ORiOn
- Drives: Polo BlueGT / Audi S5
That's what i tough! Thanks!
[quote="iichel"
It will not be listed but i'm sure some people here, including myself, will be able to assist you with it.[/quote]
That's great, will let you know how I get on
Adam87 wrote:Great news ciclo [emoji106] I have a my15 T5 highline and will be retrofitting lane assist, bi-xenons, RLS, heated seats etc, I see that you retrofit the t6 BCM into the polo (7E0 937 090), will it work with xenons? Yes, perfectly. All I can see in etka is listed with halogen or led. Also Is there anything extra in instrument cluster to add? I believe there is no convenience menu? It only add a menu for driving assistants (when they are installed, I guess) .I have this cluster installed. Nice
Adam87, you know, more information means more help.Adam87 wrote:Thanks for the reply iichel, would you say to use coding from 7H0 bcm for xenons or will it be listed in long coding? No problem.Is there any specific prefix after part no 7E0 937 090 * ***? Yes, uses this PDF to choose according factory equipment of your T5, and choose 7E0 BCM it has all the functions of your T5 Highline and those you want to add. I would choose the best.
Do you have pictures of your T5 (interior and exterior)? Any link to another forum?
iichel wrote:It will not be listed but i'm sure some people here, including myself, will be able to assist you with it.
The best to run correctly xenon headlights is to install one BCM Max. It is now much easier.ORiOn wrote:Hey guys!
Is it possible to install original bi-xenons an a polo with 6R0937087B BCM?
Thanks!
Any other option is undoubtedly worse.
Thank you ciclo, with regards the options list, do I have to write all the codes down and make a list or can I order a max bcm that is capable of all? My T5.1 GP is a highline so already has cruise, powerfold heated mirrors, elec Windows, front fogs,AC and I have had the new cluster fitted
Have now fitted roof rails and side bars since this pic
Also want to fit auto distance reg aswel [emoji6]
The more important thing is that the new 7E0 BCM is suitable for Central locking frequency (MHz) and for tail doors (rear wing doors
, sorry I do not know as they say in English)
For everything else you can choose (and highly recommended) the BCM that it is capable with all equipment available.(PR-codes A8M, A8Z)
ACC? (I also want it
) but perhaps a new ABS/ESP unit with appropriate software is required, also other units. I do not know for sure because my knowledges are limited about ACC, but it sure is an expensive modification.
433mhz is ok I'm guessing, which pr code is the highest spec? Or what is the difference between them?ciclo wrote:The more important thing is that the new 7E0 BCM is suitable for Central locking frequency (MHz) and for tail doors (rear wing doors, sorry I do not know as they say in English)
ACC? (I also want it) but perhaps a new ABS/ESP unit with appropriate software is required, also other units. I do not know for sure because my knowledges are limited about ACC, but it sure is an expensive modification.
I had a courtesy t6 with acc and now I want to fit [emoji3] I did take an autoscan of it aswel [emoji6], I think definitely BCM, maybe ecu and abs?
434 MHz
7E0937090A Z0J ...8IT+7Y1+8T0,8T1,8T2,8T3,8T5+3RD,3RE,3RF,3RG
or
7E0937090 Z4Y ... 8IT+7Y1+8T0,8T1,8T2,8T3,8T5+3RB,3RC,3RP
Check which fits with your T5.
I also have several T6 autoscan with all possible configurations, without CCS, with CCS on stalk, with CCS on MFSW buttons, with ACC, etc...
or
Ace [emoji106], it's the first one I need, will that support lane assist do you know? I can see it in the codes, I can send you the t6 autoscan if it helps you in anyway?
Can you help with coding to get mirrors to fold on key? Which number in LC do I need to change?
Spolos
- Drives: Volkswagen Polo 6R Comfortline 2012
Hi Ciclo,
I want to tell you how happy I am with the ch/lh and cables for BCM MAX! Everything works just fine without errors and stuff thanks again! This is for the people ho want to do also a BCM Max retrofit Ciclo is THE Polo Doctor!!!
Thanks man for all the help!
Spolos
Spolos
gpeixoto109
- Drives: 2013 Polo 6R 1.2TDI
Spolos wrote:Hi Ciclo,
Spolos
Absolutely! He knows everything!
- federicodrdpro
- Drives: White Polo 6R TDI
edit
Last edited by federicodrdpro on Fri Apr 15, 2016 3:43 pm, edited 1 time in total.
- federicodrdpro
edit 2
Last edited by federicodrdpro on Fri Apr 15, 2016 3:44 pm, edited 1 time in total.
- federicodrdpro
- CNK
- Drives: 6R
Yes, it works only with PQ35 BCM (e.g Golf 5, Golf 6).
Polo 6R has got PQ25, so ciclo used mirror from VW T6
