iichels VW Passat 2.0 TSI DSG 4-Motion 2017
Re: iichels VW Passat 2.0 TSI DSG 4-Motion 2017
The latest breed of VW cars don't have headlight washers anymore, probably as a cost-saving measure. Little that I knew, my latest BCM doesn't have the little PCB components on it anymore to operate the pump for that.
So... after some research, the missing components were quickly transferred from a donor 5Q0 BCM to my 2024 5Q1 BCM and all is working. Big thanks to the one and only Slavik.
https://imgur.com/a/Q8DsDM9
patil
Post by patil »
Wow.. great job you both👍
I like it, you went Russian's way of fixing the problem :mrgreen:
Well done, perfect!
I love seeing how the components line up when using the flux and solder paste, it seems like the components have a built-in PDC/PLA auto-parking system.
I'm stunned watching them park. :lol:
The Passats historically have the rear child booster seats. Since I already have the independent rear child locks, rear seat heating and the rear window curtains OEM, I figured I'd need these two.
The base:
Etka --> 885-020
Problem 1: couldn't find one with a white stitching. So I asked a good friend to replace the stitch, like she did for my gear lever.
Problem 2: no rear seat heating. That simply doesn't exist from factory. So I put in some pads myself...
Needs a lot of tiewraps to put it all back together
But the result is pretty neat!
The bump in the middle is the seat heating pad and I'm afraid it's not going away anytime soon, but that's life. :mrgreen: :twisted:
rhinopower
Drives: Not at the moment
Post by rhinopower »
iichel wrote: Thu Nov 16, 2023 2:29 pm
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 2Q0-980-653.clb
   Part No SW: 2Q0 980 653 C    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1302
   Serial number: E80320003220200 Dataset Number: V03935368RP 0001
   Coding: 0004019821FEC024889F14001020004000438000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   ROD: EV_MFK3ValeoMQB_007_VW27.rod
   VCID: 3537DC9565C39362ECD-8060
to
   Part No SW: 2Q0 980 653 D    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1421
needs a dataset but SWAP + calibration are maintained
upcoming mods:
- 42, 52, BB and BC modules upgrade from 5Q0 HW: E + SW: E to 5Q0 HW: F and SW: K/L
- BCM 084EC
- 2Q0 side assist
- Kessy module to N/Q SW
- I'm unsure if the 084E BCM will work with the 5Q0 slip ring, so Patil inspired me about 5Q1 slip rings. I'll give that a try too.
Can you help me with D revision data set? I'm also retrofitting 2Q0 A5 to my 2017 B8 Passat
I took it from mibsolution : 8)
rhinopower
Site is down. Im going to flash to 1401 to match a vin number i have and run SVM, and capture the file instead incase i need again
Thanks mate
rhinopower
2Q0 Camera all sorted and Swaps etc done
Only issue now is KLR. Wheel has 5H0 klr module, does it have to be 3G0 instead, or do i just need to update gateway? Currently 3Q0 907 530 H continental gateway, GTE version
5h0 KLR is working perfectly fine here.
rhinopower
Adp channel for wheel touch recognition is not available on gateway for me, so looks like gateway flash to solve then!
Yeah I'd update the gateway then, IIRC you need AR SW for hybrid drivetrain. You can use FPA editor for dataset.
Viperslider
Drives: Seat Leon 5F Cupra ST 290
Post by Viperslider »
Some fantastic things here! Good work!
Once my Leon 5F returns from Seat with it's brand new zero mile engine, hopefully next week, I can carry on with my MQB retrofit attacks. I have missed it so much!
Anything more in the pipeline?
For now it will be the new engine, dq500 and the torque vectoring rear differential.
Address 02: Auto Trans (J743)       Labels:. 0BH-927-711.clb
   Part No SW: 0DL 300 012     HW: 0BH 927 711 F
   Component: GSG DQ500     H10 5301
   Revision: 00H10V01
   Coding: 0014
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_TCMDQ500021 001001
   ROD: EV_TCMDQ500021_001_VW36.rod
   VCID: 66954BD968E528FAC5F-8032
:twisted: :twisted: :twisted:
Yes that's a DQ500 with a Continental mechatronic. It was adapted online via ODIS eventually, after a lot of trouble
The Continental mechatronic cannot be made immo-off, it can only be done for the later Bosch DQ500 / DQ381 mechatronic.
This is an SDM gearbox from the 2017 Passat B8 2.0 TSI alltrack (CHHB), these got the DQ381 in 2018.
How does it sound??
https://i.imgur.com/V8qBjGY.mp4
Maarten
Post by Maarten »
Very very nice!
