp. Elect. -- Status: Malfunction 0010
17-Instruments -- Status: Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GH    HW: 03L 907 309 M
   Component: R4 2,0L EDC   H44 8437
   Revision: 26H44---    Serial number: 00000000000000 CVN: C7200230
   Coding: 01114012234400080000
   Shop #: WSC 01286 386 08256
   ASAM Dataset: EV_ECM20TDI01103L906019GH 003006
   ROD: EV_ECM20TDI01103L906019FM_003.rod
   VCID: F7A006CBCF485462BE1-80A2
   VINID: 9E606AAAA1D8A946000C6144105E5FB8A3
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104)       Labels:. 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 Q    HW: 7E0 907 379 N
   Component: ESC           H06 0133
   Revision: 00000000    Serial number: 62787000000113
   Coding: 307E4098256586840C7A027AA486616F78F555
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
   ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
   VCID: C0D2AD17DA06D3DACFB-8094
   Serial number: 11031913470358
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: FEAE13EFE072652AFD7-80AA
Address 05: Acc/Start Auth. (J518)       Labels:| 5K0-959-434.clb
   Part No SW: 5K0 959 434 K    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 093 1403
   Revision: 00093000    Serial number: 0467921560
   Coding: 132C0C
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_KESSYPQ35G A02717
   ROD: EV_KESSY_PQ35GP.rod
   VCID: BD2CD4E3ADF4BE32A4D-80E8
1 Fault Found:
65826 - No Basic Setting
          B2010 00 [009] - -
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 279886 km
                    Date: 2023.04.26
                    Time: 21:58:04
   Part No SW: 7E5 907 047 BM    HW: 7E5 907 047 BM
   Component: Climatic-T5   H20 0505
   Revision: 00001010
   Coding: 0000000002
   Shop #: WSC 02736 790 50316
   ROD: EV_ClimaT5Basis.rod
   VCID: FBA81AFBF3607002DA9-80AE
   Revision: B9084001    Serial number: 2502 306190145
   Coding: 2AB0393E4E37221281280EC17EEB9FDDF88C6600608D79C032A4003F0860
   VCID: AD0CE4A37D142EB214D-80F8
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 230916 03  37  0059
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3313
   Subsystem 3 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3313
   Subsystem 4 - Part No SW: 7E0 959 442 A    HW: 7E0 959 442 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39180000000570018056
   Coding: B4FFFF
1 Fault Found:
01134 - Alarm Horn (H12)
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 183
                    Mileage: 279961 km
                    Time Indication: 0
                    Date: 2023.04.27
                    Time: 00:16:19
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39331817601496
   Coding: 0041155001
   Shop #: WSC 21890 003 104857
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: EV_EPHVA18VW364GP00_VW32.rod
   VCID: B720C6CB8FC894627E1-80E2
1 Fault Found:
12718592 - Databus
          U1121 00 [009] - Missing Message
          [Steuergerät für Lenksäulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 183
                    Mileage: 279961 km
                    Date: 2023.04.27
                    Time: 00:16:17
Address 13: Auto Dist. Reg (J428)       Labels:| 7N0-907-572.clb
   Part No SW: 7N0 907 572 C    HW: 7E0 907 572
   Component: ACC Bosch PQx H03 0211
   Serial number: 1909180453A6EF Dataset Number: ACC_MRRevo1 0001
   Coding: 00004000FE0779
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_ACCBEGVW361 001006
   VCID: B63ECBCF88C26D6A657-FFFE
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376     HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0069
   Revision: 00000000    Serial number: 12030906320002
   Coding: 030180
   Shop #: WSC 05314 123 12345
   VCID: E69E5B8F9862DDEA157-80B2
2 Faults Found:
01087 - Basic Setting Not Performed
            000 - - - MIL ON
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 183
                    Mileage: 279961 km
                    Time Indication: 0
                    Date: 2023.04.27
                    Time: 00:16:14
00149 - End of Line Programming not Completed
            000 - - - MIL ON
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 183
                    Mileage: 279961 km
                    Time Indication: 0
