BCM Max Transporter 2013
Shadow109
Drives: Vw t5.1 2013
Post by Shadow109 »
I have finished retrofitting a highline instrument cluster, CCS,MFSW with CCE, and OPS
I have inspired a lot from you forum
My next project is bam max with RLS, Auto lights, and HBA
I have order most of the parts, still missing Auto light switch and a pair of T10 terminal
I am trying now to swap my 87 BCM to 90 7H (temporarily unit I receive the 90 7H)
this is my old bcm scan :-
Friday,30,October,2020,22:11:39:00009
VCDS Version: 20.4.1.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZDH036544   License Plate:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 56 0B
VIN: WV1ZZZ7HZDH036544   Mileage: 193780km-120409miles
Address 01: Engine (J623-CAAA)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GF    HW: 03L 907 309 M
   Component: R4 2,0L EDC   H44 3312
   Revision: 26H44---    Serial number: 00000000000000
   Coding: 01114012232400080000
   Shop #: WSC 02736 790 50316
   ASAM Dataset: EV_ECM20TDI01103L906019GF 003002
   ROD: EV_ECM20TDI01103L906019FG_003.rod
   VCID: 75E154D3D4C13F2E28-8020
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0110
   Revision: 00H43001
   Coding: 508724AD89A70A9B24A79175696210
   Shop #: WSC 02736 790 49152
   VCID: 3A7B87EFB55F905605-806E
   Part No SW: 7E5 907 047 BM    HW: 7E5 907 047 BM
   Component: Climatic-T5   H20 0505
   Revision: 00001010
   Coding: 0000000002
   ROD: EV_ClimaT5Basis.rod
   VCID: 7BF542EBF2E5695E5E-802E
Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
   Part No SW: 7H0 937 087 H    HW: 7H0 937 087
   Component: BCM T5GP H+4  H47 0254
   Revision: BO047001    Serial number: 0429 014120346
   Coding: A8A0393A0E212012002808102E2B8CD40080430F60040000320000000000
   Shop #: WSC 02756 790 12345
   VCID: 397998E3B0599B4E0C-806C
   Subsystem 1 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3313
   Subsystem 2 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3313
   Subsystem 3 - Part No SW: 6C0 959 442 C    HW: 6C0 959 442 C
   Component: E221__MFL-DC1  H04 0103
   Serial number: 29160002125520036437
   Coding: B0FFFF
1 Fault Found:
00329 - Control Circuit for Unlocking Rear Lid
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 253
                    Mileage: 193782 km
                    Time Indication: 0
                    Date: 2020.10.30
                    Time: 21:04:47
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28261631000160
   Coding: 108009
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   VCID: 71E960C3A0A9130EF4-8024
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag003 H07 0013
   Revision: --------    Serial number: 003HL00DDD0.
   Coding: 000000000000000000000000000000003033
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 356194D394417F2EE8-8060
   Part No SW: 7E0 920 970 N    HW: 7E0 920 970 N
   Component: KOMBI         H04 0805
   Coding: 460A00
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 H47 0254
   Revision: BO047001
   Coding: 042200
   VCID: 70EF65C7A3A31A06FB-8024
   Component: IMMO          H04 0805
   Serial number:
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
   VCID: 6ADB77AF8D7FE0D6B5-803E
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 03:20)--------------------------
this is the 90 E7 scan
Friday,30,October,2020,22:45:39:00009
www.Ross-Tech.com
   Revision: 00H43001
   Revision: 00001010
   Coding: 0000000002
1 Fault Found:
13701456 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Date: 2000.00.00
                    Time: 00:00:00
   Part No SW: 7H0 937 090 D    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H74 0725
   Revision: B9074001    Serial number: 0671 187140532
   Shop #: WSC 02739 790 12345
   VCID: 2F6DA6BB7E1D45FEA2-807A
   Coding: B0FFFF
3 Faults Found:
            011 - Open Circuit
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 176
                    Time Indication: 0
01516 - Terminal 30; Left
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 176
                    Time Indication: 0
00927 - Terminal 30 (Right)
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 176
                    Time Indication: 0
   Coding: 108009
   Coding: 460A00
1 Fault Found:
12664832 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H74 0725
   Revision: B9074001
   Coding: 042200
1 Fault Found:
00381 - Databus Instrument Cluster
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 176
                    Time Indication: 0
   Serial number:
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 03:05)--------------------------
is it enough to add the tow wires cluster/BCM to get everything to work (temporarly) ?
