UK-POLOS.NET - THE VW Polo Forum • Polo 6R ABS CODING - Page 15
Page 15 of 35
Re: Polo 6R ABS CODING
Posted: Mon Mar 04, 2019 2:31 pm
by massimo23
This is info from vw about tpms:
Direct system:
A tyre pressure sensor is installed in every wheel.
It transmits information to a control unit.
The on-board computer displays the tyre pressure.
If the pressure falls, the system warns the driver.
Important: When you switch to winter tyres, new sensors need to be installed.
Indirect system:
The system measures the speed of the wheels, not the pressure.
Depending on tyre pressure, a wheel covers a certain distance in one revolution.
This gives rise to the speed of the wheel.
The system calculates the pressure from the speed.
If the speed increases, the pressure falls and the system warns the driver
Important: You do not need new sensors when you switch to winter tyres.
All the VW Polos use the indirect tpms system. If you have the tyre monitoring system on the cluster then you would have the direct version.
Posted: Mon Mar 04, 2019 2:55 pm
by miky396
Indirect it is
Posted: Mon Mar 04, 2019 3:03 pm
by miky396
I ll check everything u said to me on wednesday
Posted: Mon Mar 04, 2019 3:05 pm
by miky396
No, originally this option doesn t appear on my multimedia and i don t have the physical button, so my esp is always on i can t deactivate it or change it to sport or turn the asr off.
Posted: Mon Mar 04, 2019 5:07 pm
by massimo23
Hi mike I would need full scan of 09, 17 , 19 and 5F (include adaptions). i will compare with mine to see the differences.
Posted: Mon Mar 04, 2019 5:34 pm
by massimo23
I dont have the ESC physical button either. ;-)
Posted: Tue Mar 05, 2019 12:32 am
by miky396
Ok as soon as i can i will post them here for you
Posted: Wed Mar 06, 2019 10:32 pm
by miky396
So at page 13 there s a full scan of my car, i tried to do the las things u said and it still doesn t work...
Posted: Thu Mar 07, 2019 12:00 am
by massimo23
Hi mike I mean the admaps of those control modules. they contain all the extra functions of the module similar to my adaptions list.
Posted: Thu Mar 07, 2019 9:08 pm
by miky396
Oo ok sorry, as soon as i can i will post them thank u so much
Posted: Sat Mar 09, 2019 2:20 pm
by starostkadk
I need a new coding for the abs. I have switched the instrument, and didn't know it deleted the abs coding.
Hope anyone can help. I have tried to use the ESP calculator, but it won't accept that code it generates.
Polo 1.6 TDI CAYB LHD.
I have TPMS, HHC and Start/Stop.
Tuesday,01,October,2013,15:09:45:40973
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVWZZZ6RZCY523585   License Plate: CB92595
Mileage: 186937   Repair Order:
Chassis Type: 6R (6R0)
Scan: 01 03 08 09 15 17 19 25 44 56 61
Address 01: Engine (J623-CAYB)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 ME    HW: 03L 907 425 B
   Component: 1,6l R4 CR td H33 9971
   Revision: --H33---    Serial number:
   Coding: 00114016002401080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM16TDI02103L906023ME 003012
   ROD: EV_ECM16TDI02103L906023ME_VW25.rod
   VCID: 75E10756D4613BB6B75-8020
1 Fault Found:
7196 - Function Restriction due to Faults in Other Modules
          U1113 00 [101] - -
Readiness: 1000 0000
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 000000000000000000000000000000000000
   VCID: 871DFD9E328DB926559-80D2
4 Faults Found:
03306 - Coding Not Valid
            000 - - - Intermittent
01042 - Control Module; Not Coded
            000 - -
00778 - Steering Angle Sensor (G85)
            005 - No or Incorrect Basic Setting / Adaptation
00493 - ESP-Sensor Unit (G419)
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 387FCE628BF386DE6C3-806D
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 6R0 937 088 F    HW: 6R0 937 088
   Component: BCM PQ25 Re4  H50 0351
   Revision: BU050001    Serial number: 0456 242111889
   Coding: 3CB02BBF08A10000213009F02D2B0FD85F80612F7E060049200000000000
   Shop #: WSC 12469 483 00190
   VCID: 4189A386D829C716DBD-8014
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 080911 05  54  0403
   Coding: 03302D
   Subsystem 2 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Coding: 58BC30
   Subsystem 3 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD
   Component: J387__TSG_BT  008 1611
   Coding: 48BC30
   Subsystem 4 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Coding: 48BC32