                    Date: 2023.04.27
                    Time: 00:16:14
   Part No SW: 7E0 959 655 D    HW: 7E0 959 655 D
   Component: VW10Airbag00G 008 0016
   Revision: --------    Serial number: 003PH0013MB$ Dataset Number: 7E0003V____ 0735
   Coding: 000000000000000000000000000000003047
   Shop #: WSC 02734 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
   ROD: EV_AirbaVW10BPAVN750.rod
   Part No SW: 7E0 920 980 S    HW: 7E0 920 980 S
   Component: KOMBI         H04 1109
   Coding: 140E230B00
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
   VCID: BB28DAFBB3E0B0029A9-80EE
   Revision: B9084001
   Coding: 04220F
   VCID: E88255B79276CB9A27B-80BC
   Revision: AA001001
   Coding: 010100E200000100000000
   VCID: AE0EE3AF709255AA2D7-80FA
   Component: IMMO          H04 1109
   Serial number:
   VCID: EA862FBF8CFAF98A31F-80BE
Address 2B: Steer. Col. Lock (J764)       Labels:* 5K0-905-861.clb
   Part No SW: 5K0 905 861 C    HW: 5K0 905 861 C
   Component: ELV-PQ35      H21 0240
   Revision: 00000000    Serial number: 14000305204001
   Coding: 4100000000000000
   Shop #: WSC 00066 790 50316
   ASAM Dataset: EV_ELVMarquMPVW36X A01001
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: B032FDD76AA6435A3FB-80E4
Address 37: Navigation
Cannot be reached
Address 3C: Lane Change (J1086)       Labels:| 5Q0-907-686.clb
   Component: HRE_Master    H12 0081
   Serial number: 0466413079 Dataset Number: V03935256RC 0001
   Coding: 03031102
   Shop #: WSC 09003 957 00200
   ROD: EV_HREntryHella_VW37.rod
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 5Q0 907 685 C    HW: 5Q0 907 685 C
   Component: HRE_Slave  H12 0081
   Serial number: 0465512829
   Coding: 030311
Address 55: Headlight Range        Labels:
   VCID: D5ED82572C58DB3B48-FFFE
   Component: MU-S-ND-ER    H41 0478
   Serial number: VWZAZ2U1668085 Dataset Number: V03935240VJ 0001
   Coding: 0645000FBE00000011110001010D08001F0303D401200100CE
   Shop #: WSC 00046 123 12345
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: A51C1C83256416F2DCD-80F0
   Data carrier:
   Subsystem 1 - Part No SW: V03 825 254 AN    HW: -----------
   Component: MRM DL2 22/23  --- 1810
3 Faults Found:
1555 - Check Software Version Management
          B201A 00 [009] - -
          [Check software version management]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 183
                    Mileage: 279961 km
                    Date: 2023.04.27
                    Time: 00:16:16
                    Voltage terminal 30: 12.4 V
                    Status_Software_Version_Management-module_name:
          U1101 00 [009] - Active
          [Anti-theft protection - component protection active (0xEA6300)]
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 183
                    Mileage: 279961 km
                    Date: 2023.04.27
                    Time: 00:16:16
0527 - Rear Left Bass Speaker
          B1065 13 [009] - Open Circuit
          [Tieftonlautsprecher Kanal 4: Unterbrechung (DC-Diagnose)]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 183
                    Mileage: 279961 km
                    Date: 2023.04.27
                    Time: 00:16:17
   Part No SW: 7E0 907 534     HW: 7E0 937 090 E
   Component: Batt.regelung H84 0772
   Coding: F0001800
   Serial number: 30000000047437
   ROD: EV_RDKBERU30_005.rod
Address 77: Telephone
Cannot be reached
End----------(Elapsed Time: 04:10, VBatt start/end: 12.4V/12.4V)-----------
And I have adapted the ELV to my car :-
Control Module Part Number: 5K0 905 861 C
  Component and/or Version: ELV-PQ35      H21 0240
           Software Coding: 4100000000000000
            Work Shop Code: WSC 00066
Advanced Identification/FAZIT
     Identification: MD9-MSR
     Revision: 00000000
     Date: 06.11.14
     Manufacturer number: 0753
     Test stand number: 1257
Flash Status
     Programming Attempts(application): 0/0/0
     Successful Attempts(application): 0/0/0
     Programming Status: 00000000
     Flash Date: 00.01.01
Software
     UDS: 00.00.01
     UDS: 11.03.00
     LIN 2.0: 01.02.05
     CAN: 00.1E.01
     Unknown: 01.07.00
     Theft prot.: 01.02.11
     OSEK-OS: 00.1E.03
     Unknown: 00.0A.00
     Generic Net Mgt: 01.02.00
Misc.
