6R 1.6TDI 90HP CAYB 2009
- Ugabista
- Drives: Vw Polo 6R 1.6TDI 90CV CAYB
Re: 6R 1.6TDI 90HP CAYB 2009
Any idea what this will be?
https://drive.google.com/file/d/1nkjXIU ... p=drivesdk
Ventilator? [emoji848]
I'd say a broken fan resistor. It's on top of the heater housing, you can just about reach it via the glove box compartment.
The AC probably shuts off to protect it. If there is no airflow, the AC can overheat or over-pressurise.
- Ugabista
Along with this problem, I noticed that the G12 was below the minimum, which I replaced. Only the AC works at speed 4, at speeds 1, 2 and 3 it does not work. Being in position 4 never shuts off.
In the afternoon I'll check what you said.
Well can you maybe confirm, the fan is moving at speeds 1-2-3 as well? Maybe my sound is wrong, but I don't hear the fan at speeds other than 4?
- Ugabista
I don't notice that, I'll check this shortly, and turn on vcds to see if have any errors and put here.
- Ugabista
Well, not have erros in vcds about that.
Air or AC only work in position/velocity 4, in another 3 velocitys not work anything.
yeah that's very like the fan resistor/thermal fuse (6Q0 959 263 A)
Id agree, fan resistor
Youll only get an error on the full climatronic. The climatic semi auto aircon doesnt monitor this
- Ugabista
OK friends, thanks a lot for help.
I'll buy this now in Vw. [emoji1360]
- Ugabista
Problem solved
Thanks friends [emoji1360][emoji1360]
Good job!
- Ugabista
Well....another problem on car...[emoji848][emoji2955]
What sensor and where he stay, anyone know? [emoji57]
ORiOn
- Drives: Polo BlueGT / Audi S5
B1 S3 means Bank 1 Sensor 3...
It's a sensor situated near the catalytic converter...
(I don't really know TDI's...)
- Ugabista
Thanks [emoji1360]ORiOn wrote:B1 S3 means Bank 1 Sensor 3...
I liked to know what is the Part number of that but i can't find [emoji848][emoji57]