   Subsystem 5 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Coding: 48BC32
   Part No SW: 6R0 959 655 L    HW: 6R0 959 655 L
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GY004BMGK
   Coding: 003232
   ROD: EV_AirbaVW10BPAVW250_VW24.rod
   VCID: 4B9581AEE2651D46311-801E
   Crash sensor for side airbag; driver side:
   Serial number: 3575HRB40690OCUI9HE3
   Crash sensor for side airbag; passenger side:
   Serial number: 3585HRB40690OCUIB8E/
   Crash sensor for side airbag; rear driver side:
   Serial number: 3515RRB40630M8GE61OB
   Crash sensor for side airbag; rear passenger side:
   Serial number: 3525RRB405N0NI3GEPMI
   Part No SW: 6R0 920 861 H    HW: 6R0 920 861 H
   Component: KOMBI         H03 0505
   Coding: 540E01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: 3A7BD46ABDFF94CE9A7-806F
Address 19: CAN Gateway (J533)       Labels: 6R0-907-530-V2.clb
   Part No SW: 6R0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H38 0035
   Revision:   H38       Serial number: 050911F1003881
   Coding: 2500C2
   VCID: 3467FA52979B62BE40B-8061
1 Fault Found:
00381 - Databus Instrument Cluster
   Component: IMMO          H03 0505
   Serial number:
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
   VCID: EADBA42A0DDF644EAA7-80BF
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 00788
   VCID: 2F6DF53EEABD41663D9-807A
Address 56: Radio (J503)       Labels: 6RD-035-187.lbl
   Component: MIB2-S-R-CN   036 0317
   Revision: -----001    Serial number: VWZ6Z2R7374078
   Coding: 1600040004000A
   Shop #: WSC 127395 840 08317
   VCID: 4683B09AF107E02EEEF-8013
10 Faults Found:
00876 - Treble Speaker Rear Left (R14)
            011 - Open Circuit
00877 - Treble Speaker Rear Right (R16)
            011 - Open Circuit
00856 - Radio Antenna
            007 - Short to Ground - Intermittent
            011 - Open Circuit - Intermittent
00873 - Bass Speaker Rear Right (R17)
00872 - Bass Speaker Rear Left (R15)
00871 - Bass Speaker Front Right (R23)
00870 - Bass Speaker Front Left (R21)
01305 - Databus for Infotainment
            004 - No Signal/Communication
00625 - Vehicle Speed Signal
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 6R0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H38 0035
   Coding: 030B1A5A
   VCID: F4E7BA52571BA2BE00B-80A1
   Subsystem 1 - Part No SW: 6R0 915 181 D    HW: 6R0 915 181
   Component: J367-BDM  H07 0180
End   ---------------------------------------------------------------------
Posted: Mon Mar 11, 2019 10:27 am
by iichel
Is the original cluster back in? If the cluster is not adapted to the car (i.e. the engine cannot start) then the ABS will never accept new coding. The cluster needs to be OK (i.e. the original cluster put back in, or new cluster adapted to the cars immobilizer and VIN).
Posted: Mon Mar 11, 2019 10:43 am
by iichel
anyways try something like this: 210228e3436F00B5842A14EAC2D600420700
Posted: Mon Mar 11, 2019 6:22 pm
by starostkadk
iichel wrote: Mon Mar 11, 2019 10:43 am anyways try something like this: 210228e3436F00B5842A14EAC2D600420700
Yes it's the original cluster back, it wont accept yours, but I got it to accept 210228E3426F00B5842A14EA42D600421700, but I get a start stop error when I start the car.
Gettings this error now.
                Address 03: ABS Brakes       Labels: 6R0-907-37X-ESP82.clb
Control Module Part Number: 6R0 907 379 AK    HW: 6R0 907 379 AF
  Component and/or Version: ESP8.2i front H05 0001
           Software Coding: 210228E3426F00B5842A14EA42D600421700
            Work Shop Code: WSC 00788 648 00255
2 Faults Found:
            000 - -
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 3
                    Reset counter: 247
                    Mileage: 187124 km
                    Time Indication: 0
                    Date: 2021.14.01
                    Time: 17:48:47
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x1201
                    Hex Value: 0x37A0
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 31
                    Mileage: 187124 km
                    Time Indication: 0
                    Date: 2021.14.01
                    Time: 19:18:15
                    Hex Value: 0x0000
                    Hex Value: 0x0002
                    Hex Value: 0x3203
                    Hex Value: 0x25BB
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
Posted: Mon Mar 11, 2019 10:09 pm
by iichel
try:
210228E3436F00B5842A14EAC2D600421700
