- Drives: 6R, skoda rapid version of polo ;)
From my knowledge CC is supported from x87 upwards. You would need to change BCM as well.
Prise for that part includes new stalks and cables. You can make cables yourself and buy only stalks to lower prise... even more buttons can be made cheaper, there are no chips inside just one diode (if you can accept cheaper look)
Unfortunatelly you cant skip BCM replacement if you have x86 and want to have original one. You can search for used BCM (from cars after accidents). If you want to confirm it, disconnect battery and than first socket from BCM and you will see missing pins in place CC would go.
You can also go different route not described here and get CC which plugs to gas pedal + odb socket. In such case ODB2 is used to read speed and voltage from gas pedal is simulated.
Summary for CC pins in ECU:
1.2 TSI and 1.4TSI are using pin 45
1.6 MPI pin 24
1.2 HTP pin 69
1.6 TDI pin 64
1.6 MPI pin 24
1.2 HTP pin 69
1.6 TDI pin 64
- Drives: VW POLO 6R
thanks for the tips ; unfortunately tried to steal the car, now it's in the workshop; the positive thing is that I have seen the original stalks: 6r0 953 521 A. and the ECU code: 03L 906 023 NG; can you serve other tips?
Buy a BCM 6R0937087 R or T or AD from 2016 onwards, the best of these BCM models are in Russia.
In this forum there are Russian users who can help you with this. Maybe firegrafik can advise you here.
All you have to do to install it is this. http://wiki.ross-tech.com/wiki/index.ph ... rol_Module
These are the stalks you should buy.
6R0953507C
In this case and if your priority is the total cost, these will also work perfectly. (they are of good quality, but not as much as European ones)
Depending on your brake system (ABS or ESP) it may be necessary to replace your current steering ring by the one installed on the stalks of the image. Easy.
6R0953507C
thanks guys, you are very kind; I look for components; we feel it soon .. thank you again
- Drives: 6R 1,6MPI(CFNA) sedan
It is possible to get new BCM 6R0937087AB
https://www.drive2.ru/o/b/474179783714930804/
Price is about 80-90 EUR. Needs to make a request for clarification.
6R0937087AB would be perfect. 2017!!
Hallo ciclo,
on ebay are used cheaply the 6r0 953 087 m; are they okay?
sorry firegrafik, I did not realize your answer; would it be possible to ship also to Italy?
Yes, the seller could ship to anywhere. You could register on drive2.com and write the seller to the private message. Because of he has many foreign customers he starts to learn English, so he will understand your request. Other way I could ask him about stock and prices, and write you privately here.chinesia75 wrote: ↑Sun Oct 22, 2017 11:02 pm sorry firegrafik, I did not realize your answer; would it be possible to ship also to Italy?
NO (2013)chinesia75 wrote: ↑Sun Oct 22, 2017 9:32 pm Hallo ciclo,
on ebay are used cheaply the 6r0 937 087 m; are they okay?
my car is registered 12/2013
Yes, but your car is a Fabia (without VCDS autoscan), and you have to consider many other things.
The more updated BCM the less problems you will have to install it in your FABIA, and on the other hand will allow you some more modifications in your car with current original parts.
ok cycle,
I apologize for the many questions, given my ignorance in the field, I want to be sure not to make mistakes; sorry cycle about the stalks, the ring with steering sensor you mentioned what code should have to be correct?
We need an autoscan from your Fabia so we can continue advise you.
ABS or ESP?
ABS or ESP?
you are right cyclo,
what cable do I have to buy for modification and autoscan?
I anticipate that my car has the abs and esp.
