masterofpolo
Drives: 1.2 TSI DSG Lounge
Post by masterofpolo »
Dear Ciclo,
I need your help for installing Ultrasonic sensor alarm polo. I collect required equipments in the picture for the sensor(1) and alarm system(2), but ı need to know that should I need VCDS coding for activate this system or key recognition etc.? If I buy these parts and connect them with wires is it work? Should I connect them BCM? I appriciate for your help.Image
Yes, this is possible. The siren and sensors are both controlled by the BCM.
For Polo 6R
So you need to run some wires to the siren and the sensors:
Sensor
pin 1
pin 2 GND
pin 3 T73b/24 (BCM white, same wire as the RLS for example)
pin 4 Permanent +12V
Horn
pin 1 T73b/36
pin 2 GND
pin 3 Permanent +12V
Deactivation button (not obligatory)
pin 1 an T73b pin 30
pin 2 an T73a pin 57
pin 3 an T73a pin 65
pin 4 an T73a pin 4
Central electrics, coding, byte 6, change to '24'
And byte 8, set to 1: byte 1, 4 and 7
For Polo 6C
Sensor
pin 1
pin 2 GND
pin 3 T73c/15 (BCM black big connector)
Horn
pin 1 T46b/25 T46b = middle connector, the smallest on the BCM
pin 2 GND
pin 1 T73a pin 38 (BCM big white connector)
pin 2 T73a pin 37
pin 3 T73c pin 69 (connect with existing wire)
pin 4 to brown/black cable from centre reading light. But I don't know to which BCM connector it goes
For coding, I don't know.
iichel, EXCELLENT!!
I learned from the best
gti16
Drives: VW Polo 6r 1.6 TDI
Post by gti16 »
hello ciclo
This button is unique to the polo 6r? 6RU927122
I want to install a button to activate the OPS without having to put the reverse, and this button is ideal for this purpose.
thank you
masterofpolo
iichel wrote:For Polo 6C
Sensor
pin 1
pin 2 GND
Horn
pin 2 GND
pin 2 T73a pin 37
I can't find any words to say... Your're real master icchel !!! Thank you and ciclo for your all effort to help for wv end-users... I'm sure you're better than the most of WV services in my country :) I share my info and pictures after I installed to the car. In addition to this, I didn't see alarm deactivation button for polo in the carprog2 program schemes. Dou you know where is the connection diagram of this system? (Anyway it is not mandatory ı will not use it so then)
the button is part number 6Q0962109B
you need the door sill trim LHD 6R4853371H (left, 5-doors, with alarm PR code 7AS) or 6R3853371A (3-door, I'm not sure it makes a difference for 3 doors?)
connector is 8E0971832
the wiring diagrams, you can find in ESLAWIN
the parts are in ETKA -> www.ifiinterface.com --> http://ifinterface.com/prog/car/prog2/inprog.php
gti16
Post by gti16 »
I need the electric scheme, plug OBD2 Polo 6r.
Someone can help me?
Ugabista
Drives: Vw Polo 6R 1.6TDI 90CV CAYB
Post by Ugabista »
Hello friend, can you help me, please?
viewtopic.php?f=56&t=62393&start=105
benji58
Drives: 6R R-Line 1.2 TDI
Post by benji58 »
ciclo wrote: New mod
Changing the upper speed threshold for static cornering light.
VCDS
Address 09 Cent Elect, Adaptation, Channel 32, default 40 km/h.
I set the upper speed threshold at 55 km/h.
Impressive performance along with HBA during the test.
Works like a charm.
Remember they are static cornering lights, not dynamic cornering lights. :lol:
hi ciclo
good mod ! I tested it works perfectly. since the time I was looking for, thank you ! :D
link to the rear LED bulbs : http://www.ebay.fr/itm/Kit-ampoules-led ... 1742668690
Finally the project to change the BCM's for later. I'm working on a new mod on my polo :mrgreen:
if I have a VCDS issue, do you know how to disable the lamp diagnostic for front parking light?
ORiOn
Drives: Polo BlueGT / Audi S5
Post by ORiOn »
I'm sorry to ask this here...
Can anyone give me the electric scheme/diagram of the Bi-Xenons connector?
ThankS!! :D
I am sorry to inform you all that ciclo is a busy man and to save him from over-stressing, I'll answer the questions as good as I can.
gti16 wrote:I need the electric scheme, plug OBD2 Polo 6r.
source: http://www.ross-tech.com/vag-com/2x2.html
Ugabista wrote:Hello friend, can you help me, please?
try security access for PDC module and make sure you have latest VCDS version
this error I don't know about. but that's all google shows.
benji58 wrote: if I have a VCDS issue, do you know how to disable the lamp diagnostic for front parking light?
try byte 19 bit 6
ORiOn wrote:I'm sorry to ask this here...
ThankS!! :D
1-4: AFS
5 + 7: mass
6: low beam
9: indicator
10: LED plus
11: high beam
12: LED PWM
14: cornering light
8 and 13 stay vacant
gti16
Post by gti16 »
thank you iichel but it is not what I want.
I want to know what connections in the car's OBD2 plug.
Ugabista
Post by Ugabista »
What PDC module? I do not have parking sensors. I've tried 2 different pcs and the VCDS 12.12 and 14.10.2. See the scan I made and the modules that have installed please.
Locked