     Hardware number: 5K0 905 861 C
     Workshop System Name: J764
     ASAM Dataset Revision: A01001
Car Info
     Chassis Number: WV1ZZZ7HZDH036544
VCDS Info:
       Labels: 5K0-905-861.clb
But when I tried to upload parameter data for kessy I always get checksum error for some reason
WhatsApp Image 2023-04-28 at 10.02.00 PM.jpeg (132.28 KiB) Viewed 14721 times
I have also tried to use VCP, but I got the same error
Shadow109
Post by Shadow109 »
Adapting kessy . . Done
Adapting ELV . . Done
Next step: removing ignition switch, and adding needed relays
Saturday,29,April,2023,13:45:19:22797
VCDS Version: 23.3.1.0 (x64)  HEX-NET2 CB: 0.4631.5
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WV1ZZZ7HZDH036544   License Plate:
          65 77 0B
VIN: WV1ZZZ7HZDH036544   Mileage: 280010km-173990miles
05-Acc/Start Auth. -- Status: OK 0000
   Coding: 01
   Part No SW: 5K0 959 434 F    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 093 1202
   Coding: 132C0C
   VCID: B822C5F782D69B1A77B-80EC
   Revision: 00001010
   Coding: 0000000002
   Coding: 2AB0393E4E37221201280EC17EEB9FDDF88C6600608D79C032A4003F0860
   Coding: 0228EE
   Coding: B4FFFF
   Coding: 0041155001
1 Fault Found:
12718592 - Databus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 185
                    Mileage: 280011 km
                    Date: 2023.04.29
                    Time: 17:17:17
   ROD: EV_ACCBEGVW361.rod
   VCID: B63ECBCF88C26D6A657-80E2
   Coding: 030180
2 Faults Found:
            000 - - - MIL ON
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 185
                    Mileage: 280011 km
                    Time Indication: 0
                    Date: 2023.04.29
                    Time: 17:17:15
            000 - - - MIL ON
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 185
                    Mileage: 280011 km
                    Time Indication: 0
                    Date: 2023.04.29
                    Time: 17:17:15
   Coding: 140E230B00
   Revision: B9084001
   Coding: 04220F
   Revision: AA001001
   Serial number:
   Coding: 000007
Cannot be reached
   Coding: 03031102
   Coding: 030311
   Revision: --------    Serial number: -------------- Dataset Number: V03600047E0 0004
   Coding: 0206000001000000
2 Faults Found:
5275220 - Headlight
          C107E 54 [137] - Missing Calibration / Basic Setting
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 185
                    Mileage: 280011 km
                    Date: 2023.04.29
                    Time: 17:17:18
5256213 - Front Vehicle Height/Level Sensor
          C114D 15 [137] - Open or Short to Plus
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 185
                    Mileage: 280011 km
                    Date: 2023.04.29
                    Time: 17:17:17
   Data carrier:
3 Faults Found:
          B201A 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 185
                    Mileage: 280011 km
                    Date: 2023.04.29
                    Time: 17:17:17
                    Voltage terminal 30: 11.7 V
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 185
                    Mileage: 280011 km
                    Date: 2023.04.29
                    Time: 17:17:17
                    Voltage terminal 30: 11.9 V
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 185
                    Mileage: 280011 km
                    Date: 2023.04.29
                    Time: 17:17:18
   Coding: F0001800
Cannot be reached
End----(Elapsed Time: 01:58, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
WhatsApp Image 2023-04-29 at 7.28.51 PM.jpeg (69.23 KiB) Viewed 14659 times
RobertVW
Drives: T6
Post by RobertVW »
Bravo Abdullah :wink:
Shadow109
Post by Shadow109 »
I have removed ignition lock
Connected old D/3(15) & D/6(75) to new two terminals, connected 86 in the new terminals to J935/9 & 10
and connected D/4(S) to J764/7
I didn’t even got 15kl working, when I push the start button I can only hear the EPB relay clicking
Shadow109
Post by Shadow109 »
My new shock absorbers have arrived, but sadly, I couldn't make basic settings due to high level sensors value
So I guess I need to Fit a new springs too
WhatsApp Image 2023-05-12 at 1.15.53 AM.jpeg (107.4 KiB) Viewed 14457 times
WhatsApp Image 2023-05-12 at 1.15.53 AM (1).jpeg (117.81 KiB) Viewed 14457 times
   Coding: 030180
1 Fault Found:
            000 - - - MIL ON
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 221
                    Mileage: 281927 km
                    Time Indication: 0
                    Date: 2023.05.11
                    Time: 12:16:18
RobertVW
Drives: T6
Post by RobertVW »
Have you jacked up all wheels simultaneously at that stage?
Shadow109
Post by Shadow109 »
Yes, but its not enough, it seems like the wheels need to go down more
I will lift it up again and take a picture of the measurements