Re: BCM Max Transporter 2013
Yes, but as you know you will have to make more adaptations to the wiring.
Good improvements so far. 8) 8) 8) 8)
Shadow109
Post by Shadow109 »
Just finished to make the looms
Photos before installing the new looms
photos after installation
new scan after installing the looms
Friday,04,December,2020,12:38:30:00009
www.Ross-Tech.com
Chassis Type: 7H-VN75 (7E0)
VIN: WV1ZZZ7HZDH036544   Mileage: 199150km-123746miles
08-Auto HVAC -- Status: Not registered 0011
   Revision: 00H43001
   Revision: 00001010
   Coding: 0000000002
1 Fault Found:
13701936 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 190
                    Mileage: 199156 km
                    Date: 2020.12.04
                    Time: 14:40:51
   Revision: B9080001    Serial number: 0771 351150194
   Shop #: WSC 54707 002 104857
   VCID: 68DF0DA79B73D2C6A3-803C
   Coding: B0FFFF
2 Faults Found:
01504 - Bulb for License-Plate Light (X)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 190
                    Mileage: 199156 km
                    Time Indication: 0
                    Date: 2020.12.04
                    Time: 14:40:52
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
            008 - Implausible Signal
                    Fault Status: 01101000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 190
                    Mileage: 199156 km
                    Time Indication: 0
                    Date: 2020.12.04
                    Time: 14:40:52
   Coding: 308001
   Coding: 160A00
   Revision: B9080001
   Coding: 042200
1 Fault Found:
            000 - -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 199156 km
                    Time Indication: 0
                    Date: 2020.12.04
                    Time: 14:40:52
   Serial number:
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:08)--------------------------
the situation of the lights
1- DRL not working
2- low beam works normally
3- high beam only works with the return spring
4- interior illumination not working
Things I didn't install :-
1- T73a-62 to sb28a
2- reverse light wire
A8A0393A0E212012002808102E2B8CD40080430F60050000320000020000
If you have a wire from T73b/4 to T6aa/3, this will probably enable the illumination of the buttons.
And I think it makes sense to first complete all the wiring and then look at the coding.
Anyway, have a look at byte 23 bit 6 to enable your DRL (if they are now through the BCM).
Shadow109 wrote: Fri Dec 04, 2020 1:17 pm Just finished to make the looms
1- DRL not working
1- T73a-62 to sb28a
It is mandatory that you install the wire that reaches T73a/62 but not from fuse sb28a because you want to install HBA.
In the following diagram you must follow the same instructions but only what is indicated for the Stalks and BCM. (pin1 on both BCM connectors is the output for HB)
:arrow: https://drive.google.com/file/d/0B2nv91 ... sp=sharing
It is very important that you take into account the signals +30 and +15, they are very different signals.
In the previous diagram (6R WRC), do not take into account what is related to T10, Red connector and T17, it is something different from the diagrams for the T5 tranporter. For these connectors you must be guided by the diagrams posted in the Transporter thread.
All the above is to code your BCM correctly and that everything works perfectly. :wink:
Thank you very much for showing us the pictures of your progress in the wiring installation. 8)
Shadow109
Post by Shadow109 »
iichel wrote: Fri Dec 04, 2020 2:21 pm A8A0393A0E212012002808102E2B8CD40080430F60050000320000020000
Just the mfsw buttons is illuminated, do I have to code something or to recheck the wiring??
