tadej
Drives: 6R 1.6TDI DSG
Post by tadej »
Thank you again Ciclo.
I removed the fuse on the 57 mark and all the light bulbs work perfectly.
Here is an autoscan from VCDS:
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Saturday,26,December,2015,14:53:59:62939
Chassis Type: 6R (6N0)
Scan: 01 02 03 08 09 10 15 17 19 25 44 56
VIN: WVWZZZ6RZAY263597
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAYB)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 AH    HW: 03L 906 023 D
   Component: 1,6l R4 CR td H13 9970
   Revision: --H13---    Serial number:
   Coding: 00254016002400080000
   Shop #: WSC 124697 483 00190
   ASAM Dataset: EV_ECM16TDI02103L906023AH 003010
   ROD: EV_ECM16TDI02103L906023AH_VW25.rod
   VCID: 6CD7223B877E2C7E58B-8039
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 0AM-300-04x.lbl
   Part No SW: 0AM 300 049     HW: 0AM 927 769 D
   Component: GSG DSG AG7     402 9060
   Revision: 00040024    Serial number: TFK01004030233
   Coding: 0000020
   Shop #: WSC 23988 000 1048576
   VCID: EED3A833FA625E6EF6F-5000
Address 03: ABS Brakes        Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AF    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0005
   Coding: 210228E3417300B5842A14EB82D800421300
   Shop #: WSC 02069 000 00000
   VCID: 820BEC8319FA4A0E027-80D7
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
   Part No SW: 6R0 907 044 B    HW: 6R0 907 044 B
   Component: Climatronic   H08 0305
   Revision: V0000000
   VCID: 326BFC436DDABA8E527-8067
1 Fault Found:
00819 - High Pressure Sensor (G65)
            009 - Open or Short to Ground - Intermittent
                    Fault Status: 00101001
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 103
                    Mileage: 16596 km
                    Time Indication: 0
                    Date: 2000.14.13
                    Time: 09:07:05
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 6R0 937 087 D    HW: 6R0 937 087 D
   Component: BCM PQ25 H+4  H46 0207
   Revision: BF046001    Serial number: 0147 092100027
   Coding: 3CB02BBF48A10000013806003CAB0FD00080410F60842000200000000000
   Shop #: WSC 07150 298 85912
   VCID: 3E73D873A9826EEEA6F-806B
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 040410 05  54  0403
   Coding: 0005F3
   Subsystem 2 - Part No SW: 6R0 959 801 R    HW: 6R0 959 801 R  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 0903
   Coding: 18BC30
   Subsystem 3 - Part No SW: 6R0 959 802 T    HW: 6R0 959 802 T
   Component: J387__TSG_BT  006 0902
   Coding: 08BC30
   Subsystem 4 - Part No SW: 5K0 959 542     HW: 5K0 959 542
   Component: E221__MFL-TAS  H05 0010
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 811 F    HW: 6R0 959 811 F
   Component: J388__TSG_HL  006 0902
   Coding: 08BC32
   Subsystem 6 - Part No SW: 6R0 959 812 F    HW: 6R0 959 812 F
   Component: J389__TSG_HR  006 0902
   Coding: 08BC32
1 Fault Found:
00901 - Back-Up Lamps
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 88
                    Mileage: 17170 km
                    Time Indication: 0
                    Date: 2000.14.25
                    Time: 16:56:07
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475     HW: 6R0 919 475
   Component: PARKHILFE 4K  H07 0008
   Revision: --------    Serial number: 71391009039009
   Coding: 100101
   ASAM Dataset: EV_VW250ParkiAssis2 S01006
   ROD: EV_VW250ParkiAssis2.rod
   VCID: FBF5916772103BC6411-80AE
   Component: VW10Airbag00G H08 0020
   Revision: --------    Serial number: 003GX0014B1Q
   Coding: 003047
   ROD: EV_AirbaVW10BPAVW250_VW24.rod
   VCID: 4A9B84A3ED4AD24E0A7-801F
   Crash sensor for side airbag; driver side:
   Serial number: 3572SRB40000B22CDAFN
   Crash sensor for side airbag; passenger side:
   Serial number: 3582SRB40000B238A2E9
   Crash sensor for side airbag; rear driver side:
   Serial number: 3515RRB405D6Q5D6GOR9
   Crash sensor for side airbag; rear passenger side:
   Serial number: 3525RRB405F6Q5D6I8N.
