Amarok Oem Bixenon retrofit
peter222
Drives: amarok 2012
Re: Amarok Oem Bixenon retrofit
Post by peter222 »
otherwise, thank you ciclo for your help, I wouldn't have finished it without you. big thanks :D
We have done what we could. Everything works and VCDS faults are not real faults due to the state of things.
However, if you want, and to try to solve / investigate / make comparisons in the adaptation channels about the 'wrong' diagnosis on the high beams, please do the following:
- VCDS:
https://drive.google.com/drive/folders/ ... sp=sharing
- VCP:
https://www.youtube.com/watch?v=16zeMCk_Ipg
Take a read of all the BCM adaptation channels and share the text file.
Upload the generated info to a file hosting server, the two files, and share it here via a link.
I will be able to do a study of the channels and tell you something about it.
Nice LED reversing/backup lamps. I like it 8), both the location and the powerful lighting, it must be great to get that lighting when reversing on difficult terrain. 👌
It is logical that the fault is thrown in the diagnosis, but I think you can live with that without problems.
:idea:
Trick to avoid the reversing light diagnostic fault 'in case you have those non OEM reversing lights connected to the old original wiring' (T73b/48, F4).
You can install any bulb model (LED or halogen) in a 'strategic place' (e.g. loading area, between the wheel arches) so that it is not visible to other drivers, power it with a new wire from T73b/12 and the earth/ground wire to make it work. The fault will disappear.