Shadow109
Post by Shadow109 »
ciclo wrote: Fri Dec 04, 2020 3:56 pm
1- DRL not working
1- T73a-62 to sb28a
Thanks for you Fernando, I will do the rest of the wiring tomorrow
I have all the parts for the hba/rls
Is this primer the only thing i need to stick the slip ring ?
I am to sure how to use it
Well, I assume you mean the retaining plate (the thing that holds the mirror in place).
- No, you also need a glue for windows, it is a two-component polyurethane.
It worked remarkably well for me with the original VW glue.
Later I will post some more info here, now I have to fly ... :lol:
:arrow: https://www.uk-polos.net/viewtopic.php?p=502568#p502568
1.4.1 Preparing windscreen
– All adhesive and primer residue must be removed from the
ceramic pre-coating.
– Clean adhesive surface with cleaning solution D 009 401 04.
– Adhere to flash-off period of at least 10 minutes.
– Apply glass/paint primer D 009 200 02.
1. Interior mirror
– Flash-off period up to bonding: minimum of 10 minutes to
maximum of 1 hour.
1.4.2 Preparing detached or new retaining plate
– Mechanically remove adhesive remains (applies only for a
mirror base which has become detached).
– Prepare adhesive surface by sanding down with wet fine emery
paper (800-1200 grade) until water does not run off surface
to be bonded.
– Then clean with cleaning solution D 009 401 04.
1.4.3 Bonding retaining plate
– Apply 2K polyurethane adhesive D 180 KD2 A1 directly to
prepared and cleaned retaining plate bonding surface.
– Adhesive bead diameter: Approx. 2.5 … 3 mm.
– Press retaining plate into position on prepared windscreen immediately
after applying adhesive.
– Align retaining plate in position on ceramic pre-coat surface
and secure with adhesive tape.
Shadow109
Post by Shadow109 »
Something wrong
Maybe it’s because my stake
Ciclo can you make me a map for all wiring that I need to do
Hi you need to add a new pair of canbus wires from BCM to the instrument cluster. Then it's resolved
Shadow109
Post by Shadow109 »
If you mean these, I have already did it
Shadow109 wrote: Sat Dec 05, 2020 4:04 pm Something wrong
For Stalks 7E0 with return spring (1x) you need a slip ring 6R0959654 and perform the basic setting of the slip ring (G85) with VCDS in Address 03: ABS Brakes (J104).
I don't know how you managed to install the 7E0 Stalks with return spring (1x) in your OLD slip ring (which is not the correct fit). Try to do the basic setting.
In case it helps you get inspired, the diagram above comes from this installation tutorial:
The following link is so that you can make comparisons with those who only want to install automatic lights:
viewtopic.php?p=528663#p528663
Note:
The pin assignments on the RED connector may be different in the diagrams you are viewing or comparing due to the wiring adaptation, so what really matters are the assignments between the old large T17 connector and the new small T10 connector when making comparisons between diagrams.
Shadow109
Post by Shadow109 »
I have been missing the stalk and the slip ring, I have ordered them and I hope I will get them in a week
I have looked at the installation tutorial for Adam87, I am thinking of making the same looms
do I have to do the same as adam78 tutorial ??
Well, it is difficult to tell you a resounding yes for several reasons:
- It is a tutorial for some wiring that will be installed in a specific T5, it is not an explanatory guide to install HBA in any T5.
- Adam87's T5 is RHD and yours is LHD.
- The two power cables for the BCM are not taken from the battery-external fuse box, they were taken from the internal fuse boxes of Adam87's T5 because it was possible according to the original electrical installation.
Note: there is no problem if you already have the BCM powered from outside.
- This was the first wiring we did between Adam87 and me to be able to install HBA in a T5, his T5, so the wiring is based on what we had available (original wiring of his T5) and what had to be added or isolated.
What I mean is that they were totally experimental wiring looms that was finally an absolute success, but just then I only had the materials that you see in the tutorial images.
These wiring looms can be made better in regards to the new T3 and T4 connectors for easy wiring installation, ...and other small details that can be done in the installation process.
That is why I told you that perhaps the tutorial could help inspire you with your installation.