   Part No SW: 6R0 920 861 D    HW: 6R0 920 861 D
   Component: KOMBI         H13 0024
   Serial number: 00000002312652
   Coding: 140E00
   Shop #: WSC 12469 483 00190
   ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01004
   ROD: EV_DashBoardUDSJCIPQ25_VN81.rod
   VCID: 3663C05389B2A6AE7EF-8063
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 6R0 937 087 D
   Component: GW-K-CAN TP20 0207
   Coding: 002200
   VCID: F0EFB64B2356489EE43-80A5
1 Fault Found:
01304 - Radio
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 137
                    Mileage: 10834 km
                    Time Indication: 0
                    Date: 2061.14.28
                    Time: 08:54:24
Address 25: Immobilizer (J285)       Labels: 5K0-920-xxx-25.clb
   Component: IMMO          H13 X005
   Serial number:
   ASAM Dataset: EV_ImmobUDSJCIPQ25 A01001
   ROD: EV_ImmobUDSJCIPQ25_SK25.rod
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 00788
   VCID: 2F6DF537EAE897663D9-807A
Address 56: Radio
Cannot be reached
End   ---------------------------------------------------------------------
Here are pictures of light switch:
I hope I did everything you said I need to do.
Thank you again :)
Ugabista
Drives: Vw Polo 6R 1.6TDI 90CV CAYB
Re: RE: Re: ciclo's Polo. R-line 1.2 TSI 90hp 119gr.
Post by Ugabista »
Tadej, i have a car exactly like yours... http://www.uk-polos.net/viewtopic.php?t=62393
What mods you have make about electronic? You have topic for your car?
Marjacic
Drives: Polo 6R 1,6 TDI 105 hk Highline
Post by Marjacic »
Tadej.
Try with this :
3CB82FB868210000013808247E8C1FD1D08041BF60862041000000000000
tadej
Post by tadej »
Ugabista wrote:
tadej wrote:Thank you again Ciclo.
   Coding: 0000020
No Faults Found
   Revision: V0000000
1 Fault Found:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 103
                    Mileage: 16596 km
                    Time Indication: 0
                    Date: 2000.14.13
                    Time: 09:07:05
   Coding: 0005F3
   Coding: 18BC30
   Coding: 08BC30
   Coding: 020000
   Coding: 08BC32
   Coding: 08BC32
1 Fault Found:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 88
                    Mileage: 17170 km
                    Time Indication: 0
                    Date: 2000.14.25
                    Time: 16:56:07
   Coding: 100101
   Coding: 003047
   Coding: 140E00
   Coding: 002200
1 Fault Found:
01304 - Radio
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 137
                    Mileage: 10834 km
                    Time Indication: 0
                    Date: 2061.14.28
                    Time: 08:54:24
   Serial number:
   Coding: 11230
   Shop #: WSC 00788
Address 56: Radio
Cannot be reached
I will take pictures of my light switch in a few minutes, I'm writing this from inside the car. :)
Hi Ugabista! :)
What I have made since I got my car:
-change all interior light bulbs to LED
-change DRL light bulbs to LED
-change all H7 light bulbs with white xenon look(5000K)
-license plate light bulbs with OEM LED
-front parking light bulbs with OEM LED
-gas and brake pedal with ALU pedals
-swapped original RCD310 with OEM look-a-like radio with 7" touchscreen display, BT, navi, 2xUSB
-subwoofer in the trunk
I'm now working on static cornering lights, maybe also CH/LH(if it's easy). I also need to get chrome exhaust tip.
tadej
Post by tadej »
Marjacic wrote:Tadej.
Try with this :
I'm sorry Marjacic, but I don't understand this? I need to paste this code where?
I'm really sorry, but I'm not so technical experienced in VCDS.
Thank you in advance for your help :)
Marjacic wrote:
ciclo wrote:Marjacic
Rns510 New coding
00000402000000812000
Check MFD
Tell us the results...
nothing happend :(
Read red...
Marjacic
Post by Marjacic »
Try with this :
sorry .
copy the long coding and paste it .
go to . 09 central electronic - select 07 coding . and then paste the long code you got.
let us hear about the result :)
Marjacic
Post by Marjacic »
ciclo wrote:
Rns510 New coding
Check MFD
nothing happend :(
Read red...
:mrgreen: :mrgreen:
You are the polo legend! :!:
Try with this :
Do not do it.
Marjacic
Post by Marjacic »
ciclo wrote:
Try with this :
Do not do it.
why? my car is exactly the same as his. :) :?:
Thank you again :)
Perfect, what I already knew and said you previously. http://www.uk-polos.net/viewtopic.php?f ... 95#p503227
Let me some time to review the diagrams, then I tell you'll have to do to have the static cornering lights.
By the way, excellent pictures... 8)
tadej wrote: What I have made since I got my car:
Marjacic
Post by Marjacic »
tadej
Post by tadej »
ciclo wrote: Perfect, what I already knew and said you previously. http://www.uk-polos.net/viewtopic.php?f ... 95#p503227
Thank you very much Ciclo. Even though I wrote on this forum, I didn't even suspect such helpful people. Thank you a lot! :)
For the pictures I have to thank my Samsung S6 Edge+ :D It's a beast when it comes to taking pictures. I actually own a DSLR Nikon D800(I'm taking pictures of cars in my free time) and I have to admit that the optics on the S6 are really something special :)
Ugabista wrote:Tadej, i have a car exactly like yours... http://www.uk-polos.net/viewtopic.php?t=62393
Does your light switch connector has exactly the same cables? Please check it out. :wink:
Locked
